PYNQ Workshop
  • PYNQ Workshop
PYNQ Workshop
Blog Getting started with PYNQ-Z2
Join PYNQ Workshop to participate - click to join for free!
  • Author Author: equaltoall
  • Date Created: 7 May 2020 12:13 PM Date Created
  • Views 1992 views
  • pynqstarter
equaltoall
equaltoall
7 May 2020
PYNQ-Z2: Embedded Vision Workshop Series with Adam Taylor
Getting Started | Getting Up and Running  | Unlocking Your Inner PYNQ Hero  | Project14 | PYNQ Workshop image
I've been cutting my teeth with this board since Sunday night.  I completed all the lab one (with a great deal of effort required) prior to the first session of the "PYNQ-Z2: Embedded Vision Workshop (Zero to Hero) Series with Adam Taylor!" and followed along during the webinar on Tuesday.
Following the class, I figured I would flash another boot micro SD chip so any work that I did between now and the next class wouldn't jeopardize my chances of continuing where I left off for the second session.
After running an apt-get update from a terminal window started through Junyper. I started going through the online docs. When trying to follow the steps for "Alveo Getting Started Guide", I found that "pip install pynq" would not work, so I tried "pip3 install pynq"
When I tried the next step "pip3 install pynq-alveo-examples" I got the following feedback:
root@pynq:/home/xilinx# pip3 install pynq-alveo-examples
Collecting pynq-alveo-examples
  Using cached https://files.pythonhosted.org/packages/77/07/d5d82c8076cb78a6ebfefdae1e14f6cb7856ebb73025ef595d80e8046246/pynq_alveo_examples-1.
0.tar.gz
    Complete output from command python setup.py egg_info:
    Traceback (most recent call last):
      File "<string>", line 1, in <module>
      File "/tmp/pip-build-hich32k7/pynq-alveo-examples/setup.py", line 17, in <module>
        from pynq.utils import build_py
    ModuleNotFoundError: No module named 'pynq.utils'
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-build-hich32k7/pynq-alveo-examples/
I'm going to keep plugging away at trying to get a better understanding.  At this point, I feel more than slightly overwhelmed.
    beacon_dave over 6 years ago +3
    Not sure I understand what you are trying to do here exactly. PYNQ-Z2 is a dev board made by Tul Corporation TUL and is the board that the PYNQ-Z2 Workshop expects you to be using. Alveo is a range of…
    beacon_dave over 6 years ago in reply to equaltoall +1
    "... I'd like to have a better understanding of structure and syntax, more so than just copying the examples. …" I've found these courses by Jessica McKellar: https://www.oreilly.com/library/view/introduction…
    TUL
    Alveo is a range of accelerator cards by Xilinx
    https://www.xilinx.com/products/boards-and-kits/alveo.html
    and is not being used on the PYNQ-Z2 Workshop.
    If you completed Lab1 on Sunday, then I assume that you managed to follow along with the Tuesday workshop ok ?
    If you are looking for more PYNQ tutorials to try out on the PYNQ-Z2 following the workshop, then there is the PYNQ Tutorial Workshop here:
    https://github.com/Xilinx/PYNQ_Workshop
    (some of the Session 3 Logictools examples may look familiar)
    Some sessions require access to a handful of Seeed Studio 'Grove' light and temperature sensors and LED bargraph displays to complete.
    ( You can find this linked from below the 'Tutorials and other resources' section  of the PYNQ website:
    PYNQ - Python productivity for Zynq - Community )
  • equaltoall
    equaltoall over 6 years ago in reply to beacon_dave
    Thank you Dave! I did complete and follow along with the first day of the lesson, but I won't say that I feel comfortable with it. I don't have any prior experience with Python. I'd like to have a better understanding of structure and syntax, more so than just copying the examples.
    I didn't realize that the online docs for getting started with PYNQ covers 4 different boards and Alveo was one of the boards.(along with PYNQ-Z1 & ZCU104)
    Thank you for the link to the additional tutorials. I will check them out. Looks like I will need to order a few more components to go with the new lessons.
    I appreciate your help!
  • equaltoall
    https://www.oreilly.com/library/view/introduction-to-python/9781491904794/
    https://www.oreilly.com/library/view/intermediate-python-programming/9781491954935/
    and by David Beazley:
    https://www.oreilly.com/library/view/python-programming-language/9780134217314/
    on Safari Books Online, quite good for learning Python.
    You can find similar course content by Jessica at PyCon on YouTube:
    Jessica McKellar: A hands-on introduction to Python for beginning programmers - PyCon 2014
    https://www.youtube.com/watch?v=MirG-vJOg04
    One of the advantages of the Jupyter Notebook environment is that it allows you to write notes above the code blocks to help describe what is going on. It can be more convenient than trying to do it in code comments.
    "...Looks like I will need to order a few more components to go with the new lessons..."
    It looks like Ralph's already been using most of them with Trace Analyser already image
    PYNQ-Z2 Getting Started - I2C Trace Analyzer
