Project14
Project14
Forum Beaglebone AI uart enable
  • News
  • Member Updates
  • Competitions
  • Theme Suggestions
  • Replies 16 replies
  • Subscribers 204 subscribers
  • Views 4487 views
bhome
bhome over 6 years ago
Hi Everyone,
                           I am new to Beaglebone boards, I have Beaglebone AI, I am able to update its image and followed instructions on BeagleBone AI Survival Guide | element14 | Vision Thing , now I am not able to enable uart to check uart using loopback test, kindly help me out.
  • bhome
    bhome over 6 years ago in reply to aswinvenu +1
    Hi, I have added above line in uEnv.txt file save it and reboot the system, and have got the result on bash window as below, debian@beaglebone:/var/lib/cloud9$ ls -l /dev/ttyO* lrwxrwxrwx 1 root root 5…
  • aswinvenu
    aswinvenu over 6 years ago in reply to bhome +1
    It's also a best practice to keep this as a different thread (Create a new thread in the forum). It will get better reach when others search for the same question. Regards, Aswin
  • aswinvenu
    0 aswinvenu over 6 years ago
    Are you talking about the serial debug port available on board or peripheral UART ports available on the cape?
    Please give some more information of what you are trying to do.
    BTW shabaz has written a really nice "Getting started" article last year. Please refer that as well. BeagleBone AI (BB-AI) - Getting Started
    Aswin
  • bhome
    0 bhome over 6 years ago in reply to aswinvenu
    Thank you, sir,
                           I am able to read analog pins and run blink led code using Cloud9, now I start configuring UART for transmission and reception of data. but capemgr directory is missing in /sys/devices directory please help me on the same.
  • aswinvenu
    0 aswinvenu over 6 years ago in reply to bhome
    Did you enable the cape peripherals on the uboot config file?
    If no please enable that.
    go to vi /boot/uboot/uEnv.txt
    and enable the peripherals u want.
    cape_enable=capemgr.enable_partno=BB-UART1,BB-UART2,BB-UART4, BB-UART5
    Reboot the system and look for the new serial tty devices.
    ls -l /dev/ttyO*
    Let me know if this worked.
    Aswin
  • bhome
    Yes sir,
                     i have tried with option but i am not getting cape_enable=capemgr.enable_partno=BB-UART1,BB-UART2,BB-UART4, BB-UART5  this in /boot/uboot/uEnv.txt.
    my uEnv.txt file looks like as below,
    Docs: http://elinux.org/Beagleboard:U-boot_partitioning_layout_2.0
    uname_r=4.14.108-ti-r135
    #uuid=
    dtb=am5729-beagleboneai-custom.dtb
    cmdline=coherent_pool=1M net.ifnames=0 rng_core.default_quality=100 quiet
    #In the event of edid real failures, uncomment this next line:
    #cmdline=coherent_pool=1M net.ifnames=0 rng_core.default_quality=100 quiet video=HDMI-A-1:1024x768@60e
    ##enable Generic eMMC Flasher:
    #cmdline=init=/opt/scripts/tools/eMMC/init-eMMC-flasher-v3-no-eeprom.sh
  • bhome
    0 bhome over 6 years ago in reply to bhome
    Also i am getting some errors at below point while updating board using BeagleBone AI Survival Guide | element14 | Vision Thing
    Install BoneScript and setup a pin for use:
    cd /usr/local/lib⏎
    sudo npm install --unsafe-perm bonescript@0.7.4-beta1⏎
    node -pe "require('bonescript').bone.getPinObject('p9.15').ai.gpio"   (this sets up the pin in /sys/class/gpio)
  • aswinvenu
    Can you add this line to the end of the file ?
    and try??
  • bhome
    lrwxrwxrwx 1 root root 5 Jun 10 05:05 /dev/ttyO0 -> ttyS0
    lrwxrwxrwx 1 root root 5 Jun 10 05:05 /dev/ttyO5 -> ttyS5
  • aswinvenu
    Hi Mahesh,
    Which means that serial O0 and O5 are enabled. Can you write some python script to test the echo feature ?
    Short the RX and TX pins using a jumper wire. Send and receive characters on the same UART.
    Aswin
  • bhome
    Hi Aswin,
                   I have shorted RX and TX of UART5 which pin no. P9.11 and P9.13. and test on minicom, but I am not getting any echo when I have typed on keyboard. one more question that serialO5 is UART5 or anything else.
  • aswinvenu
    Interesting! I think you have to change the pin musing in the device tree file.
    Follow this:
    https://github.com/beagleboard/beaglebone-ai/issues/37
    Also please confirm the pin mapping using "show-pins" command.
    Aswin
