Spring Clean!
  • Spring Clean!
Spring Clean!
Spring Clean Projects 2025 Vintage Dual Turntable Restoration
  • News and Projects
Join Spring Clean! to participate - click to join for free!
  • Date Created: 9 Jun 2025 9:37 AM Date Created
  • Views 4164 views
  • Likes 13 likes
  • Comments 20 comments
  • vintage
  • turntable
  • vinyl
9 Jun 2025
I bought a broken Dual turntable a few summers ago, as a summer holiday fun restoration project. And then didn't do anything with it. An ideal candidate for  Spring Clean! .
Facts:
The DUAL 1218 is an early 1970s model.
  • 33 / 45 / 78 rpm
  • full automatic, handles 7, 10 and 12" size records
  • anti-skate and needle pressure adjustment
  • stacker, can handle up to 6 LPs
  • middle of the range. It has all options, but a smaller turntable platter.
It's an idler model - a rubber wheel transfers power from motor to turntable. Like all DUALs of the time, the automation is fully mechanic: wheels, cogs, levers, friction.
Also typical to DUAL, the tonearm construction is very light, and the advised stylus force - with the Shure system it's shipped with - is just 1 gram.
What was wrong
In general: nothing worked. All levers were stuck, none of the automations worked. Motor didn't start. The platter didn't turn smoothly. And the stylus was broken.
Physically, there was damage to the acrylic lid. There was some damage to the arm. And the headshell plastic was brittle.
Most of the symptoms are to be expected. Most of the mechanic is frozen in place because lubricants got sticky or dried out. Some of the finer plastic components are brittle now, on all those tables - whether the table has been used, or is new old stock that never left the original box.
Restoration work: automation
Applying new grease and oil will not fix the table. The only way to get it back to functional, is to tear it down. Then remove all existing lubricants, and apply new one when putting it back together. Some parts, such as the power switch mechanism, are frozen together because of dried oil. Trying to force it will result in damage. The same with the two plastic levers for speed and disk size. If you try to force those levers before servicing the table, you'll break them. You'll be left with a doorstop.
underside. The picture shows the table before teardown
The work to remove stuck components isn't complex, but you need to be very careful. Whenever you use force, you're doing something wrong. I removed motor, wiring, and the parts that blocked access to the lower part of the mechanism.
These pictures show different aspects before servicing:
Here, I have removed the components that block access to other parts that need to be serviced:
A first test to see if the mechanisms work after servicing - without the motor in place:
Service the motor
The motor was in good condition. But because I had removed it, it was an opportunity to service it and replace the oil.
... then placed it back:
Check power switch and suppression capacitor
In this model, the switch click suppression cap is usually good. I checked it anyway, to see if it was healthy.
image image
At this time, I was able to do a full automation test:
And a first run of a single from start till end. This test was done with a temporary stylus:
Conversion of the tonearm wiring from DIN to Phono
In Europe, this model was wired for DIN. That means that left ground, right ground and table chassis are connected together inside the table.
Somewhen it its lifecycle, a previous owner cut off the DIN plug and replaced it by phono (cinch) plugs. But they didn't split the 3 grounds as required by the phono wiring standard. I resolved that.
The phono plugs had bad contact. I replaced them.
image image image image
Headshell and Stylus
The 1218 is a stacker table. You can put 6 records on it. It 'll drop each record on the turntable and play it. Then the arm returns to the rest, a new record drops, and gets played. Etc. To compensate for the hight of 6 records, the headshell has an angle adjustment mechanism. That's broken on each table of this model now (if not, it will once you touch it).
I tried to fix this with glue. But then it just breaks somewhere else.
I found a 3D printed replacement on the internet. Not a good looker, but its functional:
image: vendor's photo of the replacement axle for tonearm angle adjustment
update 18-jun: the replacements arrived:
I fitted the stylus. It's an elliptical-cut aftermarket replacement for Shure's N95ED:
image image
Housing Clean-up
There were several housing options for this table. In Europe, it typically came in the base that I have. It was dirty, with a part of the acrylic lid broken and glued back. I rejuvenated the veneer, and left the lid as is.
bonus: facts from DUAL's brochure:
image source: https://hifi-wiki.com/index.php/Dual_1218 - fair use, low resolution render. Click the link for the full resolution picture.
bonus: stacker in action
bonus: original documentation
Thank you for reading.
    Jan Cumps over 1 year ago +1
    It works https://youtu.be/M9XkLxVSuXc and with the stacker: https://youtu.be/xVOlOEnFSzQ
    If you have ever played Syberia - The World Before, you may have spotted this table:
  • colporteur
    colporteur over 1 year ago
    How many man (person) hours did you invest in the restoration?
    Jan Cumps over 1 year ago in reply to colporteur
    ow, a lot. I'd guess somewhere between 10 and 20 hours. Most time spent on removing part, getting stuck parts separated from their pivots, and removing old lubricants,
  • colporteur
    colporteur over 1 year ago in reply to Jan Cumps
    Restoring it to working condition gives credit to your skills. I seem to recall you dabble in audio or are a professional audiophile.
  • colporteur
    I love music and meddling with audio gear Hearts. Old and new, analogue or digital. It's a hobby. Nothing professional,
