Electronic Toys
  • Electronic Toys
Electronic Toys
Blog Pimp my PICADE
Join Electronic Toys to participate - click to join for free!
  • Author Author: luislabmo
  • Date Created: 16 Sep 2019 11:50 AM Date Created
  • Views 5946 views
  • Likes 14 likes
  • Comments 15 comments
  • ardintermediate
  • picade
  • raspberri pi
  • plexiglass
  • rgb
  • ws2812b
  • rpi
  • luislab
  • electronictoych
  • acrylic
Pimp my PICADE
luislabmo
luislabmo
16 Sep 2019
Not long ago, I got a Picade: a retro arcade machine built around a Raspberry Pi. Few seconds after appreciating the marquee, I saw an opportunity to improve the looks of it using Individually Addressable LEDs, so an LED edge lit marquee was born.
    • Engraving the PICADE Logo
    • Electronics
    • Arduino Code
    • Final assembly
      • 3-D Print settings
    • Final thoughts
Since I don't have easy/cheap access to a laser engraver (or CNC mill/router) I ended up with an extra challenge, designing a mount for my Creality CR-10S 3D printer to fit a Dremel Rotary tool which to my surprise, worked very well!.
{gallery:width=960,height=768,autoplay=false} Dremel Mount for Creality CR-10S
Dremel Mount: Dremel Mount for Creality CR-10S
I designed the Picade logo in Fusion 360 with just a trace of material 0.2mm tall -equivalent to the layer height of my 3-D print settings- and the same width as the nozzle diameter, this generated perfect results and thanks to this approach I didn't have to to use a different firmware and/or software on my 3D printer to use it as an engraver.
{gallery:width=960,height=768,autoplay=false} Engraving with Creality CR-10S
Picade Logo: Picade Logo in Fusion 360
Picade Marquee: Picade Marquee on 4.5mm Acrylic
Electronics
The electronics for the project are very simple. A custom made PCB with 7 individually addressable RGB LEDs (WS2812B) connected to an Arduino Pro Mini - 5V that will control all the light effects (Digital Pin 6). Everything is then connected to the 5V and GND pins of the Picade's Hack Header.
{gallery:width=960,height=768,autoplay=false} Picade Edge Lit Marque - Electronics
Picade Edge Lit Marquee: Custom made PCB
Picade Edge Lit Marquee: Electronics assembly
Picade Edge Lit Marquee: Testing the electronics
Picade Edge Lit Marquee: PCB Eaglecad
Picade Edge Lit Marquee: RGB lights schematic
Picade Edge Lit Marquee: Arduino Pro Mini - 5V
Picade Edge Lit Marquee: Arduino Pro mini - 5V
Picade Edge Lit Marquee: Connecting the lights to the Picade's Hack Header
Arduino Code
I made various effects that can be tweaked changing the values of some variables. The most important part of the sketch is the RGB array which will define the different colors that will be displayed during all the effects; I decided to start with the classic rainbow colors.
// Luis Ortiz - luislab.com
// September 14, 2019
// Light effects for the Picade's Edge Lit Marquee
#include <Adafruit_NeoPixel.h>
#define LED_PIN           6 //Digital pin for WS2812B Data In
#define LED_COUNT         7 //Number of LEDs in the strip
#define MAX_TRANSITIONS  35 //Max number of transitions
#define LED_BRIGHTNESS  255 //Max brightness for all the effects
Adafruit_NeoPixel strip(LED_COUNT, LED_PIN, NEO_GRB + NEO_KHZ800);
byte rgb[LED_COUNT][3] = {
  {0xFF, 0x00, 0x00},
  {0xFF, 0x1F, 0x00},
  {0xF7, 0x82, 0x00},
  {0x00, 0x80, 0x00},
  {0x00, 0x00, 0xFF},
  {0xFF, 0x00, 0x62},
  {0x8F, 0x00, 0xFF}
void staticRainbow (byte firstLED = 0) {
  byte i = 0;
  for (i=0; i<LED_COUNT; i++)
    strip.setPixelColor((firstLED + i) % LED_COUNT, rgb[i][0], rgb[i][1], rgb[i][2], LED_BRIGHTNESS);
  strip.show();
void setup() {
  strip.begin();
  strip.show(); // Initialize all pixels to 'off'
  randomSeed(analogRead(0));
  for (byte i=0; i<10; i++) { // Turn ON/OFF randomly a few times
    staticRainbow(0);
    delay(random(1,50));
    strip.fill(0, 0, 0);
    strip.show();
    delay(random(1,400));
void oneAtATime(byte index = 0) {
  for (byte i=0; i<LED_COUNT; i++)
    strip.setPixelColor(i, 0x00, 0x00, 0x00, LED_BRIGHTNESS);
  strip.setPixelColor(index, rgb[index][0], rgb[index][1], rgb[index][2]);
  strip.show();
void buildUp() {
  byte i = 0;
  byte j = 0;
  strip.show();
    for (j=0; j<LED_COUNT-i; j++) {
      strip.setPixelColor(j, rgb[i][0], rgb[i][1], rgb[i][2], LED_BRIGHTNESS);
      if ( j >= 1)
        strip.setPixelColor(j-1, 0x00, 0x00, 0x00, LED_BRIGHTNESS);
      strip.show();
      delay(250);
void fade(byte index = 0, byte fadeInOut = 1) { //0 = Fade In, 1 = Fade Out
  float rRatio;
  float gRatio;
  float bRatio;
  for (int i=0; i<=LED_BRIGHTNESS; i++) {
    for (byte j=0; j<LED_COUNT; j++) {
      rRatio = rgb[j][0] * abs((LED_BRIGHTNESS * fadeInOut - i)) / LED_BRIGHTNESS;
      gRatio = rgb[j][1] * abs((LED_BRIGHTNESS * fadeInOut - i)) / LED_BRIGHTNESS;
      bRatio = rgb[j][2] * abs((LED_BRIGHTNESS * fadeInOut - i)) / LED_BRIGHTNESS;
      strip.setPixelColor((j + index) % LED_COUNT, floor(rRatio), floor(gRatio), floor(bRatio), LED_BRIGHTNESS);
    strip.show();
    delay(10);
void softTransition (byte index = 1, byte transitionNo = 0, byte maxTransitions = 5) {
  int newR;
  int newG;
  int newB;
  byte nIndex;
  byte cIndex;
  ++transitionNo;
  for (byte i = 0; i<LED_COUNT; i++) {
    cIndex = (index + i) % LED_COUNT;
    nIndex = (cIndex + 1) % LED_COUNT;
    newR = rgb[cIndex][0] + ((rgb[nIndex][0] - rgb[cIndex][0]) * transitionNo / maxTransitions) ;
    newG = rgb[cIndex][1] + ((rgb[nIndex][1] - rgb[cIndex][1]) * transitionNo / maxTransitions) ;
    newB = rgb[cIndex][2] + ((rgb[nIndex][2] - rgb[cIndex][2]) * transitionNo / maxTransitions) ;
    strip.setPixelColor(i, newR, newG, newB, LED_BRIGHTNESS);
  strip.show();
void switchColors (byte firstLED = 0) {
  for (byte i =0; i<LED_COUNT; i++)
    strip.setPixelColor((i + firstLED) % LED_COUNT, rgb[i][0], rgb[i][1], rgb[i][2], LED_BRIGHTNESS);
  strip.show();
void loop() {
  strip.show();
  byte i=0;
  // Fade In
  fade(0, 0);
  delay(500);
  // Color switch
  for (i=0; i<100; i++) {
    switchColors(i);
    delay(225 - i*2);
  delay(500);
  // Fade Out
  fade(i - 1, 1);
  delay(250);
  // Soft rainbow transition
  byte trnNo   = 0; // Transition index number
  byte nextLED = 0;
  fade(LED_COUNT - 1, 0);  // Fade In
  delay(500);
  for (int z=0; z<(MAX_TRANSITIONS*LED_COUNT)*5; z++) {
    if (trnNo == 0)
      nextLED = ++nextLED % LED_COUNT;
    softTransition(nextLED, trnNo, MAX_TRANSITIONS);
    delay(20);
    trnNo = ++trnNo % MAX_TRANSITIONS;
  // Fade Out
  fade(LED_COUNT - 1, 1);
  delay(500);
  // One-at-a-time on each direction
  for (i=0; i<LED_COUNT; i++) {
    oneAtATime(i);
    delay(250);
  for (i=1; i<=LED_COUNT; i++) {
    oneAtATime(LED_COUNT-i);
    delay(250);
  delay(500);
  //Build up
  buildUp();
  delay(2000);
  strip.show();
  delay(500);
Final assembly
To cover the custom made PCB, I designed and 3D printed a black cover with room for routing the wires. It was designed to use the same mounting hardware used to tighten the top of the PICADE without any modifications.
{gallery:width=960,height=768,autoplay=false} Picade LED Edge Lit Marque Assembly
Picade Marquee: Engraved marquee assembly
Picade Marquee: custom made PCB assembly
Picade Marquee: Top 3D printed cover
3-D Print settings
Settings used:
  • Printer: Creality CR-10S
  • Material: PLA Black
  • Infill: 20%, triangles
  • Adhesion: Skirt
  • Supports: No
  • Layer height: 0.2mm
Final thoughts
Overall I'm very happy with the results, it looks amazing, in fact the lights are so bright that they can illuminate all the Picade without the need of external lights.
Thank you for reading along!. All the resources to reproduce this project are attached to this blog entry.
Luis
Picade_Marquee.zip
    balearicdynamics over 7 years ago +5
    A very good improvement, nice effect and well done and refined. I have a spare 3D printer full working, I have in mind to ass a spindle too to convert it to ta small engraver. Please, can you share this…
  • luislabmo
    luislabmo over 7 years ago in reply to balearicdynamics +5
    Hello Enrico, Thank you for your comments. Sure thing, I will create a new entry with the details I remember, cura settings, and the mount 3D model. All the best. Luis
    dubbie over 7 years ago +5
    A really good add-on to the PiCade. I particularly liked the tip for smoothing the acrylic using a heat gun. I've cut acrylic before without getting it so smooth - now I know what to do. I've made an edge…
    I've made an edge lit acrylic sign before, yours looks much better.
    Dubbie
    • Vote Up +5 Vote Down
  • luislabmo
    luislabmo over 7 years ago in reply to dubbie
    Thank you Dubbie!. Tbh, to smooth the edges of acrylic, a heat gun is the last resource I'd go for but in my case, it was the only one I had available. These are the ones you should go for in that order IMO:
    1. Laser cut (edges will be smooth right after being cut, no extra steps needed).
    2. Buffing/polishing wheel
    3. Torch
    4. Heatgun
    For better results sand before steps 2,3,4.
    Luis
  • luislabmo
    3. Torch
    4. Heatgun
    Luis
    dubbie over 7 years ago in reply to luislabmo
    Alas, I don't have a laser cutter (or access to one), nor any buffers, nor a torch (although I've been thinking of getting one for a while now), so should I ever cut any acrylic, it looks like it is going to be heat gun.
    Dubbie
    dougw over 7 years ago in reply to dubbie
    Getting close to anything red hot would probably work - like a stove element, even a soldering iron might work.
  • luislabmo
    luislabmo over 7 years ago in reply to dougw
    Hi Doug,
    This is a great idea that can probably work better than the heat gun.
