Project14
Project14
Forum Submitting an entry?
  • News
  • Member Updates
  • Competitions
  • Theme Suggestions
  • Answers 2 answers
  • Subscribers 202 subscribers
  • Views 2415 views
Andrew J
Andrew J over 5 years ago
Apart from following the rules and guidelines for a submission, is there anything special that has to be done? I created a blog entry by clicking on “submit an entry” from the theme page, but it’s not clear if it’s in or not.  Other entries seem to have a project14 banner with ‘submit an entry’ links and my post is bereft of such decoration.  I’d hate to miss the deadline by failing to do something!
  • fmilburn
    fmilburn over 5 years ago +3 verified
    Hi Andrew, "Submit an entry" is the proper way to do it. It looks like you did everything correctly. Your entry shows "diytestinstrumentationch" in the tags and it also shows up in the project entry list…
  • Andrew J
    Andrew J over 5 years ago in reply to fmilburn +2
    Thanks Frank. I did look to see if there was a list, how did you find it? My post is definitely in that content place rather than personal space.
  • fmilburn
    fmilburn over 5 years ago +2 suggested
    Click on the Project14 title on the welcome page, it has a hyperlink to the list
  • fmilburn
    0 fmilburn over 5 years ago
    Hi Andrew,
    "Submit an entry" is the proper way to do it.  It looks like you did everything correctly.  Your entry shows "diytestinstrumentationch" in the tags and it also shows up in the project entry list.
    I don't think it makes a difference to project entry but to display the entry banner make sure to select the entry location as "DIY Test Instrumentation" instead of "Your personal blog" as shown below.
    Tariq will pick it up when he summarizes project entries but if you don't see that happen then just ping him.
    Frank
  • Andrew J
    0 Andrew J over 5 years ago in reply to fmilburn
  • fmilburn
  • Andrew J
    I think I misunderstood and mistook the list you meant for a generated set of recent content because some of the items in the list aren't in DIY Test Instrument - they do have the hashtag though.
    0 Jan Cumps over 5 years ago in reply to Andrew J
    Andrew J  wrote:
    ... because some of the items in the list aren't in DIY Test Instrument - they do have the hashtag though.
    They are from the previous DIY month, a few years ago.
