Attack of the Drones
  • Attack of the Drones
Blog Alpha Rover - GPS Unit
Join Attack of the Drones to participate - click to join for free!
  • Author Author: ralphjy
  • Date Created: 18 Apr 2021 3:24 PM Date Created
  • Views 1732 views
  • Likes 10 likes
  • Comments 5 comments
  • u-center
  • alphabot
  • gps
  • gt-u7
  • attackofthedronesch
ralphjy
ralphjy
18 Apr 2021
While I'm pondering my choice of a control processor, I thought I'd try out the GPS unit that I bought to use with the Rover.  This is an inexpensive GPS board that I found on Amazon https://www.amazon.com/gp/product/B07P8YMVNT/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1.  It uses a GT-U7 module which has a UBLOX 7th generation chip that is software compatible with the NEO-6M that I've used before.
This board has a micro USB connector in addition to the normal UART connector which makes it easy to hook up to a PC.  One really neat thing I discovered through one of the product links was the free UBLOX U-Center software.
U-Center is GNSS evaluation software for Windows and among other things it allows you to get a visual view of what satellites are available and being used (the map continually updates).  https://www.u-blox.com/en/product/u-center#tab-documentation-resources.
Contents of kit - includes a ceramic antenna with a U.FL connector.
Here is the Sky View map of satellites in U-Center.
About 10 minutes after I first plugged it in, the module had a pretty good fix on my location.  The coordinates it determined actually are in my backyard.  My computer room is an interior room on the second floor and this module is definitely better than the NEO-6Ms that I've used before.  They had some difficulty acquiring satellites from within this room and usually could only acquire 2-3.  I'll have to see how noisy the data is and how accurate it is when I'm outdoors.
The GPS unit outputs a text message stream.  The Text Console in U-Center shows messages as the unit is attempting to acquire a fix.
The message of interest is the $GPRMC which contains the position (latitude, longitude), speed and direction information.  The program needs to parse this comma separated message to extract that information which is described below:
Now have to think about where and how to mount this to the Rover.
  • fmilburn
    fmilburn over 5 years ago +3
    Thanks, amazing how inexpensive GPS has become. Mine is on order
  • javagoza
    javagoza over 5 years ago +2
    Thanks for posting. I think this library could be used with that module https://github.com/mikalhart/TinyGPSPlus
    dubbie over 5 years ago +1
    Ralph, This looks like a fun system. I might also have to get one. Hopefully it will work just as well in the UK. Dubbie
    dubbie over 5 years ago in reply to javagoza
    I've just purchased one of these GPS modules (I said I might - and then I actually did!) so this is very helpful.
    Dubbie
  • javagoza
    Thanks for posting.
  • neilk
    neilk over 5 years ago
    Ralph, very useful for the future!
    thanks for posting
    Neil
    Ralph,
    Dubbie
  • fmilburn
    Thanks, amazing how inexpensive GPS has become. Mine is on order image
