Crazy Arduino Automations
  • Crazy Arduino Automations
Crazy Arduino Automations Forum Communications for Smarthab
Join Crazy Arduino Automations to participate - click to join for free!
  • Subscribers 43 subscribers
  • Views 1282 views
  • communications
  • wiring
  • arduino automations
  • smart home
phoenixcomm
phoenixcomm over 3 years ago
Figure 1. This came from the www.regent5.com website
Wiring for a "Smart house should never look like this. They must like paying a contractor to run wire, which you have to pay for. I don't believe in wasting wire, it cost big bucks.  I prefer to use CANbus for communications to each of the rooms, in which there is always a room controller. The same goes for Internet wiring the "main switch has nodes, which go to the room controller as well, which also contains a small switch. In a large house, I switch to CAN over Ethernet. You will need a media converter, as you will have to use the higher protocol CANaerospace. the protocol converter can be nothing more than a Raspberry Pi and a Java program to handle the stacks.
I never mix types of signals on my Ethernet system in other words VOip and IP is a no-no as a busted phone can bring down your network. This also goes for any CAN over Ethernet as well, and while we are at it let's keep the video off Ethernet and put it on RJ-6. BTW did you notice the black tie wraps or cable ties?? Huge No-No! You should never use them on ANY DATA CABLES as when you tighten up the tie-wrap it deforms the cable and changes its impedance.  More later
  • phoenixcomm
    phoenixcomm over 3 years ago in reply to embeddedguy +1
    embedded_guy If you want to know more about CANaerospace please check out "Adventures in CANaerospace" which can be found here: "NexGen Blog Index 1 In there I talk about its ISO model it use and the Book…
  • embeddedguy
    embeddedguy over 3 years ago
    CANaerospace. Nice information.
  • phoenixcomm
     embedded_guyIf you want to know more about CANaerospace please check out "Adventures in CANaerospace" which can be found here: "NexGen Blog Index 1 In there I talk about its ISO model it use and the Book itself which is aircraft based of course but It has everything you need to implement it. the stack that runs is on a 32-bit machine that is EBig-endian. G Luck.
  • embeddedguy
    embeddedguy over 3 years ago in reply to phoenixcomm
    Interesting. I have worked on SpaceWire so this is useful to me to take a note. I did some simulation of SpaceWire with network simulation ..
