DIY Test Equipment
  • DIY Test Equipment
DIY Test Equipment
Blog Raspberry PI - Ohmmeter
Join DIY Test Equipment to participate - click to join for free!
  • Author Author: sherbieny
  • Date Created: 23 Sep 2017 2:23 PM Date Created
  • Views 3828 views
  • rpiintermediate
  • diytestequipch
  • ubuntu linux
  • ohmmeter
  • c progrmming
  • ads1015
  • raspberry pi2
  • pi i2c
sherbieny
sherbieny
23 Sep 2017
An Ohmmeter device using Raspberry PI 2B with ADS1015 as ADC
https://github.com/Sherbieny/Ohmmeter-Pi
http://fritzing.org/projects/pi-ohmmeter
Setup
  • Items needed:
    • PC or Laptop
    • Raspberry Pi (I used model 2B)
    • ADS1015 12bit ADC converter (if you use 1115 which is 16bit, there will be slight changes)
      • Breadbord, wires, resistors
      • Adafruit assembled Pi T-Cobbler Plus - GPIO Breakout (Optional)
  • Circuit setup
    • Refer to fritzing diagrams in schematics folder
  • Configuration
    • SSH, VNC or anyother method of communication enabled between the Raspberry PI and the user PC
      • My case was
        • Laptop with Ubuntu 16.04 LTS
        • Raspberry PI 2B with Raspbian Jessie release 2017-01-11-raspbian-jessie.img
        • SSH communication through ethernet cable
  • Deployment instructions
    • As per the schematics folder
      • Connect Raspberry with Adafruit T-Cobbler
      • Connect T-Cobbler onto the breadboard
      • Connect ADS1015 onto the breadboard
      • Do the wirings as described in the schematics folder
      • In the circuit diagram I made a note about the location of the UNKNOWN resistor
https://github.com/Sherbieny/Ohmmeter-Pi#information-sourcesInformation Sources
  • ADS1015 Schematic (Very useful !)
    • https://cdn-shop.adafruit.com/datasheets/ads1015.pdf
  • dev-interface driver at kernel.org
    • https://www.kernel.org/doc/Documentation/i2c/dev-interface
  • Voltage divider info
    • https://learn.sparkfun.com/tutorials/voltage-dividers
  • An excellent tutorial on basic usage of ADS1115 (basicly same as ADS1015), will clarify a lot !
    • http://openlabtools.eng.cam.ac.uk/Resources/Datalog/RPi_ADS1115/
https://github.com/Sherbieny/Ohmmeter-Pi#built-withBuilt With
  • VIM text editor
  • GCC compiler
