Simple Electronic Repairs
  • Simple Electronic Repairs
Blog Repair of tone control circuit in old transistor radio
Join Simple Electronic Repairs to participate - click to join for free!
  • Author Author: kk99
  • Date Created: 6 Nov 2017 4:12 PM Date Created
  • Views 6241 views
  • Comments 9 comments
  • backtoanalogch
  • simpleelectronicch
  • restorerepairch
kk99
kk99
6 Nov 2017
Monthly project competitions, chances to earn prizes, you decide project themes, your ideas, your projects, turn ideas into projects.
Project14 Home
Monthly Themes
Monthly Theme Poll
I have an old radio ITT Schaub-Lorenz Touring International 103 which had small issue with bass control circuit. Issue was caused by "cold joint" around the potentiometer used for bass regulation.
Here are steps of the radio disassembly:
1. Remove the knobs from top panel.
2. Unscrew all screws from rear panel.
3. Unscrew all screws from top panel.
4. Remove rear panel.
5. Unscrew two screws located near the handle.
6. Remove front panel. Be careful because speakers are connected with wires to main board.
Debugging part.
After short analysis of part of schematic related to tone control circuit and quick measurements of continuity I have found that issue was caused by "cold joint". There was no connection between of R334 potentiometer and C388 capacitor. The "cold joint" was marked by red square on one of following pictures.
After re-soldering of this joint, the issue was fixed. Here is short video of disassembled radio.
Here is short video after issue fix.
    jw0752 over 8 years ago +4
    I wonder how much of this great equipment ends up in the trash each year for lack of someone to just do a small repair like this? Nice job. John
  • kk99
    kk99 over 8 years ago in reply to e14phil +4
    Hi Phil, According to schematic it is printed inductor and it is part of intermediate frequency circuit. Here is this part of schematic: Here is corresponding part of PCB layout: Additionally everything…
    DAB over 8 years ago +3
    Nice example of a legacy equipment repair. DAB
    shabaz over 8 years ago
    Awesome repair log. Thanks for showing the board detail too, it was nice to see the little touches, the designers had fun : )
    I have a (far less exotic) pocket radio to repair sometime, it has some noisy slider volume controls : (
  • e14phil
    e14phil over 8 years ago in reply to shabaz
    What a beautiful PCB, is anyone aware if the 3 spirals on the left have any function other than artistic flair?
  • e14phil
    shabaz over 8 years ago in reply to e14phil
    Hi Phil,
    I'm only guessing, but probably it is partial artistic flair : ) and maybe partially acting like an inductor, it was common to put a very tiny ferrite bead on a transistor leg, if there was a risk of it oscillating. I can't tell if this is on a transistor leg, but it is possible the designers saved the ferrite and made the pattern instead. Since there are three of them, it could be a high gain RF amplifier portion maybe.
    I quite like the octopus above it : ) and the inverted earth symbol or Xmas tree : )
  • kk99
    Hi Phil,
    Additionally everything depends on version of radio because here are the same parts of schematic and PCB from older version (1968/1969).
    Schematic:
    PCB layout:
