Simple Electronic Repairs
  • Simple Electronic Repairs
Blog Repair of tone control circuit in old transistor radio
Join Simple Electronic Repairs to participate - click to join for free!
  • Author Author: kk99
  • Date Created: 6 Nov 2017 4:12 PM Date Created
  • Views 6232 views
  • Comments 9 comments
  • backtoanalogch
  • simpleelectronicch
  • restorerepairch
kk99
kk99
6 Nov 2017
Monthly project competitions, chances to earn prizes, you decide project themes, your ideas, your projects, turn ideas into projects.
Project14 Home
Monthly Themes
Monthly Theme Poll
I have an old radio ITT Schaub-Lorenz Touring International 103 which had small issue with bass control circuit. Issue was caused by "cold joint" around the potentiometer used for bass regulation.
Here are steps of the radio disassembly:
1. Remove the knobs from top panel.
2. Unscrew all screws from rear panel.
3. Unscrew all screws from top panel.
4. Remove rear panel.
5. Unscrew two screws located near the handle.
6. Remove front panel. Be careful because speakers are connected with wires to main board.
Debugging part.
After short analysis of part of schematic related to tone control circuit and quick measurements of continuity I have found that issue was caused by "cold joint". There was no connection between of R334 potentiometer and C388 capacitor. The "cold joint" was marked by red square on one of following pictures.
After re-soldering of this joint, the issue was fixed. Here is short video of disassembled radio.
Here is short video after issue fix.
    jw0752 over 8 years ago +4
    I wonder how much of this great equipment ends up in the trash each year for lack of someone to just do a small repair like this? Nice job. John
  • kk99
    kk99 over 8 years ago in reply to e14phil +4
    Hi Phil, According to schematic it is printed inductor and it is part of intermediate frequency circuit. Here is this part of schematic: Here is corresponding part of PCB layout: Additionally everything…
    DAB over 8 years ago +3
    Nice example of a legacy equipment repair. DAB
    mcb1 over 8 years ago
    Nice detail of a relatively simple repair.
    There is far too much good equipment thrown away, when a few dollars, some time and a bit of know how will restore it to service.
    It's a lot easier when you have the schematic and service information, and this is becoming scarce nowdays.
    Well done.
    Well done.
