555 Timer Madness
  • 555 Timer Madness
555 Timer Madness
Blog Walter June’s 555 Triangle Waveform Oscillator
Join 555 Timer Madness to participate - click to join for free!
  • Author Author: scottiebabe
  • Date Created: 3 Oct 2022 7:24 PM Date Created
  • Views 68544 views
  • Likes 12 likes
  • Comments 9 comments
  • ne555
  • 555 timer
  • 555timermadnessch
scottiebabe
scottiebabe
3 Oct 2022
Soft 404
  • rsjawale24
    rsjawale24 over 4 years ago in reply to shabaz
    I can see the author mentions that the dual outputs have a 90deg. phase shift between them, how they are opposite in nature and can be shaped to give sine outputs. This could have been used for various wireless communication circuits, like for I and Q generation, for some other type of modulations (phase, BPSK?), etc. Maybe these circuits played an important role back then?
    shabaz over 4 years ago in reply to scottiebabe
    Here's a weird one, that I can't get my head around. It's a dual output triangle wave generator, with adjustable phase shift. I also can't see a purpose for it, but I guess the author must have had a reason!
    DAB over 4 years ago
    Very interesting.
  • rsjawale24
    rsjawale24 over 4 years ago in reply to scottiebabe
    Another method to generate a triangular waveform from square wave is to use an opamp integrator. However, it is difficult to make a wideband integrator that would give triangular output for all square wave input frequencies.
  • scottiebabe
    scottiebabe over 4 years ago in reply to shabaz
    I thought so too! I don't know what the economics were like at the time. I believe transistor were still much more expensive than diodes.
    The circuit is sensitive to everything though, supply voltage, temperature, JFET threshold voltage...
    Still I think its a neat way to match the charge/discharge current Slight smile
