Squawkin’ on My Coffin is an infectious & entertaining Halloween themed animatronic tabletop centerpiece.
The Squawkin’ on My Coffin animatronic routine stole the show, so the build aptly was named for that animatronic routine. The video of that animatronic routine action is seen here: Squawkin' On My Coffin Animatronic routine https://youtu.be/_Yf-5-MaQdw
The project is Raspberry Pi Pico controlled, the hardware features:
- qty 2 SSD1315 OLEDs screens for animatronic BIG SKULL eyes, each screen on its own i2C network
- qty 2 WS2812 addressable LEDs for the Crow’s eyes
- qty 4 SG90 servos – one for the coffin lid lift, 2 for the Crow’s wings, qty 1 for the Crow’s neck to rotate the head
- 3 PWM outputs for skully LED eyes. The Red LEDs require a lot more mA than the green ultrabright LEDs, so the red LED circuit uses 1 output per eye.
- DFPlayer audio with an LM386 amplifier. Simple relay contact play selection
- Lots of scary bones, spiders, and a creepy coffin
Top View
Top View of electronics
Coffin Lid Lift
The design uses a left side motion detector and a right side motion detector to trigger user interactive animatronic routines.
The animatronic auto mode video can be seen here: Squawkin' on My Coffin in Auto Mode https://youtu.be/EbOLi8S1AEI
- If a left motion is detected, the left side Skull eye’s light green, the Big Skull eyes look to the left, the crow looks left, changes it’s eye color from yellow to green, and the crow squawks.
- If motion is detected on the right side, the right side Skull eye’s light red, the Big Skull eyes look to the right, the crow looks right, changes it’s eye color from yellow to violet, and the crow squawks.
- The code also uses several random number generators to trigger unnerving animatronic routines, mostly to the Big Skull’s eyes, and the show stealing “Squawkin’ on the Coffin.
On first boot up, the Big Skull first displays it’s whole catalog of eye movements and OLED graphics. The software then continues on to test each servo motion, one at a time, and the BIG SKULL eyes provide annunciation of which movement is being exercised. Finally, the software does a test run of SQUAWKIN’ ON MY COFFIN, then goes into its automation loop.
The video: Squawkin' Project startup Graphics and motion test mode https://youtu.be/Grc2aQXAHl4
Some interesting background of the project development:
The initial project goal was to build a really inexpensive graphic eye movement solution inspired by https://blog.adafruit.com/2019/09/24/halloween-builds-from-hackspace-magazine-issue-23-out-now-halloween-hackspacemag-adafruit/. A ton of time was spent trying out programming graphics, finally figuring out using byte arrays for graphics would be the best way to go. The SSD1315 screens would be mounted inside a plastic skull. The skull would have a couple smaller buddies with flashing LED eyes.
After a brief detour to implement the small skull eye flashing with 555 timers, the playing with byte arrays continued to grow using the Big Skull and the Pico python code.
The coffin was added to the project to house the RPi Pico and power distribution. The project workscope kept growing , the coffin wasn’t big enough to house all the electronics and wiring. It was way more fun to add a servo and have the coffin lid open, with a pair of LED eyes peeking out.
Workscope creep again - If the coffin lid opens, wouldn’t it be fun to have something on top to get upset about the lid opening ? It sure would. A stop at the Dollar Store for a cheap rat and a crow skeleton would do the job. The crow had a lot of potential for animatronics. Individual WS2812 addressable LEDs first went into the eyes, and a servo was installed under the head for neck movement. The expandable flapping wings would be so cool. After several days of mockups and trials for electromechanical flapping wings, it was needed to step back and keep it simple. The plastic skelly wings were each hot glued to servos. Dog gone – Halloween had passed, I am still adding stuff.
It would so much better to have the crow squawk and add other sound effects. A DFPlayer was added, but time is ticking away, I didn’t have the time to develop UART software for the DFPlayer, so a relay contact brute force served the need to play the crow sound track.
So this is the project as it stands today, but has great potential to continue to add features and functionality. I’m thinking it would be an inexpensive and fun hardware platform to use to teach python classes with the Raspberry Pi Pico.
Now onto publishing the Schematics and code to continue the fright
# Display Image & text on I2C driven ssd1306 OLED display
# for this code to work, SSD306.py must be saved to the Pico
# the HW is qty 2 SSD1306 OLEDs one wired to i2c#0, the other wited to i2c#2
from machine import Pin, I2C, PWM
from ssd1306 import SSD1306_I2C
import framebuf
import math
import utime
import random
WIDTH = 128 # oled display width
HEIGHT = 64 # oled display height
LHS_PIR = Pin(8, machine.Pin.IN,machine.Pin.PULL_DOWN)#GPIO8 is physical pin 11
RHS_PIR = Pin(9, machine.Pin.IN,machine.Pin.PULL_DOWN)#GPIO9 is physical pin 12
#LHS_Skully = Pin(13, machine.Pin.OUT)#GP13 is Pico pin 17
#RHS_Skully = Pin(14, machine.Pin.OUT)#GP14 is Pico pin 19
#RHS_Skully.value(0)
#LHS_Skully.value(0)
LHS_Skully = PWM(Pin(13))# physical pin17
RHS_Skully = PWM(Pin(14))# physical pin19
RHS_Skully2 = PWM(Pin(12))# physical pin16
LHS_Skully.freq(8) # 2 Hz is 500 msec period
RHS_Skully.freq(19) # 10 Hz is 100 msec period
RHS_Skully2.freq(19)# 10 Hz is 100 msec period
LHS_Skully.duty_u16(0)
RHS_Skully.duty_u16(0)
RHS_Skully2.duty_u16(0)
RavenHeadDuty=4875
CoffinLidServo = PWM(Pin(16))# physical pin21
CoffinLidServo.freq(50) # 50 Hz is 20 msec period
# 100% duty of PWM is 65535 counts
# 2 ms of 20 ms is 10% for full spd FWD 6553
# ( 1.5 ms / 20 ms ) * 65535 = 4875 for zero degrees
# 1 ms of 20 ms is full neg 3251 counts
CoffinLidServo.duty_u16(3251)
CoffinLidDuty=3300
RavenHeadServo = PWM(Pin(17))# physical pin22
RavenHeadServo.freq(50) # 50 Hz is 20 msec period
RavenHeadServo.duty_u16(4875)
RavenLeftWingServo = PWM(Pin(18))# physical pin23
RavenLeftWingServo.freq(50) # 50 Hz is 20 msec period
RavenLeftWingServo.duty_u16(4875)
RavenRightWingServo = PWM(Pin(19))# physical pin24
RavenRightWingServo.freq(50) # 50 Hz is 20 msec period
RavenRightWingServo.duty_u16(4875)
DFPlayerRelay = Pin(2, machine.Pin.OUT)#GP2 is Pico pin 4
DFPlayerRelay.value(0)
# Explicit Method
sda0=machine.Pin(4)
scl0=machine.Pin(5)
i2c0=machine.I2C(0,sda=sda0, scl=scl0, freq=1600000)#original setting 400 000
sda1=machine.Pin(6)
scl1=machine.Pin(7)
i2c1=machine.I2C(1,sda=sda1, scl=scl1, freq=1600000)#original setting 400 000
#print(i2c0.scan())
#print(i2c1.scan())
oled0 = SSD1306_I2C(128, 64, i2c0)
oled1 = SSD1306_I2C(128, 64, i2c1)
from neopixel import Neopixel
numpix = 2
pixels = Neopixel(numpix, 1, 22, "GRB") #arameters number of LEDs, state machine ID, GPIO number and mode (RGB or RGBW) in that order.
# strip = Neopixel(numpix, 0, 0, "GRBW")
#colors taking values between 0 and 255.
#red = (255, 0, 0)
#orange = (255, 50, 0)
#yellow = (255, 100, 0)
#green = (0, 255, 0)
#blue = (0, 0, 255)
#indigo = (100, 0, 90)
#violet = (200, 0, 100)
#colors_rgb = [red, orange, yellow, green, blue, indigo, violet]
#GPIO22 is pin29
pixels.set_pixel(1, (0, 0, 0))
pixels.set_pixel(0, (0, 0, 0))
pixels.show()
# Raspberry Pi logo as 32x32 bytearray
#buffer = bytearray(b"\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00|?\x00\x01\x86@\x80\x01\x01\x80\x80\x01\x11\x88\x80\x01\x05\xa0\x80\x00\x83\xc1\x00\x00C\xe3\x00\x00~\xfc\x00\x00L'\x00\x00\x9c\x11\x00\x00\xbf\xfd\x00\x00\xe1\x87\x00\x01\xc1\x83\x80\x02A\x82@\x02A\x82@\x02\xc1\xc2@\x02\xf6>\xc0\x01\xfc=\x80\x01\x18\x18\x80\x01\x88\x10\x80\x00\x8c!\x00\x00\x87\xf1\x00\x00\x7f\xf6\x00\x008\x1c\x00\x00\x0c \x00\x00\x03\xc0\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00")
# This buffer is te bloodshot eyeballinverse colors, wierd
#buffer = bytearray(b'\xff\xff\xff\xff\xff\xff\xe0\x07\xff\xff\xff\xff\xff\xff\x80\xff\xfb\xff\xff\xff\xfe\x00\x00?\xff\xff\xff\xfd\xf7\x80\xff\xfb\xfa_\xff\xf0\x00\x00\x07\xff\xff\xf7\xfaw\x80\xdf\xfd/\xf3\xff\xc0\x00\x00\x00\xff\xff\xdb\xfb\xd7\x80\xdf\xff\xff\xff\xff\x00\x00\x00\x00\x7f\xf9~\x7f\xef\x80\xe5\xff\xff\xff\xfc\x00\x00\x00\x00\x1f\xfb\xff\xb7\xff\x80\xfe\xbf\xff\xff\xf8\x00\x00\x00\x00\x07\xff\xff\xef\xff\x80\xff\xdf\xff\xff\xe0\x00\x00\x00\x00\x03\xfd\xff\xff\xff\x80\xff\xdf\xff\xff\xc0\x00\x00\x00\x00\x01\xfd\xff\xff\xff\x80\xff\xdf\xff\xff\x80\x00\x00\x00\x00\x00\xff\xff\xff\xff\x80\xff\xef\xff\xff\x00\x00\x00\x00\x00\x00\x7f\xff\xff\xff\x80\xff\xef\xff\xfe\x00\x00\x00\x00\x00\x00?\xff\xff\xff\x80\xff\xef\xff\xfc\x00\x00\x00\x00\x00\x00\x1f\xff\xff\xff\x80\xff\xf7\xff\xf8\x00\x00\x00\x00\x00\x00\x0f\xff\xff\xff\x80\xff\xfb\xff\xf8\x00\x00\x00\x00\x00\x00\x0f\xff\xff\xff\x80\xff\xfc\xff\xf0\x00\x00\x00\x00\x00\x00\x07\xff\xff\xff\x80\xff\xff\x7f\xe0\x00\x00\x00\x00\x00\x00\x03\xff\xff\xff\x80\xff\xff\xbf\xe0\x00\x00\x00\x00\x00\x00\x03\xff\xff\xff\x80\xff\xff\xff\xc0\x00\x00\x00\x80\x00\x00\x01\xff\xff\xff\x80\xff\xff\xff\xc0\x00\x00\x0f\xf8\x00\x00\x01\xff\xff\xff\x80\xff\xff\xff\xc0\x00\x00?\xfe\x00\x00\x01\xff\xff\xff\x80\xff\xff\xff\x80\x00\x00\x7f\xff\x00\x00\x00\xff\xff\xff\x80\xff\xff\xff\x80\x00\x00\xff\xff\xc0\x00\x00\xff\xff\xfc\x80\xff\xff\xff\x00\x00\x01\xff\xff\xc0\x00\x00\x7f\xff\xfd\x80\xff\xff\xff\x00\x00\x03\xff\xff\xe0\x00\x00\x7f\xff\xf3\x80\xff\xff\xff\x00\x00\x07\xff\xff\xf0\x00\x00\x7f\xfc\x8f\x80\xff\xff\xff\x00\x00\x07\xff\xff\xf0\x00\x00\x7f\xfb\xff\x80\xff\xff\xff\x00\x00\x07\xff\xff\xf8\x00\x00\x7f\xcf\xff\x80\xff\xff\xfe\x00\x00\x0f\xff\xff\xf8\x00\x00>?\xff\x80\xff\xff\xff\x00\x00\x0f\xff\xff\xf8\x00\x00}\xff\xff\x80\xff\xfc\xfe\x00\x00\x0f\xff\xff\xf8\x00\x00=\xff\xff\x80\xff\xff\xfe\x00\x00\x0f\xff\xff\xf8\x00\x00?\xff\xff\x80\xff\xfb\xff\x00\x00\x0f\xff\xff\xf8\x00\x00?\xff\xff\x80\xff\xf7\xfe\x00\x00\x0f\xff\xff\xf8\x00\x00?\xff\xff\x80\xff\xf7\xfe\x00\x00\x0f\xff\xff\xf8\x00\x00\x7f\xff\xff\x80\xff\xef\xff\x00\x00\x0f\xff\xff\xf8\x00\x00?\xff\xff\x80\xfco\xff\x00\x00\x0f\xff\xff\xf8\x00\x00\x7f\xff\xff\x80\xfb\x9f\xff\x00\x00\x07\xff\xff\xf0\x00\x00\x7f\xff\xff\x80\xef\xff\xff\x00\x00\x07\xff\xff\xf0\x00\x00\x7f\xff\xff\x80\xff\xff\xff\x00\x00\x03\xff\xff\xe0\x00\x00\x7f\xff\xff\x80\xdf\xff\xff\x80\x00\x03\xff\xff\xe0\x00\x00\x7f\xff\xff\x80\xbf\xff\xff\x80\x00\x01\xff\xff\xc0\x00\x00\xff\xff\xff\x80\xff\xff\xff\x80\x00\x00\xff\xff\x80\x00\x00\xff\xff\xff\x80\xff\xff\xff\xc0\x00\x00\x7f\xff\x00\x00\x01\xff\xff\xff\x80\xff\xff\xff\xc0\x00\x00\x1f\xfc\x00\x00\x01\xff\xff\xff\x80\xff\xff\xff\xc0\x00\x00\x07\xf0\x00\x00\x01\xff\xff\xff\x80\xff\xff\xff\xe0\x00\x00\x00\x00\x00\x00\x03\xff\xff\xff\x80\xff\xff\xff\xf0\x00\x00\x00\x00\x00\x00\x03\xff\xbf\xff\x80\xff\xff\xff\xf0\x00\x00\x00\x00\x00\x00\x07\xff\xdf\xff\x80\xff\xff\xff\xf8\x00\x00\x00\x00\x00\x00\x0f\xff\xff\xff\x80\xff\xff\x7f\xf8\x00\x00\x00\x00\x00\x00\x0f\xff\xf7\xff\x80\xff\xfe\xff\xfc\x00\x00\x00\x00\x00\x00\x1f\xff\xfb\xff\x80\xff\xff\xfb\xfe\x00\x00\x00\x00\x00\x00?\xff\xfd\xff\x80\xff\xcd\xed\xff\x00\x00\x00\x00\x00\x00\x7f\xff\xff\xff\x80\xff:\xef\xff\x80\x00\x00\x00\x00\x00\xff\xff\xff\x7f\x80\xff~\x7f\xff\xc0\x00\x00\x00\x00\x01\xff\xff\xff\xff\x80\xfe\xff\xbf\xff\xe0\x00\x00\x00\x00\x03\xff\xff\xff\xbf\x80\xfd\xff\xff\xff\xf8\x00\x00\x00\x00\x0f\xff\xff\xff\xdf\x80\xfb\xff\xff\xff\xfc\x00\x00\x00\x00\x1f\xff\xff\xff\xff\x80\xfb\xff\xff\xff\xff\x00\x00\x00\x00\x7f\xf7\xff\xff\xef\x80\xf7\xff\xff\xff\xff\x80\x00\x00\x00\xff\xfb\xff\xff\xff\x80\xf7\xff\xff\xff\xff\xf0\x00\x00\x07\xff\xfb\xff\xff\xf7\x80\xef\xff\xff\xff\xff\xfe\x00\x00?\xff\xfd\xff\xff\xff\x80\xadj\xaa\xaa\xaa\xab@\x00\xd5UYUUR\x80')
# Load the eyeball into the framebuffer (the image is 32x32)
buffer = bytearray(b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x0b\xe8\x00\x00\x00\x00\x02\x08\x00\x00\x04\x02\xa0\x00\x00\xff\xff\xc0\x00\x00\x00\x00\x80\x00 \x01H\x08\x00\x07\xff\xff\xf8\x00\x00$\x04(\x00 \x00\x02\x00\x00\x1f\xff\xff\xfe\x00\x02\x82\x80\x00\x00\x10\x00\x00\x00\x00\x7f\xff\xff\xff\x80\x04\x00H\x00\x00\x07\x80\x02\x00\x01\xff\xff\xff\xff\xe0\x00\x04\x10\x00\x00\x00 \x00\x00\x07\xff\xff\xff\xff\xf0\x02\x00\x00\x00\x00\x00 \x02\x00\x0f\xff\xff\xff\xff\xf8\x00\x02\x00\x00\x00\x00 \x00\x00\x1f\xff\xff\xff\xff\xfe\x00\x00\x00\x00\x00\x00\x10\x01\x00?\xff\xff\xff\xff\xff\x00\x04\x00\x00\x00\x00\x10\x00\x00\x7f\xff\xff\xff\xff\xff\x80\x00\x00\x00\x00\x00\x00\x00\x00\xff\xff\xff\xff\xff\xff\x80\x04\x00\x00\x00\x00\x08\x00\x01\xff\xff\xff\xff\xff\xff\xc0\x08\x00\x00\x00\x00\x08\x00\x03\xff\xff\xff\xff\xff\xff\xe0\x00\x00\x00\x00\x00\x04\x00\x03\xff\xff\xff\xff\xff\xff\xf0\x00\x00\x00\x00\x00\x03\x00\x07\xff\xff\xff\xff\xff\xff\xf0\x00\x00\x00\x00\x00\x00\x80\x07\xff\xff\xff\xff\xff\xff\xf8\x00\x00\x00\x00\x00\x00@\x0f\xff\xff\xff\xff\xff\xff\xfc\x00\x00\x00\x00\x00\x00\x00\x1f\xff\xff\xff\x7f\xff\xff\xfc\x00\x00\x00\x00\x00\x00\x00\x1f\xff\xff\xf0\x07\xff\xff\xfc\x00\x00\x00\x00\x00\x00\x00\x1f\xff\xff\xc0\x01\xff\xff\xfe\x00\x00\x00\x00\x00\x00\x00?\xff\xff\x80\x00\xff\xff\xfe\x00\x08\x01\x80\x00\x00\x00?\xff\xff\x00\x00\x7f\xff\xff\x00\x14\x02\x00\x00\x00\x00?\xff\xfe\x00\x00?\xff\xff\x00\x02\x0c\x00\x00\x00\x00\x7f\xff\xfc\x00\x00\x1f\xff\xff\x00\x02\xf0\x00\x00\x00\x00\x7f\xff\xfc\x00\x00\x1f\xff\xff\x00\x04\x00\x00\x00\x00\x00\x7f\xff\xf8\x00\x00\x0f\xff\xff\x000\x00\x00\x00\x00\x00\x7f\xff\xf8\x00\x00\x0f\xff\xff\x81\x80\x00\x00\x00\x00\x00\x7f\xff\xf8\x00\x00\x0f\xff\xff\x82\x00\x00\x00\x00\x03\x00\x7f\xff\xf8\x00\x00\x0f\xff\xff\x82\x00\x00\x00\x00\x00\x00\x7f\xff\xf8\x00\x00\x07\xff\xff\x80\x00\x00\x00\x00\x04\x00\x7f\xff\xf0\x00\x00\x0f\xff\xff\x80\x00\x00\x00\x00\x00\x00\x7f\xff\xf8\x00\x00\x0f\xff\xff\x80\x00\x00\x00\x00\x08\x00\x7f\xff\xf8\x00\x00\x0f\xff\xff\x00\x00\x00\x00\x00\x14\x00\x7f\xff\xf8\x00\x00\x0f\xff\xff\x80\x00\x00\x00\x03\x94\x00\x7f\xff\xf8\x00\x00\x0f\xff\xff\x00\x00\x00\x00\x04h\x00\x7f\xff\xfc\x00\x00\x1f\xff\xff\x00\x00\x00\x00\x10\x02\x00?\xff\xfc\x00\x00\x1f\xff\xff\x00\x00\x00\x00\x10\x00\xa0?\xff\xfe\x00\x00?\xff\xff\x00\x00\x00\x00 \x00\x08?\xff\xff\x00\x00\x7f\xff\xfe\x00\x00\x00\x00@\x00\x00?\xff\xff\x80\x00\xff\xff\xfe\x00\x00\x00\x00\x00\x00\x00\x1f\xff\xff\xc0\x01\xff\xff\xfe\x00\x00\x00\x00\x00\x00\x00\x1f\xff\xff\xf0\x07\xff\xff\xfc\x00@\x00\x00\x00\x00\x00\x0f\xff\xff\xfe\xbf\xff\xff\xfc\x00\x00\x00\x00\x00\x00\x00\x0f\xff\xff\xff\xff\xff\xff\xf8\x00@\x00\x00\x00\x00\x00\x07\xff\xff\xff\xff\xff\xff\xf8\x04\x00\x00\x00\x00\x00\x00\x07\xff\xff\xff\xff\xff\xff\xf0\x02@\x00\x00\x00\x00\x00\x03\xff\xff\xff\xff\xff\xff\xf0\x01\x00\x00\x00\x00\x00\x00\x01\xff\xff\xff\xff\xff\xff\xe0\x00\x80\x00\x00\x00\x00\x80\x01\xff\xff\xff\xff\xff\xff\xc0\x00`\x00\x00\x00\x01\x00\x00\xff\xff\xff\xff\xff\xff\x80\x00\x10\x00\x00\x00\x02\x0c\x00\x7f\xff\xff\xff\xff\xff\x00\x00\x08\x00\x00\x000\x02\x00?\xff\xff\xff\xff\xfe\x00\x00\x04\x00\x00\x00\xc7\x10\x00\x1f\xff\xff\xff\xff\xfc\x00\x00\x80\x00\x00\x00\x01\xa0\x00\x0f\xff\xff\xff\xff\xf8\x00\x00\x01\x00\x00\x01\x00 \x00\x03\xff\xff\xff\xff\xf0\x00\x00\xc0\x80\x00\x02\x00\x10\x00\x01\xff\xff\xff\xff\xc0\x08\x00\x14@\x00\x04\x00\x10\x00\x00\x7f\xff\xff\xff\x80\x05\x00\x00 \x00\x04\x00\x0c\x00\x00\x1f\xff\xff\xfe\x00\x06\x80\x00\x00\x00\x08\x00\x01\x00\x00\x07\xff\xff\xf0\x00\x02@\x00\x10\x00\x08\x00\x00\x00\x00\x00\x7f\xff\x80\x00\x02\x00\x00\x08\x00\x10\x00\x00\x00\x00\x00\x02\xa0\x00\x00\x04\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x08\x00\x00\x00\x00')
RoaRobLogo=bytearray(b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00$F#\x08A\x00\x00\x00\x00\x00\x00\x08$B!\x08 \x80\x00\x00\x00\x00\x00\x1e""!\x08 \x80\x00\x00\x00\x00\x00>""!\x00 \x80\x00\x00\x00\x00\x00>2"1\x0c \x80\x00\x00\x00\x00\x00>""1\x0c \x80\x00\x00\x00\x00\x00>&b!\x0c \x80\x00\x00\x00\x00\x00\x1c&b!\x0c!\x80\x00\x00\x00\x00\x00\x08fF#\x08a\x80\x00\x00\x00\x00\x00\x08dDb\x08A\x00\x00\x00\x00\x00\x00\x08\x00\x00\x00\x00\x00\x01\xf1\x00\x00\x00\x00\x08\x00\x00\x00\x00\x00\x03\x01\xe0\x00\x00\x00\x08\x00\x00\x00\x00\x00\x02p0\x00\x00\x00\x08\x00\x00\x00\x00\x00\x00\x98\xd0\x00\x00\x00\x08\x00\x00\x00\x01\x80\x00\x89`\x00\x00\x07\xc0\x00\x00\x00\x01\x80\x01\x8b \x00\x00\x07\xe0\x00\x00\x00\x01\x80\x01\x0e0\x00\x00\x0ep\x00\x00\x00\x01\x80\x01\x0e\x10\x00\x00\x0es\xe3\xf3\xf1\xf1\x98\xf1\x0e\x10\x00\x00\x0ew\xf7\xf3\xf9\xf9\xb9\xf9\x0e\x10\x00\x00\x0f\xe673\x1b\x99\xf3\x9d\x1e\xf0\x00\x00\x0f\xc663\x1b\x1d\xe3\xfd>\xf0\x00\x00\x0e\xe663\x1b\x1d\xf3\xf9\xba\xe0\x00\x00\x0evw3\x1b\x99\xb9\x80\xb9\xe0\x00\x00\x0ew\xe7\xf3\x19\xf9\x9d\xf8\x99\xc0\x00\x00\x063\xc3\xb3\x18\xf1\x88\xf8\xd0\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00`\x00\x00\x00\x00\x00\x0c\x00\x00\x10\x00\x00\x00\x00\x00\x00\x1f\x80\x0c\x00\x068\x00\x00\x00\xc0\x00\x00\x1f\xc0\x0c\x00\x06\x00\x00\x01\x81\xc0\x00\x00\x18\xc7\r\x83\x8f\x90\xf1\xe1\x81\xc0\x00\x00\x19\xcf\x8f\xcf\xcf\xb9\xfb\xe1\xe3\xc0\x00\x00\x1f\x9d\xcc\xee\xe6;\x97\x01\xbe\x80\x00\x00\x1f\x18\xcclf;\x03\x81\x8c\x80\x00\x00\x1b\x98\xcclf;\x03\xe1\x80\x80\x00\x00\x19\x98\xcc\xecf;\x80q\x80\x80\x00\x00\x19\xdf\xcf\xef\xe7\xbb\xfbq\x81\x80\x00\x00\x18\xcf\x8f\xc7\xc7\xb9\xf3\xe1\x81\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x83\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\xfe\x00\x00\x00\x03\xff\xff\xff\xff\xff\xff\xf0<\x00\x00\x00\x060\x00\x00\x00\x00\x03\x98\x00\x00\x00\x00\x0c\x18\x00\x00\x08\x00\x02\x0c\x00\x00\x00\x00\x08\x08\x00\x04\x08\x00\x02\x0c\x00\x00\x00\x00\x08\x08<4.<\x06\x04\x00\x00\x00\x00\x08\x08f%\xaaf\x02\x0c\x00\x00\x00\x00\x0c\x18CE*A\x02\x0c\x00\x00\x00\x00\x060\xc3<\xeeA\x01\x98\x00\x00\x00\x00\x03\xf0C\x00\x00A\x03\xf0\x00\x00\x00\x00\x00?b\x00\x00c\x7f\x00\x00\x00\x00\x00\x00\x01\xff\xff\xff\xff\xe0\x00\x00\x00\x00\x00\x00\x00\x10\x00\x00\x08\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00')
#PreviousblinkClosed=bytearray(b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00$\xaa\xa5UUUUJ\x95"\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x02\x80\x00$DB \x00@@\x08\x90\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00J\xb5V\xdbUUUV\xdbV\xabj\xaa\xd5\x00R\x88\x91$\x92I)"I)(\x92E$\x80\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x12$\x89$\x92D\x88\x88\x82\x04\x81\x10\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x88\x92I$\xa9URUT\x94@\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00')
blinkClosed=bytearray(b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x08\x00\x00\x00\x00\x00\x00\x00\x00\x08\x00\x00\x00\x00\x00\x02I$\x92I$\x92I$\xa0\x00\x00\x00\x00\x00\x05UUUUUUUU \x00\x00\x00\x00\x00\x10\x00\x00\x00\x00\x00\x00\x00\x00\x08\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00')
blink3qtrClosed=bytearray(b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x10\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\xfc\x00\x00\x1f\x80\x00\x00\x00\x00\x00\x00\x00\x00\x00\x0f\xf8\x00\x00\x0f\xf8\x00\x00\x00\x00\x00\x00\x00\x00\x00\x7f\xf8\x00\x00\x0f\xff\x00\x00\x00\x00\x00\x00\x00\x00\x03\xff\xf8\x00\x00\x0f\xff\xe0\x00\x00\x00\x00\x00\x00\x00\x0f\xff\xf8\x00\x00\x0f\xff\xfc\x00\x00\x00\x00\x00\x00\x00\x7f\xff\xf8\x00\x00\x07\xff\xff\x00\x00\x00\x00\x00\x00\x00\x7f\xff\xf0\x00\x00\x0f\xff\xff\x80\x00\x00\x00\x00\x00\x00\x7f\xff\xf8\x00\x00\x0f\xff\xff\x80\x00\x00\x00\x00\x00\x00\x7f\xff\xf8\x00\x00\x0f\xff\xff\x80\x00\x00\x00\x00\x00\x00\x01\x7f\xf8\x00\x00\x0f\xff@\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00')
blinkHalfwayOpen=bytearray(b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\n\xa8\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00_\xff\xff\xff@\x00\x00\x00\x00\x00\x00\x00\x00\x00\x17\xff\xff\xff\xff\xfe\x00\x00\x00\x00\x00\x00\x00\x00\x01\xff\xff\xff\x7f\xff\xff\xf0\x00\x00\x00\x00\x00\x00\x00\x1f\xff\xff\xf0\x07\xff\xff\xfc\x00\x00\x00\x00\x00\x00\x00\x1f\xff\xff\xc0\x01\xff\xff\xfe\x00\x00\x00\x00\x00\x00\x00?\xff\xff\x80\x00\xff\xff\xfe\x00\x00\x00\x00\x00\x00\x00?\xff\xff\x00\x00\x7f\xff\xff\x00\x00\x00\x00\x00\x00\x00?\xff\xfe\x00\x00?\xff\xff\x00\x00\x00\x00\x00\x00\x00?\xff\xfc\x00\x00\x1f\xff\xff\x00\x00\x00\x00\x00\x00\x00\x7f\xff\xfc\x00\x00\x1f\xff\xff\x00\x00\x00\x00\x00\x00\x00\x7f\xff\xf8\x00\x00\x0f\xff\xff\x00\x00\x00\x00\x00\x00\x00\x7f\xff\xf8\x00\x00\x0f\xff\xff\x80\x00\x00\x00\x00\x00\x00\x7f\xff\xf8\x00\x00\x0f\xff\xff\x80\x00\x00\x00\x00\x00\x00\x7f\xff\xf8\x00\x00\x0f\xff\xff\x80\x00\x00\x00\x00\x00\x00\x7f\xff\xf8\x00\x00\x07\xff\xff\x80\x00\x00\x00\x00\x00\x00\x7f\xff\xf8\x00\x00\x0f\xff\xff\x80\x00\x00\x00\x00\x00\x00\x7f\xff\xf8\x00\x00\x0f\xff\xff\x80\x00\x00\x00\x00\x00\x00\x7f\xff\xf8\x00\x00\x0f\xff\xff\x00\x00\x00\x00\x00\x00\x00\x7f\xff\xf8\x00\x00\x0f\xff\xff\x80\x00\x00\x00\x00\x00\x00\x7f\xff\xf8\x00\x00\x0f\xff\xff\x00\x00\x00\x00\x00\x00\x00\x7f\xff\xfc\x00\x00\x1f\xff\xff\x00\x00\x00\x00\x00\x00\x00?\xff\xfc\x00\x00\x1f\xff\xff\x00\x00\x00\x00\x00\x00\x00?\xff\xfe\x00\x00?\xff\xff\x00\x00\x00\x00\x00\x00\x00?\xff\xff\x00\x00\x7f\xff\xfe\x00\x00\x00\x00\x00\x00\x00?\xff\xff\x80\x00\xff\xff\xfe\x00\x00\x00\x00\x00\x00\x00\x1f\xff\xff\xc0\x01\xff\xff\xfe\x00\x00\x00\x00\x00\x00\x00\x0f\xff\xff\xf0\x07\xff\xff\xfc\x00\x00\x00\x00\x00\x00\x00\x00\xff\xff\xfe\xbf\xff\xff\xe0\x00\x00\x00\x00\x00\x00\x00\x00\x07\xff\xff\xff\xff\xfc\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x17\xff\xff\xfd\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00')
#e14logoSM=bytearray(b'\xff\xff\xff\xff\xff\xff\xff\xfe\xff\xff\xff\xff\xff\xff\xff\xfe\xff\xff\xff\xfa\x81\xff\xff\xfe\xff\xff\xff\x05Z\xff\xff\xfe\xff\xff\xff\xd4\xa5\xf5\x7f\xfe\xff\xff\xff\xeaR\x9b\x7f\xfe\xff\xff\xff\xe5*\xed\xbf\xfe\xff\xff\xfe\tI*\xff\xfe\xff\xff\xe0\n\xa5\xdb\x7f\xfe\xff\xff\x00\x8aTm\x7f\xfe\xff\xfe\x08\t*\xab_\xfe\xff\xfd\xc0J\xa5m\x7f\xfe\xff\xfc"\x05R\xb5\xbf\xfe\xff\xfa\x80\x14\x94\xaa\xdf\xfe\xff\xfa\x88\x85M^\x7f\xfe\xff\xf9\x00\nV\xa9\x1f\xfe\xff\xf4\x02E+t\xdf\xfe\xff\xf4HI]\xa8_\xfe\xff\xf0\x00\xa5UP/\xfe\xff\xe2\x01*m\xe9\x17\xfe\xff\xe8IR\xb0\x10\x17\xfe\xff\xa0\x02\x95@\x00O\xfe\xff@\x84\xa9\x00\x00\x07\xfe\xfeB\x12J\x00\x00\x0b\xfe\xf9\x08\n\xa8\x00\x00E\xfe\xf5@E \x00\x00\x02\xfe\xe4\x83\xba\xa2\x04\x00\x04\xfe\xd2\rV\x82\x02\x00\x02>\xea\x8a\x02\xa1\x04\x00\x02\x9e\xea\x14\x11\x82\x04\x00\x01^\xf2\x8c\x81B\x04\x02\x02\xa6\xf5\x18\x01\x81\x04\x02\x81\x1e\xf9\x14$\xc2\x02\x01\x02\xce\xfc\x17\xb5B\n\x02\x01>\xfd\x1a\xdb\x81\x00\x01\x01^\xfeH\x00\x02\x06\x02\x02>\xfe\x18\x00\x01\x01\x01\x01~\xff\x0c\x89\x02\x04\x02\x02\xfe\xfc\x94\x00\x02\x02\xd5b\xfe\xfe\x8c A\x00(\x81\xfe\xfd\n\x05\x02\x00\x02\x05\xfe\xfc\x8d\xda\x82\x00\x02\x05\xfe\xfdCm\x02\x00\x01\x05\xfe\xfa\x80\x00\x10\x00\x00\x08\xfe\xf9P \x80\x00\x00\x0b\xfe\xfaA\x04\x00\x00\x00(\xfe\xf9P\x00$\x00\x00\x15\xfe\xfa\xa8B\x00\x00\x01$\xfe\xfd\x14\x08\x01 \x04U\xfe\xffI\x00\x90\x02 \xa4\xfe\xff\xe4 \x04\x08\x01\x15\xfe\xff\xfd\x04 \x80\x84\xd3\xfe\xff\xfe\x80\x80 \x12/\xfe\xff\xfe\xa8\x02\x04\x0b\xff\xfe\xff\xffR\x10\x00\xb7\xff\xfe\xff\xffI\x00\x92\x8b\xff\xfe\xff\xff\xaa\xaa\no\xff\xfe\xff\xff\x94\xa5i\x1f\xff\xfe\xff\xff\xca\x92\x95_\xff\xfe\xff\xff\xd2^I\x7f\xff\xfe\xff\xff\xc9\xff\xd5?\xff\xfe\xff\xff\xf7\xff\xe8\xff\xff\xfe\xff\xff\xff\xff\xfe\xff\xff\xfe\xff\xff\xff\xff\xff\xff\xff\xfe')
E14logo=bytearray(b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x01[j\x00\x00\x05@\x01P\x00\x00\x00\x00\x00\x00\x00\x04\xad\xb5\x00\x00\n\x80\x00\xa0\x00\x00\x00\x00\x00\x00\x00\x12\xd6\xaa\xd0\x00\x02@\x02T\x00\x00\x00\x00\x00\x00\x00]umj\x00\n\x80\x01@\x00\x00\x00\x00\x00\x00\x00\xab\x96\xb7\xb4\x00\x05 \x00\xa8\x00\x00\x00\x00\x00\x00\x00\xedR\x94\xad\x00\x04\x80\x02P\x00\x00\x00\x00\x00\x00\x02\xb5\x08B\xb6\x00\n\x80\x01D\x00\x00\x00\x00\x00\x00\x01R \x00Z\x80\x02@\x00\xa8\x00\x00\x00\x00\x00\x00\x05\xd0\x00\x00+\x00\n\x90\x02P\x00\x00\x00\x00\x00\x00\x02\xa8\x00\x00\x15\x00\x05@\x01@\x00\x00\x00\x00\x00\x00\x05`\x00\x00\x16\xa0\x04\x80\x01(\x00\x00 \x00\x00\x00\x05\xa8\x00\x00\r\x80\n@\x04\xa0\x00\x01@\x00\x00\x00\n\xd0\x00\x00*\xa0\x05\x00\x01T\x00\x00\xa8\x00\x00\x00\x05@\x00\x00\x0b@\t@\x00\x90\x00\x02P\x00\x00\x00\x0b\xe0\x00\x00\r@\x05 \x02@\x00\x01 \x00\x00\x00\n\xa0\x00\x00\x16\xa0\n\x80\x01T\x00\x00\xa4\x00\x00\x00\x0bP\x00\x00\x0b@\x02@\x01P\x00\x01P\x00\x00\x00\n\xc0\x00\x00\n\xa0\n\x80\x04\xa0\x00\x00\x90\x00\x00\x00\rb"$\xab@\x05 \x01\x14\x00\x02@\x00\x00\x00\x07\xb5UR\x96\xa0\t@\x00\xd0\x00\x01P\x00\x00\x00\n\xaa\xaa\xadk@\x05\x00\x02 \x00\x00\xa8\x00\x00\x00\r\xb6\xdd\xd6\xbd\xa0\n\xa0\x01T\x00\x02@\x00\x00\x00\x06\xdbj\xbbU@\x02\x00\x00\xa0\x00\x010\x00\x00\x00\x0bQ\x15D\xa5\x00\n\xa0\x02P\x00\x00\xa2\x00\x00\x00\rD\x00\x00\x00\x00\x05\x00\x00\xaa\x00\x02\x90\x00\x00\x00\x06\xe0\x00\x00\x00\x00\t@\x01@\x00\x00\xa0\x00\x00\x00\x0b@\x00\x00\x00\x00\x05 \x00\xa8\x00\x02P\x00\x00\x00\rP\x00\x00\x00\x00\n\x80\x00T\x00\x01H\x00\x00\x00\x05\xa0\x00\x00\x00\x00\x04\x80\x01J\x00\x00\xa0\x00\x00\x00\rP\x00\x00\x00\x00\n@\x00)\x00\x02P\x00\x00\x00\x06\xc0\x00\x00\x00\x00\x02\x80\x00\xa4\xa0\x01$\x90\x00\x00\x0b`\x00\x00\x00\x00\n\xa0\x00*J\xa9R@\x00\x00\x05\xa0\x00\x00\x00\x00\x05\x00\x00\x15)\x14\xa9(\x00\x00\n\xa8\x00\x00\x00\x00\x12\xa0\x00B\xa5J\x95P\x00\x00\x05\xd0\x00\x00\x00\x00\x04\x80\x00\tURJ\x88\x00\x00\x02\xa0\x00\x00\x00\x00\n@\x00\x00$\xaa\xa4@\x00\x00\x05h\x00\x00\x00\x00\x05\x00\x00\x02\x89\x01Q\x00\x00\x00\x02\xb0\x00\x00\x00\x00\t@\x00\x00\x00*H\x00\x00\x00\x02\xd5\x00\x00\x92\x00\x05 \x00\x00\x00\x00\xa0\x00\x00\x00\x01m$\x94H\x00\n\x80\x00\x00\x00\x01(\x00\x00\x00\x00\xb6\xaaSV\x00\x04\x80\x00\x00\x00\x00\xa0\x00\x00\x00\x01Z\xd5\xadZ\x00\x12\xa0\x00\x00\x00\x02\x90\x00\x00\x00\x00KZ\xb5\xaa\x00\x05\x00\x00\x00\x00\x00\xa4\x00\x00\x00\x00*\xad\xd6\xa9\x00\t@\x00\x00\x00\x01 \x00\x00\x00\x00\x01j\xa9\x10\x00\x02\x00\x00\x00\x00\x00H\x00\x00\x00\x00\x00*\xaa@\x00\x00 \x00\x00\x00\x01\x00\x00\x00\x00\x00\x01\x00\x00\x00\x00\x08\x80\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x01\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00')
# TRY1 spinnerPos1=bytearray(b'\xf8\x01\xff\xc0?\x81\xf8\x1f\x07\xe0\x1f\xfe\x00\x00\x00\x00\xfc\x01\xff\xc0?\xc0\xf8?\x07\xe0?\xf8\x00\x00\x00\x00\xfe\x00\xff\xe0\x1f\xc0\xfc\x1e\x0f\xc0\x7f\xe0\x00\x00\x00\x00\xfe\x00\x7f\xe0\x1f\xc0\xf8>\x0f\x80\xff\x80\x00\x00\xbf\xd4\xff\x00?\xf0\x0f\xe0|\x1e\x0f\x81\xff\x00\x00_\xff\xff\xff\x80?\xf8\x0f\xe0|>\x1f\x03\xfc\x00\x07\xff\xff\xff\xff\x80\x1f\xf8\x07\xf0|\x1e\x1f\x07\xf8\x00?\xff\xff\xff\xff\xc0\x0f\xfc\x03\xf0<<\x1e\x0f\xe0\x01\xff\xff\xff\xff\xff\xe0\x07\xfe\x03\xf8>\x1e>\x0f\xc0\x0f\xff\xff\xff\xff\xff\xf0\x03\xff\x01\xf8>\x1c<\x1f\x80?\xff\xff\xff\xff\xff\xf8\x01\xff\x00\xfc\x1e\x1c<?\x00\xff\xff\xff\xff\xff\xff\xf8\x00\xff\x80\xfc\x1e\x1c8|\x03\xff\xff\xff\xff\xff\xff\xfe\x00\x7f\xc0~\x0e\x1cx|\x07\xff\xff\xb7\xff\xff\x7f\xfe\x00?\xe0?\x0f\x1cp\xf0\x1f\xff\xc0\x00\x03\xff?\xff\x80\x1f\xf0\x1f\x07\x1cq\xf0\x7f\xf8\x00\x00\x00\x1f\x1f\xff\x80\x0f\xf8\x0f\x87\x8cq\xc0\xff\xc0\x00\x00\x00\x03\x0f\xff\xe0\x07\xfc\x07\xc3\x8cc\xc1\xfe\x00\x00\x00\x00\x00\x07\xff\xf0\x01\xfe\x03\xc3\x8c\xe3\x87\xf0\x00\x00\x00\x00\x00\x03\xff\xf8\x00\xff\x81\xe1\xceg\x0f\xc0\x00\x00\x00\x00\x00\x00\xff\xfe\x00\x7f\xc0\xf1\xcc\xc6\x1f\x00\x00U@\x00\x00\x00\x7f\xff\x00\x1f\xe0x\xc6N<\x00?\xff\xff\x80\x00\x00\x1f\xff\xc0\x0f\xf0<f\xccx\x07\xff\xff\xff\xfc\x00\x00\x0f\xff\xe0\x03\xfc\x1ef\xd8\xe0?\xff\xff\xff\xff\xc0\x00\x03\xff\xf8\x00\xff\x072\x99\x81\xff\xff\xff\xff\xff\xf8\x80\x00\xff\xfe\x00?\x83\x9a\xb3\x0f\xff\xff\xff\xff\xff\xfe\xe0\x00\x7f\xff\x80\x0f\xe1\xca\xa6?\xe8\x00_\xff\xff\xff\xf0\x00\x0f\xff\xe0\x01\xf8e\xa8\xfc\x00\x00\x01\xff\xff\xff\xfc\x00\x03\xff\xfc\x00~4\x93\xc0\x00\x00\x00\x0f\xff\xff\xfe\x00\x00\xff\xff\x80\x0f\xcbn\x00\x00\x00\x00\x01\xff\xff\xff\x80\x00\x1f\xff\xf8\x00\xb5 \xbf\xff\x80\x00\x00?\xff\xff\xe0\x00\x03\xff\xff\xd0\x05_\xff\xff\xfe\x00\x00\x0f\xff\xff\xf8\x00\x00?\xff\xff\xfa\xa0\x02\xff\xff\xe0\x00\x03\xff\xff\xff\xc0\x00\x00\x00\x00uY\xf8\x00\xff\xff\x80\x00?\xff\xff\xfc\x00\x00\x00\x03\xca\xa4?\x00\x1f\xff\xe0\x00\x1f\xff\xff\xff\xc0\x00\x00\x7f\x13S\x0f\xc0\x03\xff\xfc\x00\x07\xff\xff\xff\xffI_\xfceY\xc3\xf8\x00\xff\xfe\x00\x03?\xff\xff\xff\xff\xff\xe0\xedL\xe0\xfe\x00?\xff\x80\x01\x0f\xff\xff\xff\xff\xff\x81\x89$p\x7f\x80\x0f\xff\xe0\x00\x01\xff\xff\xff\xff\xfc\x07\x99&<\x1f\xe0\x03\xff\xf8\x00\x00\x1f\xff\xff\xff\xc0\x1f;3\x1e\x0f\xf0\x01\xff\xfc\x00\x00\x00\xff\xff\xf4\x00<33\x8f\x03\xfc\x00\x7f\xff\x00\x00\x00\x00\x00\x00\x00\xf8s3\x87\x81\xff\x00?\xff\x80\x00\x00\x00\x00\x00\x03\xf0\xe31\xc7\xc0\xff\x80\x0f\xff\xc0\x00\x00\x00\x00\x00\x1f\xe1\xe79\xc3\xe0\x7f\xc0\x07\xff\xf0\x00\x00\x00\x00\x00\x7f\xc3\xc68\xe1\xf0\x1f\xf0\x03\xff\xf8\xe0\x00\x00\x00\x03\xff\x03\x878\xe0\xf8\x0f\xf8\x01\xff\xfc\xfe\x00\x00\x00?\xfe\x07\x8e8\xf0\xfc\x0f\xfc\x00\xff\xfe\xff\xf0\x00\x17\xff\xf8\x0f\x0e8p|\x03\xfe\x00\x7f\xff\xff\xff\xff\xff\xff\xe0\x1f\x1e8x>\x03\xff\x00?\xff\xff\xff\xff\xff\xff\xc0>\x1e<x?\x01\xff\x80\x1f\xff\xff\xff\xff\xff\xff\x00\xfc\x1c8<\x1f\x80\xff\xc0\x0f\xff\xff\xff\xff\xff\xfc\x01\xf8<<<\x1f\xc0\x7f\xe0\x07\xff\xff\xff\xff\xff\xe0\x03\xf8<<>\x0f\xc0?\xf0\x03\xff\xff\xff\xff\xff\x80\x07\xf0|<>\x0f\xe0\x1f\xf8\x01\xff\xff\xff\xff\xfc\x00\x1f\xe0x<>\x07\xf0\x1f\xf8\x01\xff\xff\xff\xff\xc0\x00?\xc0\xf8|\x1f\x07\xf0\x0f\xfc\x00\xff\xff\xff\xf4\x00\x00\xff\x81\xf8<\x1f\x03\xf8\x07\xfe\x00\x7f\x05P\x00\x00\x01\xff\x01\xf0|\x1f\x03\xf8\x07\xff\x00\x7f\x00\x00\x00\x00\x07\xfe\x03\xf0|\x1f\x81\xfc\x03\xff\x00?\x00\x00\x00\x00\x1f\xfc\x03\xe0|\x1f\x81\xfc\x03\xff\x80\x1f\x00\x00\x00\x00\x7f\xf8\x07\xe0|\x1f\x81\xfe\x01\xff\xc0\x1f\x00\x00\x00\x03\xff\xf0\x0f\xe0\xfc\x1f\x80\xff\x01\xff\xc0\x0f\x00\x00\x00\x0f\xff\xe0\x1f\xc0\xfc\x0f\xc0\xff\x00\xff\xe0\x0f\x00\x00\x00\xff\xff\xc0\x1f\xc0\xfc\x1f\xc0\xff\x00\xff\xf0\x07')
#Pos1Try2
spinnerPos1=bytearray(b"\xfc\x00\xff\xe0\x1f\xe0|\x1f\x83\xf0\x1f\xfc\x00\x00\x00\x00\xff\x00\xff\xf0\x0f\xe0|\x1f\x83\xe0?\xf0\x00\x00\x00\x00\xfe\x00\x7f\xf8\x0f\xe0|\x1f\x83\xe0\x7f\xc0\x00\x03\xff\xff\xff\x00?\xf8\x07\xf0~\x1f\x87\xc0\xff\x80\x00\x7f\xff\xff\xff\x80\x1f\xfc\x03\xf0>\x1f\x07\xc1\xfe\x00\x07\xff\xff\xff\xff\xc0\x0f\xfe\x03\xf8>\x1f\x87\x83\xf8\x00?\xff\xff\xff\xff\xc0\x07\xfe\x01\xf8\x1e\x0e\x0f\x83\xf0\x01\xff\xff\xff\xff\xff\xe0\x03\xff\x01\xfc\x1e\x0e\x0f\x07\xe0\x07\xff\xff\xff\xff\xff\xf0\x01\xff\x80\xfc\x0f\x0e\x0f\x0f\xc0\x1f\xff\xff\xff\xff\xff\xf8\x00\xff\xc0~\x0f\x0e\x1e\x1f\x80\x7f\xff\xff\xff\xff\xff\xfc\x00\x7f\xe0?\x0f\x1e\x1e\x1e\x01\xff\xff\xdb\xbf\xff\xff\xfe\x00\x1f\xf0\x1f\x07\x8e\x1c<\x07\xff\xf8\x00\x01\xff\x7f\xff\x80\x1f\xf8\x1f\x87\x8e\x1c|\x1f\xff\x00\x00\x00\r\x1f\xff\x80\x07\xfc\x0f\xc3\x8e\x18x\x7f\xf0\x00\x00\x00\x00\x1f\xff\xc0\x03\xfe\x03\xc3\xc6\x18\xe0\xff\x80\x00\x00\x00\x00\x07\xff\xf0\x01\xff\x03\xe1\xc69\xe3\xfc\x00\x00\x00\x00\x00\x01\xff\xfc\x00\x7f\x81\xf8\xc69\x83\xe8\x00\x00\x00\x00\x00\x01\xff\xff\x00?\xe0\xf8\xe61\x8f\xa0\x01$\x91\x00\x00\x00\x7f\xff@\x0f\xe08f\xb3\x8f\x00'\xff\xff\xe4\x00\x00\x1f\xff\xc0\x07\xfc\x1e33<\x01\xff\xff\xff\xff\x80\x00\x1f\xff\xf0\x01\xfc\x0e3\xa68\x17\xff\xff\xff\xff\xf0\x00\x03\xff\xfa\x00\xbf\x83\x9b\xac\xe0\xff\xff\xff\xff\xff\xfe\xc0\x00\xff\xfe\x80/\xc3\x89\xa4\x83\xff\xf7\xff\xff\xff\xff\xc0\x00?\xff\xa0\x0b\xf0m\xa9\x9f\xad\x00-\xff\xff\xff\xf0\x00\x0f\xff\xf4\x00\xfcU6}\x00\x00\x00_\xff\xff\xfc\x00\x01\xff\xfd\x00/*\xb1P\x00\x00\x00\x02\xff\xff\xfe\x00\x00_\xff\xd0\x05\xda\xdd\x02\xaa\x00\x00\x00/\xff\xff\x80\x00\x17\xff\xfd@c%_\xff\xd5\x00\x00\x0b\xff\xff\xe0\x00\x01\x7f\xff\xea\x9e\xa2\xd7\xff\xff@\x00\x02\xff\xff\xfa\x00\x00\x15\xff\xff\xe6\xb2\x01_\xff\xfa\x00\x00\xbf\xff\xfe\x80\x00\x00\xaa\xaa\x95+\xd4\x02\xff\xfe\x80\x00/\xff\xff\xd0\x00\x00\x00\x00\xaa\xa8]\x00/\xff\xe8\x00\x0b\xff\xff\xfe\x80\x00\x00\x0b\xc9\xcf\x17\xc0\x07\xff\xfe\x00\x03\xff\xff\xff\xd4\x00\x01_\x1a\xb1\xc3\xf8\x00\xff\xff@\x00\xff\xff\xff\xff\xad_\xf8vVp\xfe\x00?\xff\xe0\x00/\xff\xff\xff\xff\xff\xe0\xe4R8?\xc0\x07\xff\xf8\x00\x0b\xff\xff\xff\xff\xff\x03\xcc\xbb\x9e\x0f\xe0\x03\xff\xfe\x00\x01\x7f\xff\xff\xff\xf0\x07\x89I\x8e\x07\xf8\x00\xff\xfe\x80\x80\x0b\xff\xff\xff \x1f\x19\xcc\xc7\x81\xfe\x00?\xff\x80\x00\x00Iu\x10\x00\xfc9\xcc\xe7\xc0\xff\x80\x0f\xff\xe0\x00\x00\x00\x00\x00\x01xs\xcca\xf0?\xc0\x03\xff\xf8\x00\x00\x00\x00\x00\x07\xf0\xf3\xccp\xf0\x1f\xe0\x01\xff\xfc\x00\x00\x00\x00\x00?\xe0\xe3\x8cx\xfc\x1f\xf8\x00\xff\xfc\x80\x00\x00\x00\x01\xff\x81\xc3\x8e8|\x07\xfc\x00?\xff\xfc\x00\x00\x00\x1f\xff\x03\xc7\x8e<>\x03\xfe\x00\x1f\xff\xff\x80\x00\x01\xef\xfc\x07\x87\x8e<\x1f\x01\xff\x00\x0f\xff\xff\xff\xff\xff\xff\xf8\x0f\x8f\x8e\x1c\x1f\x80\xff\xc0\x07\xff\xff\xff\xff\xff\xff\xe0\x1f\x0f\x0e\x1e\x0f\xc0\xff\xd0\x03\xff\xff\xff\xff\xff\xff\x80~\x0e\x0e\x1e\x0f\xc0?\xf8\x01\xff\xff\xff\xef\xff\xfe\x00|\x1e\x0e\x1f\x07\xe0\x1f\xf8\x01\xff\xff\xff\xff\xff\xf8\x01\xfc\x1e\x0f\x0f\x03\xf0\x1f\xfc\x00\xff\xff\xff\xff\xff\xc0\x03\xf8<\x1f\x0f\x83\xf8\x0f\xfe\x00\x7f\xff\xff\x7f\xfe\x00\x07\xf0|\x0f\x0f\x81\xf8\x07\xff\x00=\xff\xff\xff\xe0\x00\x1f\xe0|\x1f\x0f\x81\xfc\x03\xff\x80\x1f\xff\xff\xfe\x00\x00?\xc0\xf8\x1f\x07\xc1\xfc\x03\xff\xc0\x1f\x0b\xfa\x00\x00\x00\xff\x80\xf8\x1f\x07\xc0\xfe\x01\xff\xc0\x0f\x00\x00\x00\x00\x03\xff\x01\xf8\x1f\x07\xc0\xff\x00\xff\xe0\x07\x00\x00\x00\x00\x0f\xfe\x03\xf0\x1f\x07\xe0\x7f\x00\xff\xf0\x07\x00\x00\x00\x00?\xfc\x03\xf0?\x07\xe0\x7f\x80\x7f\xf0\x03\x01\x00\x00\x00\xff\xf8\x07\xf0?\x07\xe0\x7f\x80\x7f\xf8\x03\x00\x00\x00\x07\xff\xf0\x0f\xe0>\x07\xe0?\xc0?\xfc!\x00\x00\x00\x0f\xff\xf0\x0f\xe0?\x07\xf0?\xc0?\xfc!\x00\x00\x00\x7f\xff\xe0\x0f\xe0>\x07\xf0?\xc0?\xfc\x01\x00@\x0b\xff\xff\x80?\xc0~\x07\xf0?\xc0\x1f\xfe@")
#Try1 spinnerPos2=bytearray(b'\xf8\x03\xff\x80\x7f\x81\xf8\x1f\x03\xf0\x0f\xff\x80\x00\x00\x00\xf8\x01\xff\xc0?\x81\xf8?\x07\xe0\x1f\xfe\x00\x00\x00\x00\xfc\x01\xff\xc0?\xc0\xf8\x1f\x07\xe0?\xf8\x00\x00\x00\x00\xfe\x00\xff\xe0\x1f\xc0\xfc>\x0f\xc0\x7f\xe0\x00\x00\x00\x00\xfe\x00\x7f\xe0\x1f\xc0\xf8\x1e\x0f\x80\xff\x80\x00\x00\xbf\xd4\xff\x00?\xf0\x0f\xe0|>\x0f\x81\xff\x00\x00_\xff\xff\xff\x80?\xf8\x0f\xe0|\x1e\x1f\x03\xfc\x00\x07\xff\xff\xff\xff\x80\x1f\xf8\x07\xf0|>\x1f\x07\xf8\x00?\xff\xff\xff\xff\xc0\x0f\xfc\x03\xf0<\x1c\x1e\x0f\xe0\x01\xff\xff\xff\xff\xff\xe0\x07\xfe\x03\xf8>\x1e>\x0f\xc0\x0f\xff\xff\xff\xff\xff\xf0\x03\xff\x01\xf8>\x1c<\x1f\x80?\xff\xff\xff\xff\xff\xf8\x01\xff\x00\xfc\x1e\x1c<?\x00\xff\xff\xff\xff\xff\xff\xf8\x00\xff\x80\xfc\x1e\x1c8|\x03\xff\xff\xff\xff\xff\xff\xfe\x00\x7f\xc0~\x0f\x1cx|\x07\xff\xff\xb7\xff\xff\x7f\xfe\x00?\xe0?\x0f\x1cp\xf0\x1f\xff\xc0\x00\x03\xff?\xff\x80\x1f\xf0\x1f\x07\x1cq\xf0\x7f\xf8\x00\x00\x00\x1f\x1f\xff\x80\x0f\xf8\x0f\x87\x0cq\xc0\xff\xc0\x00\x00\x00\x03\x0f\xff\xe0\x07\xfc\x07\xc3\x8cc\xc1\xfe\x00\x00\x00\x00\x00\x07\xff\xf0\x01\xfe\x03\xc3\x8c\xe3\x87\xf0\x00\x00\x00\x00\x00\x03\xff\xf8\x00\xff\x81\xe1\xceg\x0f\xc0\x00\x00\x00\x00\x00\x00\xff\xfe\x00\x7f\xc0\xf1\xcc\xc6\x1f\x00\x00U@\x00\x00\x00\x7f\xff\x00\x1f\xe0x\xc6N<\x00?\xff\xff\x80\x00\x00\x1f\xff\xc0\x0f\xf0<f\xccx\x07\xff\xff\xff\xfc\x00\x00\x0f\xff\xe0\x03\xfc\x1ef\xd8\xe0?\xff\xff\xff\xff\xc0\x00\x03\xff\xf8\x00\xff\x072\x99\x81\xff\xff\xff\xff\xff\xf8\x80\x00\xff\xfe\x00?\x83\x9a\xb3\x0f\xff\xff\xff\xff\xff\xfe\xe0\x00\x7f\xff\x80\x0f\xe1\xca\xa6?\xf0\x00_\xff\xff\xff\xf0\x00\x0f\xff\xe0\x01\xf8e\xa8\xfc\x00\x00\x01\xff\xff\xff\xfc\x00\x03\xff\xfc\x00~5S\xc0\x00\x00\x00\x0f\xff\xff\xfe\x00\x00\xff\xff\x80\x0f\xcaN\x00\x00\x00\x00\x01\xff\xff\xff\x80\x00\x1f\xff\xf8\x00\xb5\xb0\xbf\xff\xa0\x00\x00?\xff\xff\xe0\x00\x03\xff\xff\xe0\x05_\xff\xff\xfe\x00\x00\x0f\xff\xff\xff\x00\x00\x00\xbf\xfa\n\xaf\x80\x0f\xff\xfc\x00\x00\xff\xff\xff\xc0\x00\x00\x00\x00uP\xf8\x00\xff\xff\x80\x00?\xff\xff\xfc\x00\x00\x00\x03\xcal?\x00\x1f\xff\xe0\x00\x1f\xff\xff\xff\xc0\x00\x00\x7f\x13S\x0f\xc0\x03\xff\xfc\x00\x07\xff\xff\xff\xffI_\xfceY\xc3\xf8\x00\xff\xfe\x00\x03?\xff\xff\xff\xff\xff\xe0\xedL\xe0\xfe\x00?\xff\x80\x01\x0f\xff\xff\xff\xff\xff\x81\x89$p\x7f\x80\x0f\xff\xe0\x00\x01\xff\xff\xff\xff\xfc\x07\x99&<\x1f\xe0\x03\xff\xf8\x00\x00\x1f\xff\xff\xff\xc0\x1f;3\x1e\x0f\xf0\x01\xff\xfc\x00\x00\x00\xff\xff\xf4\x00<33\x8f\x03\xfc\x00\x7f\xff\x00\x00\x00\x00\x00\x00\x00\xf8s3\x87\x81\xff\x00?\xff\x80\x00\x00\x00\x00\x00\x03\xf0\xe31\xc7\xc0\xff\x80\x0f\xff\xc0\x00\x00\x00\x00\x00\x1f\xe1\xe79\xc3\xe0\x7f\xc0\x07\xff\xf0\x00\x00\x00\x00\x00\x7f\xc3\xc68\xe1\xf0\x1f\xf0\x03\xff\xf8\xe0\x00\x00\x00\x03\xff\x03\x878\xe0\xf8\x0f\xf8\x01\xff\xfc\xfe\x00\x00\x00?\xfe\x07\x8e8\xf0\xfc\x0f\xfc\x00\xff\xfe\xff\xf0\x00\x17\xff\xf8\x0f\x0e8p|\x03\xfe\x00\x7f\xff\xff\xff\xff\xff\xff\xe0\x1f\x1e8x>\x03\xff\x00?\xff\xff\xff\xff\xff\xff\xc0>\x1e<x?\x01\xff\x80\x1f\xff\xff\xff\xff\xff\xff\x00\xfc\x1c8<\x1f\x80\xff\xc0\x0f\xff\xff\xff\xff\xff\xfc\x01\xf8<<<\x1f\xc0\x7f\xe0\x07\xff\xff\xff\xff\xff\xe0\x03\xf8<<>\x0f\xc0?\xf0\x03\xff\xff\xff\xff\xff\x80\x07\xf0|<>\x0f\xe0\x1f\xf8\x03\xff\xff\xff\xff\xfc\x00\x1f\xe0x<>\x07\xf0\x1f\xf8\x01\xff\xff\xff\xff\xc0\x00?\xc0\xf8|\x1f\x07\xf0\x0f\xfc\x00\xff\xff\xff\xf4\x00\x00\xff\x81\xf8<\x1f\x03\xf8\x07\xfe\x00\x7f\x05P\x00\x00\x01\xff\x01\xf0|\x1f\x03\xf8\x07\xff\x00\x7f\x00\x00\x00\x00\x07\xfe\x03\xf0|\x1f\x81\xfc\x03\xff\x00?\x00\x00\x00\x00\x1f\xfc\x03\xe0|\x1f\x81\xfc\x03\xff\x80\x1f\x00\x00\x00\x00\x7f\xf8\x07\xe0|\x1f\x81\xfe\x01\xff\xc0\x1f\x00\x00\x00\x03\xff\xf0\x0f\xe0\xfc\x1f\x80\xff\x01\xff\xc0\x0f\x00\x00\x00\x0f\xff\xe0\x1f\xc0\xfc\x0f\xc0\xff\x00\xff\xe0\x0f')
# next line is Pos2 try 2
spinnerPos2=bytearray(b'\x07\xff\x80?\xe0?\x07\xc1\xf8\x1f\x80\x1f\xff\xff\xff\xff\x03\xff\xc0\x1f\xf0?\x83\xe0\xf0\x7f\x00\x7f\xff\xff\xff\xff\x03\xff\xe0\x0f\xf0\x1f\x83\xc1\xf0~\x00\xff\xff\xff\xff\xff\x01\xff\xf0\x07\xf8\x0f\x81\xe0\xe0\xfc\x03\xff\xfe\x00\x00\x01\x00\xff\xf0\x07\xf8\x0f\xc3\xc1\xf0\xfc\x0f\xff\xe0\x00\x00\x00\x00\x7f\xf8\x03\xfc\x0f\xc3\xe1\xe1\xf0\x1f\xff\x00\x00\x00\x00\x00?\xfc\x01\xfe\x07\xc1\xc3\xc1\xf0?\xf8\x00\x00\x00\x00\x00\x1f\xfe\x00\xff\x03\xc1\xe1\xc3\xc0\xff\xc0\x00\x00\x00\x00\x80\x0f\xff\x00\xff\x03\xf0\xe3\xe3\xe0\xff\x00\x00\x00\x00\x00\xc0\x07\xff\x80?\x81\xe1\xe1\x87\x81\xfc\x00\x00\x00\x00\x00\xe0\x03\xff\xc0?\xc1\xf0\xf3\xc7\x07\xf8\x00\x03\xff\xff\x80\xf0\x01\xff\xe0\x1f\xc0\xf8a\x87\x07\xe0\x00\xff\xff\xff\xfe\xf0\x00\xff\xf0\x0f\xf0x\xf3\xce\x1f\xc0\x07\xff\xff\xff\xff\xfc\x00\x7f\xf8\x03\xf0xa\x8e?\x00\x7f\xff\xff\xff\xff\xfe\x00\x1f\xfc\x01\xf8\x1e;\x9c|\x01\xff\xff\xff\xff\xff\xff\x00\x0f\xff\x00\xfe\x1cq\x0c\xf0\x0f\xff\xff\xff\xff\xff\xff\x80\x07\xff\x00~\x0f\x1b\x98`?\xff\xff\xff\xff\xff\xff\xc0\x01\xff\xc0?\x0f11\xe1\xff\xff@\xbf\xff\xff\xff\xf0\x00\xff\xf0\x0f\xc3\x1b\x9b\x83\xff\x00\x00\x00\x7f\xff\xff\xf8\x00?\xf8\x07\xc3\xcc#\x0f\xf0\x00\x00\x00\x07\xff\xff\xfc\x00\x0f\xfe\x01\xf0\x95\xb6?\x80\x00\x00\x00\x00\xff\xff\xff\x00\x03\xff\x80\xf8\xc8\xac|\x00\x00\x00\x00\x00\x1f\xff\xff\xc0\x00\xff\xe0>f\xa9\xe0\x00\x00\x00\x00\x00\x07\x7f\xff\xf0\x00?\xf8\x0f9S\x80?\xff\xfc\x00\x00\x01?\xff\xf8\x00\x07\xff\x01\x8b&\x07\xff\xff\xff\xe0\x00\x00\x0f\xff\xff\x00\x00\xff\xe0\xf5\x98\x7f\xff\xff\xff\xfe\x00\x00\x03\xff\xff\xc0\x00\x0f\xfe\x1ac\xfd_\xff\xff\xff\xc0\x00\x00\xff\xff\xfc\x00\x00\x7f\xe1\xbc\x00\x00\x0f\xff\xff\xf8\x00\x00?\xff\xff\x80\x00\x00)E\x00\x00\x00\xff\xff\xfe\x00\x00\x07\xff\xff\xfc\x00\x00=a\xff\x80\x00\x0f\xff\xff\x80\x00\x00\xff\xff\xff\xff\xff\xc5\x1e\x1f\xfc\x00\x01\xff\xff\xe0\x00\x00\x1f\xff\xff\xff\xfe4c\x81\xff\xc0\x00?\xff\xf8\x80\x00\x01\xff\xff\xff\xe0kX\xe0?\xf8\x00\x0f\xff\xfe\xc0\x00\x00\x07\xff\xfc\x01\xca\xcex\x0f\xfe\x00\x03\xff\xff\xf8\x00\x00\x00\x00\x00\x07\x12S\x1e\x03\xff\x80\x00\xff\xff\xfe\x00\x00\x00\x00\x00>;S\x1f\x80\xff\xf0\x00\x7f\xff\xff\xc0\x00\x00\x00\x01\xf8d\x88\xc3\xe0?\xfc\x00\x1f\xff\xff\xf8\x00\x00\x00\x0f\xf0\xc6\x9d\xc1\xf0\x0f\xfe\x00\x0f\xff\xff\xff\xc0\x00\x01\xff\xc1\xecLp\xfc\x03\xff\x80\x03\xff\xff\xff\xff\xff\xff\xff\x07\x8c\xccx~\x01\xff\xc0\x01\xff\xff\xff\xff\xff\xff\xfc\x0f\x18\xc68\x7f\x00\x7f\xf0\x00\xff\xff\xff\xff\xff\xff\xf0\x1e,\xef<\x1f\x80?\xf8\x00\x7f\xff\xff\xff\xff\xff\xc0<9\xc6\x1e\x0f\xe0\x1f\xfe\x00\x1f\xff\xff\xff\xff\xfe\x00\xfcp\xe7\x0f\x07\xf0\x0f\xff\x00\x0f\xff\xff\xff\xff\xe0\x01\xf8y\xc3\x9f\x03\xf8\x07\xff\x80\x07_\xff\xff\xfe\x00\x03\xf0\xf0\xe7\x07\x81\xfc\x03\xff\xc0\x07\x00?\xff\x80\x00\x0f\xe0\xe1\xc3\x8f\xc1\xfe\x00\xff\xe0\x01\x00\x00\x00\x00\x00?\xc1\xe1\xe7\xc3\xc0\xff\x00\xff\xf0\x00\x00\x00\x00\x00\x00\xff\x83\xc3\xc3\x87\xe0\x7f\x80\x7f\xfc\x00\x00\x00\x00\x00\x03\xfe\x07\xc1\xc3\xc1\xf0?\x80?\xfc\x00\x00\x00\x00\x00\x1f\xfc\x03\x83\xc3\xc1\xe0\x7f\xc0\x1f\xfe\x00\x00\x00\x00\x00\xff\xf8\x0f\xc7\x83\xe3\xf8\x1f\xe0\x0f\xff\x00\x00\x00\x00\x07\xff\xf0\x1f\x07\xc1\xc0\xf8\x0f\xf0\x07\xff\x80\xe0\x00\x00\x7f\xff\xc0?\x03\x83\xe0\xfc\x0f\xf8\x07\xff\xc0\xff\xf5\x7f\xff\xff\x80~\x0f\xc1\xc1\xf8\x07\xf8\x03\xff\xe0\xff\xff\xff\xff\xfe\x00\xff\x07\x83\xe0~\x07\xfc\x01\xff\xf8\xff\xff\xff\xff\xfc\x01\xfc\x0f\xc1\xf0~\x03\xfe\x00\xff\xfc\xff\xff\xff\xff\xf0\x03\xfc\x1f\x83\xe0\xfe\x03\xfe\x00\xff\xfe\xff\xff\xff\xff\xc0\x07\xf8\x0f\x01\xf0\x7f\x01\xff\x00\x7f\xfe\xff\xff\xff\xff\x00\x0f\xf0?\x83\xf0>\x03\xff\x00\x7f\xff\xff\xff\xff\xf8\x00\x1f\xe0\x1f\x07\xe0?\x80\xff\x80?\xff\xff\xff\xff\xe0\x00?\xe0\x7f\x83\xf0\x7f\x80\xff\x80?\xff\xff\xff\xff\x00\x00\xff\xc0>\x07\xe0?\x80\x7f\xc0\x1f\xff\xff\xff\xf8\x00\x01\xff\x80\xff\x03\xf0?\xc0\x7f\xe0\x1f\xff')
# bat is 128 X 64
bat=bytearray(b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x03\x00\x01\x80\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x03\xe0\x07\x80\x00\x00\x00\x00\x00\x00\x00\x00\x00\x80\x00\x00\x03\xf0\x1f\xc0\x00\x00\x02\x00\x00\x00\x00\x00\x01\x80\x00\x00\x07\xfb\xbf\xc0\x00\x00\x03\x00\x00\x00\x00\x00\x03\xc0\x00\x00\x07\xff\xff\xc0\x00\x00\x07\x80\x00\x00\x00\x00\x07\xe0\x00\x00\x03\xff\xff\xc0\x00\x00\x0f\xe0\x00\x00\x00\x00\x0f\xf0\x00\x00\x03\xff\xff\x80\x00\x00\x0f\xf0\x00\x00\x00\x00\x1f\xf8\x00\x00\x03\xff\xff\x80\x00\x00\x1f\xf8\x00\x00\x00\x00?\xf8\x00\x00\x01\xff\xff\x80\x00\x00?\xfc\x00\x00\x00\x00?\xfc\x00\x00\x01\xff\xff\x00\x00\x00\x7f\xfe\x00\x00\x00\x00\x7f\xfe\x00\x00\x00\xff\xff\x00\x00\x00\x7f\xff\x00\x00\x00\x00\xff\xff\x00\x00\x00\xff\xff\x00\x00\x01\xff\xff\x80\x00\x00\x01\xff\xff\xc0\x00\x01\xff\xff\x00\x00\x03\xff\xff\x80\x00\x00\x03\xff\xff\xe0\x00\x01\xff\xff\x00\x00\x07\xff\xff\xc0\x00\x00\x03\xff\xff\xf0\x00\x03\xff\xff\xc0\x00\x1f\xff\xff\xe0\x00\x00\x07\xff\xff\xfc\x00\x07\xff\xff\xf0\x00\x7f\xff\xff\xf0\x00\x00\x0f\xff\xff\xff\x00?\xff\xff\xfe\x03\xff\xff\xff\xf0\x00\x00\x0f\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xf8\x00\x00\x1f\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xfc\x00\x00?\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xfc\x00\x00?\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xfe\x00\x00\x7f\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\x00\x00\x7f\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\x00\x00\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\x80\x00\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\x80\x00\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\x80\x01\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xc0\x01\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xc0\x03\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xc0\x03\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xe0\x03\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xe0\x07\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xe0\x07\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xff\xe0\x07\xfc\x00\x03\xff\xff\xff\xff\xff\xff\xff\xff\xc0\x00\xff\xe0\x07\xc0\x00\x00\xff\xff\xff\xff\xff\xff\xff\xfe\x00\x00\x0f\xf0\x0e\x00\x00\x00?\xff\xff\xff\xff\xff\xff\xf8\x00\x00\x00\xf0\x08\x00\x00\x00\x0f\xff\xff\xff\xff\xff\xff\xe0\x00\x00\x000\x00\x00\x00\x00\x07\xff\xff\xff\xff\xff\xff\xc0\x00\x00\x00\x00\x00\x00\x00\x00\x03\xff\xff\xff\xff\xff\xff\x80\x00\x00\x00\x00\x00\x00\x00\x00\x01\xff\xff\xff\xff\xfb\xff\x80\x00\x00\x00\x00\x00\x00\x00\x00\x01\xfc\x0f\xff\xff\x80?\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\xf0\x03\xff\xff\x00\x0e\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00@\x01\xff\xfe\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\xff\xfc\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x7f\xf8\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00?\xf8\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00?\xf0\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x1f\xe0\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x1f\xe0\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x0f\xc0\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x07\xc0\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x07\xc0\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x07\x80\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x03\x80\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x03\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x03\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x01\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x01\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00')
# skull is 64 X 64
skullCrossbones=bytearray(b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x0f\xf8\x00\x00\x00\x00\x00\x00\x7f\xfe\x00\x00\x00\x00\x00\x01\xff\xff\x80\x00\x00\x00\x00\x03\xff\xff\xe0\x00\x00\x00\x00\x0f\xff\xff\xf0\x00\x00\x00\x00\x1f\xff\xff\xf8\x00\x00\x00\x00\x1f\xff\xff\xfc\x00\x00\x00\x00\x7f\xff\xff\xfe\x00\x00\x00\x00\x7f\xff\xff\xfe\x00\x00\x00\x00\xff\xff\xff\xff\x00\x00\x00\x00\xff\xff\xff\xff\x00\x00\x00\x00\xff\xff\xff\xff\x80\x00\x00\x01\xff\xff\xff\xff\x80\x00\x00\x01\xff\xff\xff\xff\x80\x00\x00\x01\xff\xff\xff\xff\x80\x00\x00\x01\xff\xff\xff\xff\x80\x00\x00\x00\xff\xff\xff\xff\x80\x00\x00\x00\xff\xff\xff\xff\x00\x00\x00\x00\xfc\x1f\xf8?\x00\x00\x00\x00x\x07\xe0\x1e\x00\x00\x00\x00p\x03\xc0\x0e\x00\x00\x00\x00p\x03\xc0\x0e\x00\x00\x00\x000\x03\xc0\x0c\x00\x00\x00\x000\x06`\x0e\x00\x00\x00\x008\x0c8\x1e\x00\x00\x00\x00\x7f\xfc?\xfe\x00\x00\x00\x00\x7f\xfc?\xfe\x00\x00\x00\x00\x7f\xfc?\xfe\x00\x00\x00\xe0?\xfc\x1f\xfc\x0f\x00\x01\xf8\n\xfc\xbfP\x1f\x00\x01\xf8\x00\x7f\xbe\x00?\x00\x01\xf8\x00\x7f\xfe\x00?\x00\x01\xfc\x00\x7f\xfe\x00\x7f\x80\x03\xff\x00\x7f\xfe\x00\xff\xe0\x03\xff\xc0kZ\x07\xff\xe0\x07\xff\xf0\x0b\xd8\x1f\xff\xe0\x07\xff\xfc\x00\x00\x7f\xff\xe0\x07\xc3\xff\x80\x03\xff\x87\xe0\x00\x00?\xe0\x0f\xf8\x01\x80\x00\x00\x07\xf8?\xc0\x00\x00\x00\x00\x01\xff\xff\x00\x00\x00\x00\x00\x00?\xf8\x00\x00\x00\x00\x00\x00\x1f\xf8\x00\x00\x00\x00\x00\x00\xff\xfe\x00\x00\x00\x00\x00\x03\xfc\x7f\xc0\x00\x00\x00\x00\x1f\xf0\x1f\xf8\x00\x00\x07\x81\xff\x80\x03\xfe\x03\xe0\x07\xff\xfe\x00\x00\xff\xff\xe0\x07\xff\xf0\x00\x00\x1f\xff\xe0\x07\xff\xc0\x00\x00\x05\xff\xe0\x03\xff\x00\x00\x00\x01\x7f\xe0\x01\xfc\x00\x00\x00\x00\x7f\x80\x01\xf8\x00\x00\x00\x00?\x80\x01\xf8\x00\x00\x00\x00?\x00\x01\xf0\x00\x00\x00\x00\x1f\x00\x00\xf0\x00\x00\x00\x00\x0f\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00')
def blk():
oled0.fill(0)
oled0.show()
oled1.fill(0)
oled1.show()
def blink(blinkHalfwayOpen, blink3qtrClosed, blinkClosed):
fb = framebuf.FrameBuffer(blinkHalfwayOpen, 113, 64, framebuf.MONO_HLSB)
oled0.blit(fb, 7, 0) # Empty circle
oled1.blit(fb, 7, 0) # Empty circle
oled0.show()
oled1.show()
utime.sleep(.05)
fb = framebuf.FrameBuffer(blink3qtrClosed, 113, 64, framebuf.MONO_HLSB)
oled0.show()
oled1.show()
utime.sleep(.05)
fb = framebuf.FrameBuffer(blinkClosed, 113, 64, framebuf.MONO_HLSB)
oled0.show()
oled1.show()
utime.sleep(.05)
oled0.show()
oled1.show()
utime.sleep(.05)
oled0.show()
oled1.show()
utime.sleep(.05)
fb = framebuf.FrameBuffer(buffer, 113, 64, framebuf.MONO_HLSB)
def wink(blinkHalfwayOpen, blink3qtrClosed, blinkClosed):
# oled1.blit(fb, 7, 0) # Empty circle
oled0.show()
# oled1.show()
utime.sleep(.1)
oled0.show()
# oled1.show()
utime.sleep(.1)
oled0.show()
# oled1.show()
utime.sleep(.1)
oled0.show()
# oled1.show()
utime.sleep(.1)
oled0.show()
# oled1.show()
utime.sleep(.2)
#def horiz(l,t,r,c): # left, right , top
# n = r-l+1 # Horizontal line
# for i in range(n):
# oled0.pixel(l + i, t, c)
#def vert(l,t,b,c): # left, top, bottom
# n = b-t+1 # Vertical line
# oled0.pixel(l, t+i,c)
#def box(l,t,r,b,c): # left, top, right, bottom
# horiz(l,t,r,c) # Hollow rectangle
# horiz(l,b,r,c)
# vert(l,t,b,c)
# vert(r,t,b,c)
#def blink(l,t,r,c): # left, right , top
# oled1.pixel(l + i, t, c)
#def ring2(cx,cy,r,c): # Centre (x,y), radius, colour
# for angle in range(0, 90, 2): # 0 to 90 degrees in 2s
# y3=int(r*math.sin(math.radians(angle)))
# x3=int(r*math.cos(math.radians(angle)))
# oled0.pixel(cx-x3,cy+y3,c) # 4 quadrants
# oled0.pixel(cx-x3,cy-y3,c)
# oled0.pixel(cx+x3,cy+y3,c)
# oled0.pixel(cx+x3,cy-y3,c)
# oled1.pixel(cx-x3,cy+y3,c) # 4 quadrants
# oled1.pixel(cx-x3,cy-y3,c)
# oled1.pixel(cx+x3,cy+y3,c)
# oled1.pixel(cx+x3,cy-y3,c)
def LookFront():
oled0.blit(fb, moveRight, 0) # Empty circle
oled1.blit(fb, moveRight, 0) # Empty circle
oled0.show()
oled1.show()
LookUp=0
def LookUpandReCenter(LookUp):
LookUp=0
while True:
oled0.blit(fb, 7, LookUp) # Empty circle
oled1.blit(fb, 7, LookUp) # Empty circle
# Finally update the oled display so the image & text is displayed
LookUp=LookUp-1
oled0.show()
oled1.show()
#print("movingright")
if LookUp==-20:
# LookUp=LookUp+1
break
def LookLeftandReCenter(moveLeft):
moveLeft=32
while True:
oled0.blit(fb, moveLeft, 0) # Empty circle
oled1.blit(fb, moveLeft, 0) # Empty circle
moveLeft=moveLeft-1
oled0.show()
oled1.show()
if moveLeft==-20:
break
def LookRightandReCenter(moveRight):
moveRight=7
while True:
moveRight=moveRight+1
oled0.show()
oled1.show()
# print("movingright")
if moveRight==7:
break
def LookRight():
moveRight=30
# blk()
# while True:
oled0.show()
oled1.show()
def LookLeft():
moveRight=-20
# blk()
# while True:
oled0.show()
oled1.show()
def HypnoEyes():
x=0
while True:
x=x+1
fb = framebuf.FrameBuffer(spinnerPos1, 128, 64, framebuf.MONO_HLSB)
oled0.blit(fb, 0, 0) #
oled1.blit(fb, 0, 0) #
oled0.show()
oled1.show()
utime.sleep(.05)
oled0.fill(0)
oled0.show()
oled1.fill(0)
oled1.show()
fb = framebuf.FrameBuffer(spinnerPos2, 128, 64, framebuf.MONO_HLSB)
oled0.show()
oled1.show()
utime.sleep(.05)
oled0.fill(0)
oled0.show()
oled1.fill(0)
oled1.show()
if (x==16):
break
def batlogo():
fb = framebuf.FrameBuffer(bat, 128, 64, framebuf.MONO_HLSB)
oled0.blit(fb, 0, 0) # Empty circle
oled1.blit(fb, 0, 0) # Empty circle
oled0.show()
oled1.show()
utime.sleep(1.5)
oled0.fill(0)
oled0.show()
oled1.fill(0)
oled1.show()
def Pirate():
fb = framebuf.FrameBuffer(skullCrossbones, 64, 64, framebuf.MONO_HLSB)
oled0.blit(fb, 32, 0) #
oled1.blit(fb, 32, 0) #
oled0.show()
oled1.show()
utime.sleep(2)
oled0.fill(0)
oled0.show()
oled1.fill(0)
oled1.show()
def RavenEyesYellow():
pixels.set_pixel(1, (50, 25, 0))
pixels.set_pixel(0, (50, 25, 0))
pixels.show()
def RavenEyesOff():
pixels.show()
def RavenEyesViolet():
pixels.set_pixel(1, (50, 0, 45))
pixels.set_pixel(0, (50, 0, 45))
pixels.show()
def RavenEyesRed():
pixels.set_pixel(1, (200,0,0))
pixels.set_pixel(0, (200, 0, 0))
pixels.show()
def RavenEyesGreen():
pixels.set_pixel(1, (0,200,10))
pixels.set_pixel(0, (0, 200, 10))
pixels.show()
def RavenEyesRGBflash():
pixels.set_pixel(1, (50, 0, 0))
pixels.set_pixel(0, (50, 0, 0))
pixels.show()
utime.sleep(.1)
pixels.set_pixel(1, (0, 50, 0))
pixels.set_pixel(0, (0, 50, 0))
pixels.show()
utime.sleep(.1)
pixels.set_pixel(1, (0, 0, 50))
pixels.set_pixel(0, (0, 0, 50))
pixels.show()
utime.sleep(.1)
def CoffinLidRaven():
CoffinLidServo.duty_u16(6550)
utime.sleep(.5)
RavenEyesRed()
CoffinLidCycles=0
DFPlayerRelay.value(1) #trigger play squawk
utime.sleep(.2)
DFPlayerRelay.value(0) #off trigger to squawk relay
while True:
CoffinLidCycles=CoffinLidCycles+1
RavenLeftWingServo.duty_u16(6500)
RavenRightWingServo.duty_u16(6500)
utime.sleep(.2)
RavenLeftWingServo.duty_u16(3300)
RavenRightWingServo.duty_u16(3300)
utime.sleep(.2)
if CoffinLidCycles==9:
break
utime.sleep(.2)
RavenEyesYellow()
CoffinLidDuty=6500
while True:
CoffinLidDuty=CoffinLidDuty-10
utime.sleep(.02)
CoffinLidServo.duty_u16(CoffinLidDuty)
if CoffinLidDuty==3300:
break
CoffinLidServo.duty_u16(3300)
########################## the demo of screens ############################
oled1.text("BIG SKULL", 10, 30)
oled1.show()
oled0.text("OLED EYE DEMO", 10, 30)
oled0.show()
utime.sleep(8)
blk()
fb = framebuf.FrameBuffer(RoaRobLogo, 90, 64, framebuf.MONO_HLSB)
oled0.blit(fb, 15, 0) # Empty circle
oled1.blit(fb, 15, 0) # Empty circle
oled0.show()
oled1.show()
utime.sleep(10)
fb = framebuf.FrameBuffer(E14logo, 128, 64, framebuf.MONO_HLSB)
oled0.show()
oled1.show()
utime.sleep(5)
oled0.fill(0)
oled0.show()
oled1.fill(0)
oled1.show()
#fb = framebuf.FrameBuffer(buffer, 32, 32, framebuf.MONO_HLSB)
# Clear the oled display in case it has junk on it.
oled0.fill(0) # Black
oled1.fill(0)
batlogo()
blk()
Pirate()
# Blit the image from the framebuffer to the oled display
#oled0.blit(fb, 96, 0)
oled1.blit(fb, 7,0)
#print("blit")
oled0.show()
oled1.show()
utime.sleep(4)
blk()
utime.sleep(1)
moveRight=7
while True:
oled0.show()
oled1.show()
if moveRight==32:
break
utime.sleep(1)
blk()
moveLeft=32
while True:
moveLeft=moveLeft-1
oled0.show()
oled1.show()
if moveLeft==-20:
break
utime.sleep(1)
blk()
moveRight=-20
while True:
oled0.show()
oled1.show()
if moveRight==7:
break
utime.sleep(2)
blk()
LookFront()
utime.sleep(3)
blk()
LookFront()
utime.sleep(.1)
blk()
LookFront()
utime.sleep(.1)
blk()
LookFront()
utime.sleep(.1)
blk()
LookFront()
utime.sleep(.1)
HypnoEyes()
blk() # clear screen
################# DEMO TESTING SERVOS ######
oled1.text("TESTING", 20, 30)
oled1.show()
oled0.text("MOTIONS", 40, 30)
oled0.show()
utime.sleep(6)
blk()
oled1.text("RAVEN", 20, 30)
oled1.show()
oled0.text("LEFT WING", 30, 30)
oled0.show()
utime.sleep(2)
RavenLeftWingServo.duty_u16(4875)
utime.sleep(.2)
RavenLeftWingServo.duty_u16(6400)
utime.sleep(.2)
utime.sleep(.8)
utime.sleep(.8)
utime.sleep(.8)
utime.sleep(.8)
utime.sleep(.8)
utime.sleep(.8)
utime.sleep(.8)
utime.sleep(.8)
blk()
oled1.show()
oled0.text("RIGHT WING", 30, 30)
oled0.show()
utime.sleep(2)
RavenRightWingServo.duty_u16(4875)
utime.sleep(.2)
RavenRightWingServo.duty_u16(6400)
utime.sleep(.2)
utime.sleep(.8)
utime.sleep(.8)
utime.sleep(.8)
utime.sleep(.8)
utime.sleep(.8)
utime.sleep(.8)
utime.sleep(.8)
utime.sleep(.8)
blk()
oled1.show()
oled0.text("HEAD", 40, 30)
oled0.show()
utime.sleep(2)
RavenHeadServo.duty_u16(4875)
utime.sleep(1)
RavenHeadServo.duty_u16(3300)
utime.sleep(1)
RavenHeadServo.duty_u16(6550)
utime.sleep(1)
RavenEyesRGBflash()
utime.sleep(1)
blk()
oled1.text("COFFIN", 20, 30)
oled1.show()
oled0.text("LID LIFT", 30, 30)
oled0.show()
utime.sleep(2)
utime.sleep(2)
blk()
oled1.text("SQUAWKING ON", 10, 30)
oled1.show()
oled0.text("MY COFFIN", 30, 30)
oled0.show()
utime.sleep(2)
CoffinLidRaven()
blk()
oled1.text("Small ", 20, 30)
oled1.show()
oled0.text("SKULLIES EYES",10, 30)
oled0.show()
utime.sleep(2)
LHS_Skully.duty_u16(40000)
utime.sleep(3)
LHS_Skully.duty_u16(0)
RHS_Skully.duty_u16(45000)
RHS_Skully2.duty_u16(45000)
utime.sleep(3)
RHS_Skully.duty_u16(0)
RHS_Skully2.duty_u16(0)
#LHS_Skully.value(1) #LED EYES ON small skull
#utime.sleep(1)
#LHS_Skully.value(0) #LED EYES ON small skull
#RHS_Skully.value(1) #LED EYES ON small skull
#utime.sleep(1)
#RHS_Skully.value(0) #LED EYES ON small skull
blk()
oled1.text("STARTING", 20, 30)
oled1.show()
oled0.text("AUTOMATION", 30, 30)
oled0.show()
utime.sleep(2)
blk()
########################## the program ############################
## Look straight ahead, occassionally blinking
### if LHS_PIR activates, look left, turn on LHS_Skully
### if RHS_PIR activates , look right, turn on RHS_Skully
### if both activate , look straight ahead, both skullys on
while True:
RandomNumber=random.randint(1,49)
WinkRandomNumber=random.randint(0,21)
RavenHeadPositionRandomNumber=random.randint(3300, 6500)
RavenHeadLookAroundRandomNumber= random.randint(1,9)
RavenEyesYellow()
### randon motion events when PIRs at rest
if ((WinkRandomNumber==20) & (LHS_PIR.value() ==0) & (RHS_PIR.value() ==0)):
if ((RandomNumber==20) & (LHS_PIR.value() ==0) & (RHS_PIR.value() ==0)):
batlogo()
if ((RandomNumber==22) & (LHS_PIR.value() ==0) & (RHS_PIR.value() ==0)):
Pirate()
if ((RandomNumber==35) & (LHS_PIR.value() ==0) & (RHS_PIR.value() ==0)):
HypnoEyes()
if ((RavenHeadLookAroundRandomNumber==6) & (LHS_PIR.value() ==0) & (RHS_PIR.value() ==0)):
RavenHeadServo.duty_u16(RavenHeadPositionRandomNumber)
utime.sleep(2)
if ((RandomNumber==31) & (LHS_PIR.value() ==0) & (RHS_PIR.value() ==0)):
CoffinLidRaven()
if ((LHS_PIR.value() ==1) & (RHS_PIR.value() ==1)):
# blk()
# LookFront()
LHS_Skully.duty_u16(30000)
RHS_Skully.duty_u16(40000)
RHS_Skully2.duty_u16(40000)
if ((LHS_PIR.value() ==1) & (RHS_PIR.value() ==0)):
# blk()
LookLeft()
RavenEyesGreen()
utime.sleep(.2)
while True:
RavenHeadDuty=RavenHeadDuty-5
RavenHeadServo.duty_u16(RavenHeadDuty)
utime.sleep(.005)
if RavenHeadDuty==3400:
break
RavenHeadServo.duty_u16(3400)
utime.sleep(2)
while True:
RavenHeadDuty=RavenHeadDuty+5
utime.sleep(.005)
if RavenHeadDuty==4875:
break
RavenEyesYellow()
utime.sleep(.5)
# LHS_PIR_LastScan=LHS_PIR.value()
if ((LHS_PIR.value() ==0) & (RHS_PIR.value() ==1)):
RavenHeadDuty=4875
#blk()
LookRight()
RavenEyesViolet()
utime.sleep(.2)
while True:
utime.sleep(.005)
if RavenHeadDuty==6550:
break
utime.sleep(.2)
while True:
utime.sleep(.005)
break
if ((LHS_PIR.value() ==0) & (RHS_PIR.value() ==0)):
RavenEyesYellow()
#blk()
LookFront()
utime.sleep(1)
#blink(blinkHalfwayOpen, blinkutime.sleep(.2)3qtrClosed, blinkClosed)
dougw
Cancel
Vote Up
0
Vote Down
Sign in to reply
More
Cancel
robogary
in reply to dougw
Cancel
Vote Up
0
Vote Down
Sign in to reply
More
Cancel
Comment-
robogary
in reply to dougw
Cancel
Vote Up
0
Vote Down
Sign in to reply
More
Cancel
