Project14
Project14
Member Updates Tiny light cluster
  • News
  • Member Updates
  • Competitions
  • Theme Suggestions
  • Author Author: Workshopshed
  • Date Created: 12 Oct 2018 2:50 PM Date Created
  • Views 2250 views
  • Likes 10 likes
  • Comments 6 comments
  • clusteredmcuch
  • tagname
Tiny light cluster
Workshopshed
Workshopshed
12 Oct 2018
Here's my idea I'm afraid I did not quite have time to get it completed as I've had lots of other things on.
My first thought was what is the cheapest MCU I can find? I spotted the ATTiny10 chips for just 25p each so bought a handful of these along with some surface mount LEDs and resistors.
These would be powered from some button batteries I just happened to have lots of.
The nodes would be spaced out on a clear plastic sheet so you could see that there was no physical connection between them.
They would provide a synchronised pattern or message.
So how does the synchronisation work you ask? Well that would be done by using a camera flash and the LEDs acting as a sensor (a trick I learnt from the Microbit).
https://electronics.stackexchange.com/questions/902/detecting-light-with-an-led
Unfortunately I only got as far as wiring up the ATTiny to some wires and the LED to some wires. I do have a programmer for the ATTiny but I've not tried programming it yet.
  • 14rhb
    14rhb over 8 years ago +6
    Andy, Maybe you haven't got as far as you'd have liked but thank you for sharing as you've given me some ideas for in the future. Your use of a small MCU was exactly along the lines of what I was thinking…
  • Fred27
    Fred27 over 8 years ago +5
    25p? You were ripped off! 3c is the going rate for microcontrollers these days. https://www.eevblog.com/forum/blog/eevblog-1132-the-3-cent-microcontroller!/
    genebren over 8 years ago +4
    These ATTiny parts are on of my favorites. I have used these on a lot of simple device including my light ring for my microscope and my under cabinet LED lighting solution in my kitchen. I have also used…
    I have also used these and some similar PIC chips to eliminate a bunch of discretes and logic gates in H-bridge drivers, using timers to manage on-off times to prevent low impedance paths between power rails (off before on protection).
    Nice of you to share your ideas even if you did not complete your entry.
    Gene
    Gene
