Electronic Art
  • Electronic Art
Electronic Art
Blog Electronic Art app controlled by Arduino Uno
Join Electronic Art to participate - click to join for free!
  • Author Author: ilvyanyatka
  • Date Created: 28 Aug 2020 2:23 AM Date Created
  • Views 5794 views
  • Likes 12 likes
  • Comments 24 comments
  • electronic art app
  • electronicartch
  • c#.net
ilvyanyatka
ilvyanyatka
28 Aug 2020
My project is an electronic Art App controlled by Arduino Uno.
The app connects to Arduino port. goes full screen, and starts drawing abstract geometrical figures based on parameters it reads from the Arduino. The user can can control what the app is drawing using potentiometers, switches, and a push button. Everything can be controlled by Arduino, there is no need for keyboard and mouse (after connecting to Arduino port). App can be used for meditation, or just to relax. Drawings can be saved in real time using push button.
Push button 1 – clears app screen
Push button 2 - save the screenshot of the drawing
Switch 1 – Start/Stops drawing
Switch 2 – controls line type. Line type can be an Arc (Bezier curve) or a straight line
Potentiometer 1 – controls line width
Potentiometer 2 – controls an angle for a drawing
Potentiomenter 3 - controls drawing speed
The app itself is written in C#.NET. To communicate between .NET and Arduino I used open source Sharer library, it is awesome and it can be found here:
https://github.com/Rufus31415/Sharer
Fun fact: When testing the board I ran into a problem that all analogRead() functions returned incorrect values. I could not figure out why, it was driving me crazy. I was sure that I fried both of my Arduinos somehow. But finally I figured out that connections on my $1 breadboard were not wired properly. I changed the breadboard and everything started working right away.
Schematics (updated):
Demo video: (can also be found on YouTube: https://youtu.be/DOUr6JplXHg )
Additional demo video for using save screenshots and changing drawing speed
Couple of screenshots:
and
and
This is how the board looks like:
Arduino code, and NET main module with math and Arduino communication code will be attached soon.
Update: Code on Github: https://github.com/ilvyanyatka/ElectronicArtWithArduino
Before I added "Save screenshot" functionality, the code was cross platform. Now .NET code is Windows specific. To make it cross platform again one need to remove all the functionality related to "Select Windows Dialog" and "Take Screenshot". I am planning to come back to it later.
Electronic_Art.ino.txt.zip
  • fmilburn
    fmilburn over 6 years ago in reply to jw0752 +5
    I thought it was a fun project also. Well done
  • ilvyanyatka
    ilvyanyatka over 6 years ago in reply to jw0752 +4
    Thank you John, will do it tomorrow! I am glad you liked it!
  • ilvyanyatka
    John, I will, because it is so much fun. This projects bring a lot of emotions. When I was working on this one, all of analogRead values for all the pins were totally wrong. I thought I fried both of my…
    beacon_dave over 6 years ago
    Looks great.
    This reminds me a bit of a short course I viewed on the O'Reilly platform which also uses Arduino but with the Processing language to create visual effects through a hardware interface.
    Processing and Arduino in Tandem
    Joseph Gray
    https://www.oreilly.com/library/view/processing-and-arduino/9781449399832/
    Just mentioning it as it may be of interest for various algorithms.
    A while ago, Monash University produced a MOOC on FutureLearn called 'Creative Coding' which was all about generative art which was also interesting
    https://www.youtube.com/watch?v=BFCj8z846ic
    It featured some of the work by Casey Reas REAS.com is a database for Casey REAS  co-founder of the Processing.
    I'm not sure if it is still running or not, or may have been moved elsewhere but was an interesting course.
    On a related note there is also a tutorial on working with the Golden Ratio in graphics here
    https://channel9.msdn.com/Series/Sketchbooktutorial/Trigonometry-for-Designers-Dont-Panic
    It was written using Processing but I was able to follow along in SVG.
    Actually there now appears to be a whole series here:
    which look interesting and may also be of interest.
  • ilvyanyatka
    ilvyanyatka over 6 years ago in reply to beacon_dave
    Dave,
    Wow, thank you so much! It is a lot of very interesting information, I will look thru it.
    I am very interested to see the other algorithms. Mine is just a simple math, calculating the next point and drawing a line there.
  • ilvyanyatka
    Dave,
