Solar Power Devices
  • Solar Power Devices
Solar Power Devices
Blog Simple Solar BOT  ----Blog 3
Join Solar Power Devices to participate - click to join for free!
  • Author Author: snidhi
  • Date Created: 18 Aug 2018 11:52 AM Date Created
  • Views 3411 views
  • Likes 10 likes
  • Comments 5 comments
  • solar_panel
  • solarbot
  • ardexpert
  • arduino_classic
  • conservation_projects
  • solar_power
  • solarpwrdevicesch
snidhi
snidhi
18 Aug 2018
Solar Power Devices
Enter Your Electronics & Design Project for Your Chance to Win a Grand Prize for the most inspiring project or a $100 Shopping Cart!
Project14 Home
Monthly Themes
Monthly Theme Poll
This week was not blessed with much sun in North Germany. I focused on testing different sensors and motor drivers with Arduino Nano board.
  • Testing Solar Panels powering Arduino Nano
  • The Sensors Test Setup Plan
  • Learning to use Arduino
Powering up the Nano with Solar panels
imageNote: Next time must add some diodes for security to keep the controller safe.
Blinking LEDs with Solar Power
The test plan
Testing the Sensors
DHT 11 Sensor with Arduino
Upcoming..
  • Test the different motors to drive the bot and to find the least power hungry.
  • Building the mechanics of the Solar BOT.
    genebren over 8 years ago +3
    Nice update on your solar powered project entry. Care should be taken to insure that over light loads that the solar panel output voltage remains in safe region. This can be achieved in similar manner…
    jw0752 over 8 years ago +2
    Hi Sneha, I am assuming that you are using the bread board for display of the components for this presentation as many of your placements are meaningless electronically. John
  • 14rhb
    14rhb over 8 years ago +1
    Nice work - if you win I think you need to buy a bigger breadboard Rod
    Nice update on your solar powered project entry.  Care should be taken to insure that over light loads that the solar panel output voltage remains in safe region.  This can be achieved in similar manner as fmilburn  did on his Solar Bubble Blaster project, or through the use of a switchable load (like a resistor or LED) which can keep the open circuit voltage in a reasonable range.
    Good luck on your continued progress on your project (and on getting some sunlight for testing your robot).
    Gene
    Gene
