Making Time
  • Making Time
Making Time
Blog (Modified) Work Clock
Join Making Time to participate - click to join for free!
  • Author Author: dwinhold
  • Date Created: 29 Nov 2020 6:28 PM Date Created
  • Views 4293 views
  • Likes 10 likes
  • Comments 13 comments
  • makingtimech
  • work clock
  • dwinhold
dwinhold
dwinhold
29 Nov 2020
I am presenting the, "(Modified) Work Clock"
How often are you at work and feel:
     The time is just dragging on?
     Will this day ever end?
     I wish our lunch break is longer?
I would say every one of us feels this way now and then. I have the solution for this!!
The (Modified) Work Time Clock
Here is how it works: (This is set for my work day)
00:00:00 - Midnight - Personal Time (1 second = 1.1666667 seconds)
to
06:59:59
07:00:00 - Work Time (1 second = .6666667 seconds)
to
11:59:59
12:00:00 - Lunch Break (1 second = 1.1666667 seconds)
to
12:29:59
12:30:00 - Work Time (1 second = .6666667 seconds)
to
15:29:59
15:30:00 - Personal Time (1 second = 1.1666667 seconds)
to
00:00:00
Work clock math:
So, with the Modified Work Clock you now work only 5.3 hours a day and have 18.7 hours of personal time. This clock still keeps your day at 24 hours but changes the actual time you worked and your personal time.
With Project14's theme being "Making Time Change", this does it!!
Below is the Arduino code for the clock:
//Digital Arduino Work Clock
//By Dale Winhold
//Project14 Making time change
//Nov 29,2020
#include <LiquidCrystal.h>
LiquidCrystal lcd(12,11,5,4,3,2);
int h; //Hours
int m; //Minutes
int s; //Seconds
const int hs=6; //Hour set pin
const int ms=7; //Minutes set pin
int Hset;
int Mset;
void setup()
  lcd.begin(16,2);
  pinMode(hs,INPUT_PULLUP);
  pinMode(ms,INPUT_PULLUP);
void loop()
 lcd.setCursor(0,0); //Set lcd start print to 0,0
 s=s+1;
 lcd.print("TIME:");
 lcd.print(h);
 lcd.print(":");
 lcd.print(m);
 lcd.print(":");
 lcd.print(s);
//at work 7am to 12pm : 1 second=.6666667 seconds
 if(h>=7 && h<12){
  delay(666.6667);
  lcd.clear();
    if(s==60){
      s=0;
      m=m+1;
    if(m==60){
      m=0;
      h=h+1;
    if(h==24){
      h=0;
  lcd.setCursor(0,1); //Set lcd start print to 0,1
  lcd.print("Work Time");
//at work 12:30pm to 3:30pm : 1 second=.6666667 seconds
else if((h==12 && m>29) || h==13 || h==14 || (h==15 && m<30)){
    delay(666.6667);
    lcd.clear();
      if(s==60){
        s=0;
        m=m+1;
      if(m==60){
        m=0;
        h=h+1;
      if(h==24){
        h=0;
//off work : 1 second=1.1666667 seconds
else{
  delay(1166.6667);
  lcd.clear();
    if(s==60){
      s=0;
      m=m+1;
    if(m==60){
      m=0;
      h=h+1;
    if(h==24){
      h=0;
    lcd.print("Personal Time");
//-------Time
// setting-------//
Mset=digitalRead(ms);
if(Mset==0){
  s=0;
  m=m+1;
Hset=digitalRead(hs);
if(Hset==0){
  h=h+1;
A video of the time changing from personal time to work time. (Notice the difference in the seconds):
Rough sketch of the setup:
I really hope you like this project on "Making Time Change"
Dale Winhold
  • kmikemoo
    kmikemoo over 5 years ago +5
    dwinhold Boss, you've got it all backwards! The clock is supposed to run faster during the work day! Seriously though, I love the creativity. On some days... it really feels like the clock has two time…
  • dwinhold
    dwinhold over 5 years ago in reply to kmikemoo +4
    It is actually quite funny, I started to go over my chart in detail after I sent the reply. It took me a bit to figure out how that works out, I still am having issues. It looks good, works on paper and…
  • Fred27
    Fred27 over 5 years ago +4
    A really fun project. It reminds me a little of a clock someone wrote back in the day when I used to code as a contractor on an hourly rate. The clock started at £0.00 (or $0.00 or €0.00 as appropriate…
  • kmikemoo
    dwinhold image  Boss, you've got it all backwards!  The clock is supposed to run faster during the work day!  Seriously though, I love the creativity.  On some days... it really feels like the clock has two time constants. image imageimage
    • Vote Up +5 Vote Down
  • dwinhold
    Hi Mike,
    Ohhh, but it does run faster during work time!!! The 8 hour work day is cut down to 5.3 hours. I actually took the clock to work today and set the time when I got here (6:40am). The real time here is 12:20pm but the work clock says 2:26pm which is an hour (or 40 minutes of modified time) until home time. Then the clock will slow down until 7am tomorrow. My boss was quite amused with it, he said he'll pay me to change the time clock in the shop to do the opposite. I'm getting a good reaction out of the staff here!! image
  • kmikemoo
    kmikemoo over 5 years ago in reply to dwinhold
    dwinhold  Your reply made me blurt out a huge belly laugh!!!  Guess I understood the chart wrong.  I'm still chuckling. Awesome idea. image
  • kmikemoo
  • dwinhold
    It is actually quite funny, I started to go over my chart in detail after I sent the reply. It took me a bit to figure out how that works out, I still am having issues. It looks good, works on paper and the clock is working correctly but I realize that Real time noon won't be noon on the clock as it shows on my chart. So clock time 7am is actually 8:12am real time and clock time noon is actually 11:30am real time. Hmmmmm, messing with time is messing with my head. image
  • hugohu
    hugohu over 5 years ago in reply to dwinhold
    Well, are you sure your head isn't a computer and it uses a clock?
    And if you tamper with clocks... and time...
  • dwinhold
    dwinhold over 5 years ago in reply to hugohu
    A While ago I made a clock that ran backwards. It really messes with your day!!
  • hugohu
    oh...... I'd certainly love one of those!
