Tales for Makers
  • Tales for Makers
Tales for Makers
Forum The Predictive Maintenance Tale - piezo element voltages
Join Tales for Makers to participate - click to join for free!
  • Replies 19 replies
  • Subscribers 7 subscribers
  • Views 6177 views
  • predictive maintenance
  • rides and Ferris wheels
  • talesformakersch
Jan Cumps
Jan Cumps over 4 years ago
For balearicdynamics' Tales for Makers Amusement Park, I'm making a predictive maintenance design for the rides and Ferris wheels. They have to be kept safe and in good condition.
The project is a little piezo buzzer. In this little forum post , I show that these can generate high voltages that can damage microcontroller inputs.
The artwork in this story is an ode to Benoît Sokal. Comic Artist and Designer of the Syberia game.
A piezo transducer can act as speaker or sensor. I'm using it as a sensor. Piezo can generate high voltages - an element is used to generate the spark in piezoelectric stove igniters. Although these high voltages aren't generated when measuring usual mechanical vibrations, a protection circuit is advised. Even a medium tap on the sensor generates 10s of volts.
image source: product page of the kit I bought on Conrad
There are breakout kits from several companies for Arduino and Raspberry Pi, that come with a piezo element and a protection circuit. They all seem to deploy the same protection circuit:
The diode is a 5.1V Zener Diode. But let's see what happens if I hit a test probe on the board where sensor sits on:
It's a "plastic on cardboard" action. I can easily generate 24 V peaks with the protection circuit in place. Not good for a 5V UNO. Most likely unhealthy for 3.3 V Arduino MKR or Raspberry Pi. If this would be mounted on metal, and a metal part would be used to hit, I'd expect the peaks to go higher. There's almost no energy - it's all voltage and for a short time. But it's voltage that often does the damage.
also check out this related post:  Piezo disk as Vibration Sensor: input buffer and filter
Additional Syberia art from this walktrough, from PlayStation store.
    michaelkellett over 4 years ago in reply to michaelkellett +3
    Here's a way of using a single supply. You need one big decoupling cap but its very hard to see any way round that. If you give the sensor a really big thump the voltage across C3 will chang so you need…
    michaelkellett over 4 years ago +2
    Hello Jan, Not very suprsied by the result or the badness of some of the Arduino and Pi support stuff - it's attracted a lot of very low end suppliers. There is a very old charge amp/filter fronmt…
    Jan Cumps over 4 years ago +2
    Action video: www.youtube.com/.../_FsigN2DZkQ
    0 michaelkellett over 4 years ago
    Hello Jan,
    There is a very old charge amp/filter fronmt end ciruit on my website and I've adapted it for your sounder sensor.
    I've guessed your source capacity at 25nF.
    This circuit gives real and fast protection and band pass filtering and the ability to drive an ADC properly.
    I've modelled it with dual supplies but you can use and RRIO type CMOS amplifier with a single supply to match the ADC. (with suitable biasing of course)
    Putting the protection diodes on the summing node of the charge amp means that there is no voltage (almost) across them in normal operation so they don't screw up the LF response (which the zener across the sensor can.)
    C1 and V1 represent the sensor
    R1 sets a HF rolloff (dependent on the source capacity as well (yes the source capacity))
    C2 sets the charge gain (if C1 = C2 the output is the same as the open circuit outpuy of the sensor would have been))
    Because R1 is between the sensor and the protection diodes they will clamp the maximum input to the amplifer effectively.
    The blue trace is the voltage on the summing node.
    0 Jan Cumps over 4 years ago in reply to michaelkellett
    It's 10 nF. I'm going to check your circuit. Thank you!
    I installed a fresh LTSpice, updated my KiCad. I'll get going now.
    In the meantime, I received a second piezo element. It was on backorder since begin July. This one is 34.5 nF.
    Both the original one (10 nF) and this one are measured after calibrating the LCR meter.
    0 Jan Cumps over 4 years ago in reply to Jan Cumps
    Simulation results. I saw on your website that you used an LT071, so I downloaded the model from TI, and drew an opamp symbol for it.
    changes:
    • BAV99HM are no longer advised for new designs, suppliers suggest HY variant.
    • 35 nF capacity for the piezo
    It has been some time since I used LTSpice, the muscle memory was gone, but I got it working:
    In volts:
    KiCad schematic
    image image
    edit: the charge capacitor is to be adapted to the capacity of the piezo element (see Michael's post above, and his paper). My element has 35 nF capacity. When I use a 33 nF value in the simulator, I get a response that's close to 0dB. With a 22 nF, it bops up to +4 dB
    33 nF (match the input element)
    22 nF:
    image image
    michaelkellett, is it OK to have your name on schematic and pcb?
  • scottiebabe
    0 scottiebabe over 4 years ago in reply to Jan Cumps
    Nice little TIA circuit! If you are going to make a PCB, you may want to try making a single-supply version too.
    There are lots of low-cost CMOS op-amps, ex: MCP601 nothing special about it all other than that you can still get them in DIP.
    0 michaelkellett over 4 years ago in reply to Jan Cumps
    Absolutely fine re name.
    /members/scottiebabe makes a good suggestion re. single supply op amps.
    The tricky part is getting the biasing right. I'll give it some thought and post something later today if I can.
    0 michaelkellett over 4 years ago in reply to michaelkellett
    Here's a way of using a single supply. You need one big decoupling cap but its very hard to see any way round that. If you give the sensor a really big thump the voltage across C3 will chang so you need to pick the time constant of C3 and R3//R4 carefully.
    A better performance can be obtained with an active voltage divider but thats more parts.
    A really nice op amp for this would be the TI OPA375 but they are currently hard to get.
    The MCP601 suggested by /members/scottiebabe would work but isn't rail to rail input so is kind of near its limit with a 3.3V supply (OK with 5V). It is noisey but this probably won't matter too much.
    The NCV20166 from Onsemi looks good on paper and Farnell have stock (3528474).
    I've never used them.
