Photography
  • Photography
Photography
Blog Lightning strike photos
Join Photography to participate - click to join for free!
  • Author Author: helium5793
  • Date Created: 17 Jul 2021 12:35 PM Date Created
  • Views 1945 views
  • Comments 8 comments
  • photographych
  • canon camera
  • lightning
helium5793
helium5793
17 Jul 2021
My intention is to make a circuit that can see the increase in brightness of a lightning strike and trigger a canon camera to photograph it before it fades.  I have partially succeeded in this several years ago, but need to look up my current circuit, describe it and see about improving it.
A list of needs:
appropriate sensor
arduino to control it
camera interface
protection from bad weather.
Portable power.
john
    DAB over 5 years ago +5
    Having done lightning photography, I have won awards with some of my shots, here are some things to consider. Most lightning lasts about one second and generates repeated strikes at about 38 HZ, which…
    beacon_dave over 5 years ago in reply to DAB +3
    Even more fun if you have a high speed camera lying around Lightning Strike at 103,000 FPS - YouTube ( Just need to setup on the correct side of the hotel ! )
    dougw over 5 years ago +2
    https://www.electroschematics.com/lightning-detector/
    Most lightning lasts about one second and generates repeated strikes at about 38 HZ, which will give you an idea about your timing requirements.
    I use the technique where I just open the shudder and watch what happens in front of the camera.
    Use your highest f stop.
    Depending upon the camera you use, you can keep the shutter open up to about 1 minute before you begin to get background lighting show up.
    Some rigs I have seen use an RF receiver to pick up the first strike and then open the shudder.
    With some inexpensive digital cameras, you can set them up to do repeated exposures automatically. This approach works, but you have to sort through a lot of dark frames, though you could use OpenCV and automatically search for any light instance above background.
    Have fun and keep safe. Lightning does kill.
    • Vote Up +5 Vote Down
