Project14
Project14
Member Updates Received Off-the-Grid Project14 Reward
  • News
  • Member Updates
  • Competitions
  • Theme Suggestions
  • Author Author: misaz
  • Date Created: 19 Jul 2023 9:36 PM Date Created
  • Views 2675 views
  • Likes 16 likes
  • Comments 9 comments
  • shopping cart
  • off the grid
  • prize
  • project14
  • reward
misaz
misaz
19 Jul 2023
Hello Element14 Community!
About two weeks passed since I was announced as winner of Off-the-Grid Project14 competition which I entered with my Mini Solar Powered Wireless Temperature Sensor. About two days ago I received the reward and about 50 antistatic bags with parts landed on my desk. Thank you very much Tariq for your work when ordering my basket and for organising Project14 competitions!
This time I ordered many small parts and few expensive one. Generally, I made my 250 USD free Farnell basket by importing BOMs for project which I want to do in near future and then filled remaining budget with items from my personal wishlist. At last, I refilled my personal stock by parts which were running low. Btw, few months ago, I deployed Part-DB Open-Source WMS (https://github.com/Part-DB/Part-DB-server) for managing parts. I recommend using it. It helped me very much to realize parts running low in comparison with manual checking which I did before.
Next Projects BOM
These parts I have used in some designed but not yet assembled project. Generally, basket contained several sensors, MCUs and required passives which I do not have yet (ie. mostly non-standard resistor values).
Storage refill
If you read carefully my project Mini Solar Powered Wireless Temperature Sensor you maybe remember that I wrote that one of my unit is missing JTAG connector because my stock get exhausted. This was now fixed and 11 of these nice SAMTEC compact connector fitted the list. Expect these connectors I refilled some capacitors, resistors and 32.768 kHz Crystals.
Security
First parts which were on my wishlist foir a long time were secure elements. The most interesting (and expensive) part of this section is USB Authenticator used for human authentication to the online service but after my first experiment I can confirm that it works even for authenticating to servers over SSH and I will use for these purposes. Goal of this device that it uses encryption private key stored on the device and the device should never leak it. Thus, for authentication to my servers you need to physically steal it from me. Benefit is that even compromise of my computer using malware possible hackers are unable to login to my server, even they get remote access to my disk. Naturally, it is of course much more secure than entering passwords. Device is also usable for few other purposes which I did not test yet.
Other security parts which I ordered are targeting embedded applications. First one is SPI TPM chip and second interesting chip is Infineon Optiga Trust M security IC which do similar thing to TPM chip but has proprietary interface more optimized for embedded applications.
USB Authenticator SNU20000D1PBAN0-E-11-110-SB0 Swissbit 1 Buy Now
TPM Chip SLB9670VQ20FW785XUMA1 Infineon 1 Buy Now
Optiga trust M V3 SLS32AIA010MKUSON10XTMA2 Infineon 1 Buy Now
Soldering
Other parts form my Wishlist are two soldering tips for MP740686 Soldering Station which I received recently as a webinar reward. I will soon update the MP740686 mini review blog with my experience with new tips (spoiler: It is much better). Other part useful for soldering which I received are these super cool helping hands:
You can install up to 6 handles. They are from plastic, so you need to pay attention to high temperatures, but they are strong enough. Of course, they are adjustable and very flexible.
Helping Hands D03419 Duratool 1 Buy Now
Soldering tip Chinsel 1.2mm 21-10142 (compatible with MP740686) Tenma 1 Buy Now
Soldering tip Bevel 2mm N9-26 Duratool 1 Buy Now
Raspberry Pi Camera Module 3  Buy Now
Other part from my Wishlist is Camera for Raspberry Pi. It is my first Raspberry Pi Camera, so now I can integrate computer vision to my projects. For a first time, my Raspberry Pi made it’s own selfie:
Renesas RX72N Envision Kit  Buy Now
The other part from my wishlist is this Renesas RX72N MCU devkit. It was RoadTested few years ago, so you can read find detailed reviews of this board here: Renesas RX72N Envision Kit. Board comes from Japan and their authors are proud of it. At the first look it is clear that they loved their job and board is designed very well. It is preprogramed with games which allows to test high-performance nature of the MCU and test it 2D graphics accelerator. RX72N is one of the most advanced MCU on the world, but it’s usage is quite a hard because of CPU core with proprietary Renesas core supporting proprietary RXv3 instruction set. I am missing reset button on the board but otherwise it is very nice and comprehensive board with Display, Ethernet, Wi-Fi, USB, and several other chips and sensors. Interestingly it is affordable, and the price is not high when you take in account that it features very advanced MCU, onboard E2 Lite debugger, lot of external parts and so on.
Very soon, I replaced default firmware containing games by something much simpler for learning the basics of the development environment (which is different from environment used on Renesas RA ARM MCU families):
Optic Fiber  Buy Now
The last part which I want to mention is optic fibre. While datasheet mention possibility for data transfer I want to use it for “routing” light from LED on PCB to other place on case. If you place light at fibre start, it slightly illuminates on the body and most light, you will see on the other end. It works very nice.
Conclusion
Thank you very much Tariq and Element14 for this reward. I enjoyed unboxing these parts, some of them I already tested and in near future they will allow me to make some project and possibly join next Project14 competitions.
  • robogary
    robogary over 3 years ago +2
    Very nice treasure chest ! Project14 is a high gain positive feedback loop. You have a good idea and build it. Win a shopping cart, replenish inventory, get parts you cant really justify buying for some…
  • misaz
    misaz over 3 years ago in reply to ntewinkel +1
    Thank you for feedback. Yes it work with Google account well. It has both USB and NFC interface. On normal computer you use USB (Type A). On iPhone or iPad you use NFC interface (when requested you bring…
  • misaz
    Yes it work with Google account well. It has both USB and NFC interface. On normal computer you use USB (Type A). On iPhone or iPad you use NFC interface (when requested you bring authenticator near to NFC antena on device and it will authenticate). Support for authenticating differs per service. For example in case of MS Account I was able to register it and login using it on computer but on iPhone it do not offer me this method for some reason. In case of Google it work better. It work in native app and it also work when loging to Google from browser, but only Safari supports this.
  • ntewinkel
    ntewinkel over 3 years ago
    Congratulations, misaz !
    I love how these shopping carts create an endless feedback loop Smile  create a project, win more parts to create the next project, repeat.
    That USB Authenticator key you picked out caught my eye - does that work with Google as well? And, given that it's USB, does it only work with "regular" computers, or is there a way to use it through an iPhone or iPad? (newer iPads now have the USB-C connection, so maybe there's a chance?)
  • misaz
    misaz over 3 years ago in reply to baldengineer
    Base of the helping hands is strong but I can imagine it even more heavy. All old helping hands which I used at high school, univerzity and job were more heavy but for most tasks it's weight is sufficientl, I think. I cant esitmate which metal is used but that it is finished by some black surface finish. It has six mounting locations. Distance between nearby mounting points is exactly 5cm.
    At the bottom of each mounting point there is rubber stand which make stand stable on the desk.
    In comparison with "standard" helping hands D00269 it is much bigger and hands are longer. Every hand has length of 35cm including clamp and thread which fits the base. It is good when you working with large devices but for general purpose soldering when two hands are sufficient standard helping hands may be better because it is more compact. The big benefit is flexibility. You can use for exmaple thre arms for holding PCB and you still have three arms ready to help with holding wires and so on.
    Clamp is detachable and and the orange part holding clap is the only part of the system which I consider slightly weak. There is rubber black part on the clamp which holds the clamp inside the orange holder. You need little to mediate force to pull it out. It is much weaker than for exmaple blue part of the hand but still holds clamp at position pretty well. Maybe over time will become more weaker but in new condition it is not a problem.
    It do not have any accessories known from standard helping hands like magnifier but this is not issue for me, and I like this simple design.
    As I mention orange and blue parts are from plastic. I have no idea about thermal transfers quality (or preferable poor quality) but I recommend paying attention attention to this. At least you need to pay attention occasionaly touching the arms. One of benefit of plastic arms is that they are not conductive in comparison with standard helping hands which have all claps usualy electricaly interconnected.
    Finally, good part is price. It was one of the cheaper parts in my free basket. At newark it is for some reason much more expensive than on Farnell in Europe. In US price difference between standard (D00269) and these (D03419) helping hands is significant but in Europe difference is smaller and with price set to around 15 GBP it is good buy, I think.
  • baldengineer
    baldengineer over 3 years ago
    Nice haul!
    I am very interested to know your thoughts on the Duratool helping hands. I bought a similar setup from an individual who "hand made" (CNC) the base. It was part of a larger system that was customizable. But essentially, it was a PTFE base with those articulating arms.
    He has since stopped selling them, but people always ask about my setup. So, I have been looking for an alternative to suggest.
    DAB over 3 years ago
    Well earned, have fun.
