Project14
Project14
Member Updates Smart Shopping Bag --Blog2
  • News
  • Member Updates
  • Competitions
  • Theme Suggestions
  • Author Author: anupash.1002
  • Date Created: 13 Jan 2019 5:59 PM Date Created
  • Views 1749 views
  • pocketbeaglebone
  • Wearable
  • Wearable tech
  • wearabletechch
anupash.1002
anupash.1002
13 Jan 2019
Wearable Tech
Enter Your Electronics & Design Project for a chance to win a $100 Shopping Cart!
Project14 Home
Monthly Themes
Monthly Theme Poll
  • Interface load cell to Arduino
  • Testing and calibrating the load cell
  • Problems During the Project
  • upcoming.....
These are the first results of the working smart shopping bag project. Finally I got the Load Cell 10kg straight Bar sensor and the Load Cell Amplifier HX711. Interfacing them is simple with Arduino. There are also libraries available in Arduino to use the load cell.
Connecting the load cell to the Arduino board via the amplifier
The test setup
I2C operated LCD to see the load results
The load cell should be calibrated with 100g so i chose to use the spicy sauce
reset the scale to 0grams
No weight measurement. Sometimes some offset can be seen which have to be reset everytime
measuring other items such as cream.
The working Load Cell 10kg straight Bar with Amplifier HX711 connected to Arduino and displaying message on LCD via the I2C
Working demo if the project
Adding the flex Panel LED array to the mix and connecting to Arduino
Working video with different messages to the flex-led panel
  • I tried to re-do the code with pocket beagle but without much success. Since the beagle IDE runs on the board itself there is needed to add a wifi dongle to install libraries on it. I also tried to use the flex panel with beagle bone but without much success so I decided to go with Arduino.
  • Another minor issue is that the load cell needs to be reset several times as sometimes it does show not so accurate results. I did several times the calibration of the load cell.
Where to buy Hardware:
Load Cell 10kg straight Bar sensor https://www.sparkfun.com/products/13329
Load Cell Amplifier HX711 https://www.sparkfun.com/products/13879
upcoming.....
How all the sensor fits to the shopping bag.
  • daz23079
    daz23079 over 7 years ago
    You won’t get accurate readings from this load cell because it is not mounted correctly it needs mounting feet 1 at the top and 1 at the bottom.
  • daz23079
