Project14
Project14
Forum Beaglebone AI uart enable
  • News
  • Member Updates
  • Competitions
  • Theme Suggestions
  • Replies 16 replies
  • Subscribers 204 subscribers
  • Views 4413 views
bhome
bhome over 6 years ago
Hi Everyone,
                           I am new to Beaglebone boards, I have Beaglebone AI, I am able to update its image and followed instructions on BeagleBone AI Survival Guide | element14 | Vision Thing , now I am not able to enable uart to check uart using loopback test, kindly help me out.
  • bhome
    bhome over 6 years ago in reply to aswinvenu +1
    Hi, I have added above line in uEnv.txt file save it and reboot the system, and have got the result on bash window as below, debian@beaglebone:/var/lib/cloud9$ ls -l /dev/ttyO* lrwxrwxrwx 1 root root 5…
  • aswinvenu
    aswinvenu over 6 years ago in reply to bhome +1
    It's also a best practice to keep this as a different thread (Create a new thread in the forum). It will get better reach when others search for the same question. Regards, Aswin
  • bhome
    0 bhome over 6 years ago in reply to aswinvenu
    Hi Aswin,
                    I have added file referred in https://github.com/beagleboard/beaglebone-ai/issues/37 but my dts file is not compiled and gives an error . so unable to generate a new dtb file.
  • aswinvenu
    0 aswinvenu over 6 years ago in reply to bhome
    Hi Mahesh,
    I don't have a Beaglebone AI with me now. Else I would have tried it and gave you the working solution.
    I remember few months back we had a roadtest on BB AI. I would like you to comment below one of the roadtest. So the roadtester may help you with this.
    I would also recommend you to get in touch with the Beagle IRC chat group. Ask you question there as well.
    https://beagleboard.org/chat
    Aswin
  • bhome
    Hi aswin,
                     i am able to enable UART. now ia mworking with I2C, i have  interface Ds1307 RTC and use  I2C for read DS1307. i am able to read time and date, but not able to set time and date using I2C help me out on same.
    Thanks and regards,
    Mahesh
  • aswinvenu
    If you are able to read from the DS1307, That means the  I2C communication is working fine. The reason you are not able to set the date and time
    is probably because you are not following the datasheet.
    Can you share the code ? Then I can take a look.
    Aswin
  • aswinvenu
    Aswin
  • aniljade2019
    0 aniljade2019 over 5 years ago
    Hello Aswin venu,
    I have enabled the UART 3 in Beaglebone AI using the link you shared
    .But i have one issue here. After compiling the new dts file to create a new dtb file with uart 3 enabled. the CPU frequency is not remaining  fixed to what i have set using the cpupower utility. I have set 1500MHz max frequency but it dynamically changes to lower 400MHz. then 1000MHz.
    How ahould i fixed that in new dts file. Can you help me?
    customdtb.zip
