Attack of the Drones
  • Attack of the Drones
Blog Alpha Rover - Ultrasonic Ranging
Join Attack of the Drones to participate - click to join for free!
  • Author Author: ralphjy
  • Date Created: 14 Apr 2021 10:11 PM Date Created
  • Views 1218 views
  • ultrasonic sensor
  • arduino uno plus
  • rotating servo
  • alphabot
  • attackofthedronesch
ralphjy
ralphjy
14 Apr 2021
Time to try the Ultrasonic distance sensor with the panning servo mount.
The Ultrasonic detector uses the common HC-SR04 module.  It emits a stream of eight 40 kHz pulses and provides an ECHO pulse whose width is proportional to the reflection time.
The detector uses a single servo that provides panning to allow detection in different directions.  It uses an SG-90 micro servo which has 180 degrees of rotation.
The range is supposed to be 2cm to 400cm.  That's certainly more than I'll need.
Here's a short range test (limited by the clutter on my desk).
A quick panning test to allow for detection Left, Forward, and Right.
I don't think that I'll be able to use both this sensor and a camera because there isn't enough physical space, but that's something to think about.  Also, I would probably share the panning - but would I want the distance sensor to tilt with the camera?
