Headless Nick
Table of contents
Headless Nick
Abstract
A Harry Potter-themed, battery-operated, dual-XIAO ESP32-C5 gadget designed for use with GhostESP firmware. This dual-band penetesting gadget is a headless, battery operated tool, controllable via any Wi-Fi supported device such as a laptop or phone.
  I made Headless Nick for my 2026 Halloween project independently, unaware of the competition. I wanted to build something for one of 2 of my favorite open-source projects to support the developers behind them and to put something in my hands that I have been wanting for a long time. A dual-band, pocketable, headless penetration testing gadget you can operate via webUI from your smart phone.
  The project I chose to build this for ended up being GhostESP, as opposed to Bruce Predatory Firmware. GhostESP firmware was such a great fit for this. The XIAO ESP32-C5 was already supported for their firmware—requiring less setup headache, and the GhostESP theme has always caught my attention. Being Halloween, I shaped the theme to be ghostly and because I was raised a Harry Potter fan, I decided to make the ghost element be that of Nearly Headless Nick. Firstly because he is an iconic ghost in the Harry Potter stories and secondly because the Nearly Headless Nick character's number one feature is he is "nearly" headless and always on a mission to join the Headless Hunt but fails to ever get approved to join because he isn't fully headless. I decided to call this project Headless Nick because this is a headless gadget. There's even an Easter egg on the back of the PCB that quotes the movie scene where Headless Nick says, "Once again, my request to join the Headless Hunt has been denied." Whereas on the PCB it says, "My request to join the Headless Hunt has been approved." A play on that dilemma considering Headless Nick is headless.
  I gave myself from the first of October to Halloween to finish this project. Starting out, I needed to learn how to wire everything up properly. I needed two XIAO ESP32-C5 chips to use the GhostLink feature to have one XIAO ESP32-C5 host the webUI and the other chip to be on standby for GhostLink commands so the webUI would be stable while the penetration testing and wireless diagnostic tools in the firmware are being executed. I figured out the wiring by using a breadboard and male-to-male pins and figuring out the best setup for this configuration.
  While networking in the GhostESP Discord server during the development of this project, I noticed some stability issues with the webUI and the main developer behind the GhostESP project was quick to solve it. This made the next step much more exciting because it meant the final product was going to have no issues running GhostESP firmware. The next step was learning how to design a PCB. So I spoke to my electronics engineer friend, Surya Rapeti (aka REDHAT) because he was talented at this type of stuff and he recommended I use EasyEDA.
  Getting started with EasyEDA was very easy and I had very few questions getting this project done. Having REDHAT available for advice made the process go smoothly. He made design recommendations for the board itself which ended up ultimately becoming a very nice little gadget. Once I got it, I assembled it and it worked flawlessly. All in 3 days before Halloween.
  Now, you can build one yourself using either the breadboard/perfboard method or you can have them manufactured yourself. I released everything fully open-source on GitHub on Halloween.
References
GitHub Project Link: https://github.com/GH0ST3CH/Headless_Nick
Category : project
