7-Segment Display
  • 7-Segment Display
7-Segment Display
Blog 3d Printed Clock
  • Author Author: GustavoMorales
  • Date Created: 16 Jun 2022 4:17 PM Date Created
  • Views 2063 views
3d Printed Clock
GustavoMorales
GustavoMorales
16 Jun 2022
I made a 3d printed clock researched for stl files to get an idea, first I made one with MDF and a laser cutter but moths later I decided to use a 3d printed model to improve it. I found some files on thingiverse, and used them as a refference, but then I used my own code an diagram to wire everithing, up to the final stage. The main problem I am facing now exepting for programing, was a difusor for leds. To place you in context I used some ws2812b led strip to control them individually and able to program them as I wanted. I also used some codes I found on internet but the fact that using my own files and own diagram made me to modify some code. Here is my project.
It´s capable to show temperture, it gathers this information from a temperture sensor, also humidity and it displays it.
    DAB over 4 years ago
    Looks good, now you are all set for that New Year's eve countdown.
