Mixing Electronics & Water
  • Mixing Electronics & Water
Blog Project: Flush-A-Vader
Join Mixing Electronics & Water to participate - click to join for free!
  • Author Author: beagles
  • Date Created: 17 Dec 2017 6:53 PM Date Created
  • Views 2351 views
  • Comments 8 comments
  • ardunio
  • arduino_projects
  • motion-control
  • conservation_projects
  • mixewaterch
beagles
beagles
17 Dec 2017
Aim:
To build a device that will remind people not to flush anything but toilet paper once they have finished their business.
The UK is being hit with the soft wet wipe style tissues that are advertised as flushable and other products such as cotton buds that are entering the sewage styles and causing blockages and equipment failures. In the fight to raise awareness of these issues I want to build the Flush-A-Vader.
Equipment:
Arduino Uno
Ardunio adafruit wave shield
Speaker
Motion sensor (I have two to try)
Proposed Design:
Proposed Method:
Step 1: Solder the Wave shield together
Step 2: Record message and import onto shield
Step 3: Get speaker wired up and working
Step 5: Work out how to use a motion sensor
Step 6: Link all together and house in a decorated cardboard tissue box
Wish me luck! :-)
    jw0752 over 8 years ago +2
    Hi Kaylee,Here is an inexpensive IR kit that could be used to trigger the message. This is very similar to the IR detectors used in faucets and towel dispensers. I built one for the fun of it and it works…
    DAB over 8 years ago +1
    Interesting project. I look forward to seeing your idea put into practice. DAB
    beacon_dave over 8 years ago +1
    Good luck ! If you get stuck there is quite a good tutorial series here on Element14: Jeremy Blum Arduino Tutorials which may be of some help to you. There is also a good cookbook available by Michael…
    mcb1 over 8 years ago
    2nd edition download
    https://github.com/shihyu/Arduino/blob/master/books/Oreilly.Arduino.Cookbook.2nd.Edition.Dec.2011.pdf
