Circuit Prototype Techniques
  • Circuit Prototype Techniques
Forum Wonderboard Solderless Circuit Cards
Join Circuit Prototype Techniques to participate - click to join for free!
  • Replies 16 replies
  • Subscribers 45 subscribers
  • Views 4220 views
shabaz
shabaz over 4 years ago
I was browsing through an old issue of Wireless World (really old - 1978), and saw this advert:
It's not very clear how it works, although if you look at the diagram at the very bottom of the photo, to me it appears like the elastomer is like a thin rod poked through the hole, and perhaps the contacts are pushed around it...or maybe it is a sheet of elastomer with small holes in it, and it is glued onto the PCB, because it says 4mm on the diagram, and a PCB would usually be much thinner.
Anyway, it looked interesting!
  • scottiebabe
    scottiebabe over 4 years ago +6
    Interesting discovery, thanks for sharing. I wish I had a speedwire board just as a collectors item https://en.wikipedia.org/wiki/Speedwire This was the best photo I could find after a quick search …
    shabaz over 4 years ago in reply to scottiebabe +4
    Nice! It looks like IDC style pins like on the rear of phone jacks.. If you could find a source for the metal contacts in IDC ribbon cable sockets, then those might work : ) I really like Eurocard…
  • scottiebabe
    scottiebabe over 4 years ago in reply to shabaz +4
    Yes exactly, and the pen just had a spool of 30 awg Kynar wire on top. Yes the eurocard was definitely large enough to contain an entire project on one card. I find the inexpensive 5cm x 7cm perfboards…
    I should have google'd it : ) Just found some more info, that explains it a bit better:
    Source: Electronics and Radio Constructor, December 1978
  • ntewinkel
    ntewinkel over 4 years ago
    shabaz said:
    really old - 1978
    Dang. I’m ancient Laughing
    Really cool prototyping board! I’m guessing they were just not cost effective compared to the alternatives, but it looks like a handy way to build little circuits.
  • Andrew J
    Andrew J over 4 years ago in reply to ntewinkel
    The small one is around £18 in inflation adjusted cost.  I don’t know how much a breadboard would have cost in 1978 but assuming their price would have adjusted for inflation the same way, then I’d say they were very expensive.
    shabaz over 4 years ago in reply to Andrew J
    Their claim of it being the most economical prototyping method is quite ridiculous : )
    shabaz over 4 years ago in reply to ntewinkel
    Looks like the normal plug-in breadboards were around then, you're right, probably that was way more cost-effective.
    (Image source; Practical Electronics Nov 1978).
    Still, it got me thinking, if there were a PCB with larger diameter holes (say 3mm) then each hole could be plugged with a small piece of silicone tube (it comes in such small diameters from memory), so that a user would just push in wires between the hole edge and the tube, i.e. so that it's forced against the inner conductive surface of the hole. It could be completely impractical for integrated circuits, but maybe feasible for discrete parts. But then one may as well use a normal breadboard!
  • Andrew J
    Andrew J over 4 years ago in reply to shabaz
    Did that advert have any prices?  I think breadboards are so cheap, easy to use and ubiquitous that it’s easy to put up with the occasional issue and any alternate technology for prototyping would really struggle.  Veroboard is probably the next best alternative.
    Still, these adverts are interesting to see the path of technology advancement.  I’ll have to dig archive at the museum to see what they have.
    It didn't have prices, but I found another advert from the time. Jjudging by some of the prices in these ads in 1978, I think it must have either generally been really high cost to buy electronics stuff, or at least in the UK back then. Can't see how they are suggesting the watch prices below are "low-cost" for that time. Still, VAT was just 8% versus 20% now, and postage and packing was typically 25p, versus the £3-5 or even higher that is normal nowadays everywhere : (
  • neilk
    neilk over 4 years ago in reply to shabaz
    Adjusting even vaguely for inflation, the Quick test and Protoboards look very very expensive!
    Neil
  • scottiebabe
    Interesting discovery, thanks for sharing. I wish I had a speedwire board just as a collectors item Stuck out tonguehttps://en.wikipedia.org/wiki/Speedwire
    https://docs.rs-online.com/e9b7/0900766b800270c2.pdf
    • Vote Up +6 Vote Down
  • Andrew J
    Andrew J over 4 years ago in reply to neilk
    You’re right.  £179 in 1978 is worth around £1100 now!  Inflation calculator here: https://www.bankofengland.co.uk/monetary-policy/inflation/inflation-calculator
