Proving Science
  • Proving Science
Proving Science
Blog Measuring the speed of sound
Join Proving Science to participate - click to join for free!
  • Author Author: kk99
  • Date Created: 2 Aug 2020 1:29 PM Date Created
  • Views 4211 views
  • Likes 12 likes
  • Comments 12 comments
  • provingsciencech
  • science
  • speed of sound
  • audacity
kk99
kk99
2 Aug 2020
Basic concept is to measure the speed of the sound using echoes and with the microphone build in notebook.
Apparatus and materials:
1. Notebook or device with microphone,
2. Sound editor e.g. Audacity
3. Paper or other material tube with known length (in my case 70 cm length tube)
Procedure:
1. Place the tube is closest to possible to the microphone and start recording with possible highest sampling rate (in my case 19200 samples),
2. Make sound by clapping hands or whistling,
3. With the sound editor find the first sound and its echo then measure time difference between them. The speed of sound could be calculated from below formula: speed = (2 * length of tube) / time. If you use difference in samples you could get time value by dividing this difference by sampling rate e.g. 750 / 192000.
At the of the measurement the speed of sound should be around 350 m/s relative to air temperature.
Below there is video with sample calculation of sound speed with usage of Audacity editor:
    jw0752 over 6 years ago +7
    Very nice experiment. I bet one could do something similar using a simultaneous light and sound emission with an audio and light pick up a known distance away and monitored by the oscilloscope. The idea…
    balearicdynamics over 6 years ago +4
    Nice experiment, very appreciated the simple setup and the results
  • colporteur
    colporteur over 6 years ago +4
    Friggin (can you say that) awesome! Simple experiment that has real practical value for the visual learner. Nice job kk99 .
    dougw over 6 years ago
    Interesting experiment. If the tube is open ended, do you still get a good reflection?
  • kk99
    kk99 over 6 years ago in reply to dougw
    I have not tested this case but probably there will be a reflection from nearby wall.
    dougw over 6 years ago in reply to kk99
    There should be some sort of reflection from the end of the open tube because of the acoustic impedance mismatch at that plane.
