Spy Nerd
  • Spy Nerd
Spy Nerd
Blog TKKOK D80 Night Vision Binoculars - Review
Join Spy Nerd to participate - click to join for free!
  • Author Author: dougw
  • Date Created: 17 Jan 2022 5:01 AM Date Created
  • Views 4028 views
  • Likes 9 likes
  • Comments 10 comments
  • doug wong
  • night vision
  • ir illumination
  • spy nerd
  • d80
  • tkkok
dougw
dougw
17 Jan 2022
The prize for the Spy Nerd contest finally made it here after a convoluted courier trek. I made an unboxing video and then realized I needed to understand it a bit better, so I did a bit of a review video.
I had fun learning how this instrument works. It performs better than I expected and has a fairly powerful zoom capability. I do not have any software that can view IR images captured by the camera yet (they have some odd format) but the captured IR videos are viewable in VLC. Overall a very interesting prize.
    dougw over 4 years ago in reply to scottiebabe +1
    I think I figured it out. My batteries were a bit weak and the IR illuminator was causing a power brownout glitch while saving the IR image. This corrupted the jpeg. Running from a solid power supply everything…
  • scottiebabe
    scottiebabe over 4 years ago
    Mine powered up with only 4 AA. It also appears to implement power path management and powers off the USB C port when connected to a power source.
    Sometimes it forgets the IR filter isn't in the optical path on power up and the color photos look purple Stuck out tongue
    Yes, mine definitely runs well off the USB C port when the batteries are depleted and even when they are not depleted. I will have to check if the two battery banks are separate with one set only used for IR illumination.
    What viewer software do you use for IR images?
  • scottiebabe
    scottiebabe over 4 years ago in reply to dougw
    Not sure, there may be a FW bug buried and you happened to discover it. I noticed every image has the exact same file size. Perhaps there is a bug creating exact file size jpegs, not sure.
    The IR image 2 posts up, was just drag-and-drop into chrome.
    Yes, mine are all the same size as yours, but dragging into Chrome doesn't work.
  • scottiebabe
    Playing around earlier I did end up with a bad image file
    Not sure how, only guess I have is the image was overexposed. Perhaps only largely dark images work, I don't know. That's annoying.
    I think I figured it out. My batteries were a bit weak and the IR illuminator was causing a power brownout glitch while saving the IR image. This corrupted the jpeg. Running from a solid power supply everything works as expected.
  • scottiebabe
    Happy you found a root cause. This is good to know. Happy Spying Wink
  • scottiebabe
