Acoustics
  • Acoustics
Acoustics
Blog Audio project: Agony Box
Join Acoustics to participate - click to join for free!
  • Author Author: cypresstwist
  • Date Created: 17 Jan 2020 7:27 AM Date Created
  • Views 2967 views
  • Likes 13 likes
  • Comments 8 comments
  • sounds
  • python
  • circuitpython
  • WAV
  • drum machine
  • sound
  • acousticsch
  • circuit playground express
  • microcontroller
  • adafruit
cypresstwist
cypresstwist
17 Jan 2020
This is just something to have disturbing fun with: the Agony Box.
I'm using an Adafruit's Circuit Playground Express with some CircuitPython code in it and some freely available WAV files. The WAV files had to be converted to PCM 16-bit Mono and I think I need to tune down their volume a bit. I used the open-source SoundConverter app in Ubuntu for the conversion:
the CircuitPython code is as follows:
import time
import board
import touchio
import digitalio
try:
    from audiocore import WaveFile
except ImportError:
    from audioio import WaveFile
try:
    from audioio import AudioOut
except ImportError:
    try:
        from audiopwmio import PWMAudioOut as AudioOut
    except ImportError:
        pass  # not always supported by every board!
bpm = 120  # Beats per minute, change this to suit your tempo
# Enable the speaker
speaker_enable = digitalio.DigitalInOut(board.SPEAKER_ENABLE)
speaker_enable.direction = digitalio.Direction.OUTPUT
speaker_enable.value = True
# Make the input capacitive touchpads
capPins = (board.A1, board.A2, board.A3, board.A4, board.A5,
           board.A6, board.TX)
touchPad = []
for i in range(7):
    touchPad.append(touchio.TouchIn(capPins[i]))
# The seven files assigned to the touchpads
audiofiles = ["1aaa.wav", "1aarrgghh.wav", "1scream.wav",
              "1scream5.wav", "1scream7.wav", "1scream11.wav",
              "1ToddQuitit.wav"]
audio = AudioOut(board.SPEAKER)
def play_file(filename):
    print("playing file " + filename)
    file = open(filename, "rb")
    wave = WaveFile(file)
    audio.play(wave)
    time.sleep(bpm / 960)  # Sixteenth note delay
while True:
    for i in range(7):
        if touchPad[i].value:
            play_file(audiofiles[i])
I just modified the WAV files from this drum machine code that originally sounded like this:
Next I used some brass standoffs and standoff rounded metal caps to be able to better access the touch sensors. I soldered some Dupont wires to a 3.7V phone battery and filed down their ends a bit to fit the battery port of the Circuit Playground Express.
Now let's hear some screams:
Disturbing - I know.
I plan to use analog buttons and a cheaper CircuitPython-capable device to build a better Agony Box. This is just some quick hack I did.
    dubbie over 6 years ago +5
    Something to give to the Grandchildren - if you want to annoy their parents. Still, a good project. Dubbie
  • robogary
    robogary over 6 years ago +3
    OMG - I could have so much fun with this. Install the agony sound box in a baby doll or a stuffed animal and watch the reactions. when it gets touched :-)
  • clem57
    clem57 over 6 years ago +3
    Thanks cypresstwist . Because of this project, I went and got one to play with from local Micro Center. I am using Circuit Python as well... Just love how easy to use this board. Did you share the code…
  • clem57
    Just love how easy to use this board. Did you share the code?
  • clem57
  • cypresstwist
    cypresstwist over 6 years ago in reply to clem57
    Glad you like it. It's a fun little toy.
    The code is in the article image
  • cypresstwist
    BTW, here are the code and WAV files I have used in the video demo. In case you need them too.
