Home Automation
  • Home Automation
Home Automation
Forum Esp32 failed to connect to Mosquitto MQTT Broker
Join Home Automation to participate - click to join for free!
  • Subscribers 8 subscribers
  • Views 5417 views
waxore
waxore over 5 years ago
Hello everybody I'm facing a problem in my home automation project that is based on a mosquito mqtt broker that needs to connect to some clients on the same network (node red, esp32, mqtt client app on the phone) but the problem that whenever I try to connect to the server form outside the hosting machine I fail. For example the connexion to node red that is executed on the same machine as the mqtt server is working like a charm but Any other client on the same network is blocked . I tried to create a new rule in firewall to open the 1883 port, but when I do a test using Nmap I find that the port is filtered. Also, I had some difficulties accessing the config file for mosquitto in this latest version can anyone help me please
Any other client on the same network is blocked .I tried to create a new rule in firewall to open the 1883 port, but when I do a test using Nmap I find that the port is filtered. Also, I had some difficulties accessing the config file for mosquitto in this latest version can anyone help me please
    shabaz over 5 years ago +2
    Hi, There must be many answers to this, depending on what you're running the server on. I really think google is your best friend here. For example, see the answer here, which lists the steps to resolve…
  • ntewinkel
    ntewinkel over 5 years ago +2
    Hi Waxore, I actually just set up a Raspberry Pi with Node-Red and Mosquitto, and set up a Wemos D1 Mini ESP8266 to connect to Mosquitto to report sensor data via MQTT. Similar to you, I was able to test…
  • waxore
    waxore over 5 years ago +1
    Thank you for your response Shabaz just to share the solutions that worked for me, I was able to found a node in node red that can run a market broker called Aedes broker other than that I have searched…
    For example, see the answer here, which lists the steps to resolve it on 'ufw' firewall if that is what your Linux machine is running.
    https://stackoverflow.com/questions/54878001/cannot-get-mosquitto-to-allow-connection-from-outside-local-network
    If your server is running on a different Linux distribution with something else, then search for that version of Linux as part of your search term.
  • waxore
    Thank you for your response Shabaz just to share the solutions that worked for me, I was able to found a node in node red that can run a market broker called Aedes broker other than that I have searched every corner in google but I think it might be a problem with the compatibility of the latest version of mosquitto with my windows 10
    Thank you again
  • ntewinkel
    Hi Waxore,
    Similar to you, I was able to test MQTT on the Raspberry Pi itself, but the ESP board could not connect.
    Turns out I have my Raspberry Pi plugged into the wired ethernet in my house, and I was connecting the ESP board to the guest WiFi network. The guest network is purposely separated from my main home network for security reasons. Once I switched the ESP over to connect to my internal home network WiFi, it all works properly now.
    Hoping yours is as easy a fix!
    Best of luck,
    -Nico
