Energy Harvesting
  • Energy Harvesting
Energy Harvesting
Blog Soil Battery for Forest Fire Detection System
Join Energy Harvesting to participate - click to join for free!
  • Author Author: pratyush_cetb
  • Date Created: 13 Oct 2019 4:28 AM Date Created
  • Views 2958 views
  • Likes 14 likes
  • Comments 7 comments
  • energyharvestingch
  • fire
  • forest
  • bme680
pratyush_cetb
pratyush_cetb
13 Oct 2019
  • three-phase
    three-phase over 7 years ago +6
    This is a very interesting project. I couldn't work out what powers the cluster heads and gateways though. Do they not need to be power continually to be able to receive from the sensors and forward the…
    dubbie over 7 years ago +5
    An interesting idea, should be useful for remote areas. Dubbie
    jw0752 over 7 years ago +4
    I liked your idea and presentation. Why choose microbial power as opposed to solar? Will this technology be limited to temperate areas and low altitude areas where the ambient temperature remains above…
  • pratyush_cetb
    pratyush_cetb over 7 years ago in reply to mudz
    Sir here we are using a recovery diode PMEG4002 in between the voltage booster and super capacitor .
  • mudz
    mudz over 7 years ago in reply to jw0752
    I believe this is rather a good concept if it is implemented properly and correctly. We can't only rely on solar energy all the time. Moreover, combining other green energy sources and this one, it would be a great workaround to use lost energy more efficiently.
    pratyush_cetb Though, there are some points like, if maximum voltage of MFC which 1.16 volts( from chart, which I assume are logged from this MFC project readings) than how come did you managed to charge super capacitor and that too with low current. Also, Creating MFC video is not clear on how you did it. And somehow everything worked as you've shown in video.
    A bit confusing for me.
    -Mudz
    I liked your idea and presentation. Why choose microbial power as opposed to solar? Will this technology be limited to temperate areas and low altitude areas where the ambient temperature remains above 0 C? Do you have an alternative to microbial for the areas where the temps drop below 0C?
  • pratyush_cetb
    pratyush_cetb over 7 years ago in reply to three-phase
    We have designed the power management scheme as the microbial fuel cell will charge the supercapacitors in every 20 minutes and then wake up sensor node sense the data for 50 seconds and start charging again. And this cycle goes on.
  • pratyush_cetb
    pratyush_cetb over 7 years ago in reply to dubbie
    Ya energy harvesting is done mostly done in areas where there is an absence of relaible power source.
