Techno Toys
  • Techno Toys
Techno Toys
Blog DollaS Dancer
Join Techno Toys to participate - click to join for free!
  • Author Author: Molham
  • Date Created: 30 Apr 2017 11:51 PM Date Created
  • Views 5005 views
  • Comments 24 comments
  • ti-rt
  • ttoysch
  • project14
  • electronictoych
DollaS Dancer
Molham
Molham
30 Apr 2017
DollaS Dancer
Introduction:
My girlfriend came up with this crazy idea!
Turning a barbie into a dancer on a stage,
The stage is coin bank, so you have to put money into it to make it dance for you.
Figure (0): Barbie Toy
Description:
BOM:
0. Barbie with swimming suit.
1. Right Angle Gear Motor: voltage is 4.5-6V with a no load current of 190mA, output shaft is 9mm long and the gearbox ratio is 48:1 with a wheel speed of 140 RPM (unloaded)
2. Dual Ball Bearing Hub
3. 1.50” Aluminum Channel
4. 1/4" aluminum pole
5. 1/4" wood pole
6. Aluminum box "I found it in the recycling where I work"
7. Plexiglas cover.
8. 8 ohm speaker
9. Mp3 Player Audio Decoder Board
10 Switcher Power Module  LMZ36002EVM see below for more info
RoadTest Review the TI LMZ36002EVM - Review
11. L298N Motor Drive Controller Board Module Dual H Bridge.
12. PIR Motion Sensor.
13. MCU ATMEL ATMEGA328P
Figure (1): Right Angle Gear Motor
Figure (3): Dual Ball Bearing Hub
Figure (4): Dual Ball Bearing Hub
Figure (6.8): Aluminum box with speaker.
Figure (7): Plexiglas cover.
Figure (9): Mp3 Player Audio Decoder Board
Figure (10): Switcher Power Module  LMZ36002EVM
Figure (11): L298N Motor Drive Controller Board Module Dual H Bridge.
Figure (12): PIR Motion Sensor.
Figure(13) MCU Arduino Tiny
Full System:
Code:
' * Title         : DallaS Dancer                                                      *
' * Version       : 1.0        *
' * Last Updated  : 06/2/2017                                                      *
' * Target Board  : Atmel 328p module                                        *
' * Target MCU    : ATMega328p                                                 *
' * Author        : Molham Kayali                                                    *
' * IDE           : BASCOM AVR 2.0.7.5                                           *
' * Peripherals   : Motors Control                                                  *
' * Description   : DollaS Dancer control                                       *
'-----------------------[Definitions]
Declare Function Pir1() As Byte
Declare Function Pir2() As Byte
$regfile = "m328pdef.dat"
$crystal = 8000000
$baud = 9600
'$Sim
'-----------------------[GPIO Configurations]
Config Pind.2 = Output : Dc1 Alias Portd.2 : Reset Dc1
Config Pind.3 = Output : Dc2 Alias Portd.3 : Reset Dc2
Config Pind.4 = Input
Config Adc = Single , Prescaler = Auto , Reference = Internal
Dim Motion As Byte
Dim Motion2 As Byte
Start Adc
Wait 3
'--->[Main Program]
Do
   Motion = Pir1()
    If Motion = 1 Then
     Gosub Move_forward : Waitms 200
     Gosub Move_backward : Waitms 200
    End If
Loop
End
'---<[End Main]
'--->[Move Renbot with 4 motors forward]
Move_forward:
   Set Dc1 : Reset Dc2
   Waitms 100
Return
'--->[Move Renbot with 4 motors backward ]
Move_backward:
   Reset Dc1 : Set Dc2 :
   Waitms 100
Return
'--->[Front PIR sensor]
Local Adcvalue As Integer
      Adcvalue = Getadc(0)
    If Adcvalue < 512 Then
      Motion = 1
    Else
      Motion = 0
    End If
End Function
  • Molham
    Molham over 9 years ago +3
    Sorry guys I just moved all the way from Kansas to California for a new job and I have been unpacking my stuff, I woke up really early today so I can finish this project and I finally found all the components…
  • tariq.ahmad
    tariq.ahmad over 9 years ago +3
    Hi Molham , Winners have been chosen and an announcement will be posted in the next couple of days. Hoping to have this done by end of the day tomorrow.
  • Molham
    Molham over 9 years ago in reply to tariq.ahmad +3
    Thank you for clarifying now I can focus on coming up with an idea for the next project.
  • Molham
    Going nerd about barbie with some research
  • tariq.ahmad
    tariq.ahmad over 9 years ago in reply to Molham
    Can't wait to see what the final build looks like!
    This is exciting!
  • tariq.ahmad
    This is exciting!
