Simple Music Maker
  • Simple Music Maker
Simple Music Maker
Blog Old fashioned Japanese Music Box
Join Simple Music Maker to participate - click to join for free!
  • Author Author: Workshopshed
  • Date Created: 4 Jun 2018 4:50 PM Date Created
  • Views 24712 views
  • Likes 16 likes
  • Comments 6 comments
  • musicmakerch
  • musictimech
Workshopshed
Workshopshed
4 Jun 2018
Today you can put a Rasperry Pi Zero or PocketBeagle in a project and have the resources of a whole computer to control your project.
When I was a lad, all we had were a few chips and transistors. One of my favourites was the 555 timer so I decided to use two for this little project which was origionally created for a tutorial in Hackspace Magazine.
A mechanical music box is controlled with 556 chip (dual 555), a transistor and a few discrete components. It is triggered by a capacitive touch module which has an active high output.
A simple transistor switch inverts the signal and triggers the first 555. This is configured as a monostable and runs for a few seconds. The second 555 is configured as an astable with a diode in the timing circuit to make it perform as a PWM generator. This allows speed control of the motor which is driven by a transistor.
The motor was a modified microservo, the mechanics were adjusted so that it could run continuously and the control circuit was removed and replaced with a simple capacitor, with the above circuit providing the control.
A simple wooden box was made for the housing and a tune from a popular Japanese animation was played on the hand cranked music mechanism.
    jw0752 over 8 years ago +3
    Hi Andy, I really liked your use of the 556 timer chip. For some reason using basic chips appeals to me as opposed to microprocessors for everything. Thanks John
  • Workshopshed
    Workshopshed over 8 years ago in reply to jw0752 +3
    Cheers John, when I grew up the 555, CMOS 4000 series logic and a 741 were what I had. Many variations of a 555 + 4017 were created.
    genebren over 8 years ago +2
    Clever design. I really like the servo motor crank approach to drive the music box mechanism. Very cool! Gene
    Hi Andy,
    Thanks John
  • Workshopshed
  • Workshopshed
