Fighting Germs
  • Fighting Germs
Fighting Germs
Blog Corona Cap
Join Fighting Germs to participate - click to join for free!
  • Author Author: dougw
  • Date Created: 3 Apr 2020 6:34 AM Date Created
  • Views 4242 views
  • Likes 18 likes
  • Comments 21 comments
  • doug wong
  • pandemic
  • fightinggermsch
  • anti-virus
  • covid-19
  • 3d printed mask
  • corona cap
  • corona virus
Corona Cap
dougw
dougw
3 Apr 2020
After seeing some 3D printed masks, I was inspired to make a simple one that could clip onto the brim of a baseball cap. It turned out to be a very lightweight transparent barrier that can prevent spray from reaching your face and prevent your spray from getting on someone else. The 3D printed frame simply clamps a photocopier transparency in a curved shape and clips it to the brim of a hat. You can also wear a filter style mask under it, if you need more protection.
It fits differently on different hat brims, but it can be positioned reasonably on most of them....
Flatter brims work better with this design....
Here it is on a Med-Eng cap
Here it is on an element14 cap.
If you want to try this build, there are 3 .stl files in the attached .zip file.
One file is the curved rail that everything mounts to.
One file has the two clips that attach the rail to the cap brim.
One file has three small clips to attach the transparency to the rail.
My other ideas for fighting viruses are here:
Anti-Virus Ideas
Stay safe....
CovidMask.zip
CapMaskSTL.zip
  • ntewinkel
    ntewinkel over 6 years ago in reply to fmilburn +7
    Good point. I'm always touching my face. With a face shield I might not need my cone anymore!
    dubbie over 6 years ago +5
    Looks a good lightweight solution. How is the plastic sheet optically? Does it make it a bit blurred? Dubbie
  • ntewinkel
    ntewinkel over 6 years ago in reply to dougw +5
    Thanks Douglas! I printed out a set using your gcode files, after replacing the header with one from my own prints (there were subtle differences. I'm not sure if they mattered). I'm having trouble with…
    Dubbie
    • Vote Up +5 Vote Down
