Vision Thing
  • Vision Thing
Vision Thing
Forum Beaglebone Ai Heating Issues
Join Vision Thing to participate - click to join for free!
  • Replies 124 replies
  • Subscribers 18 subscribers
  • Views 21527 views
  • beagleboneai
  • beaglebone ai
  • BeagleBone
  • ai
  • beagleboard
ipv1
ipv1 over 7 years ago
While experimenting with the device, I found that the board would shutdown without warning. The reasons is...
Now I tried a number of combos like us the USB tether, connect with display(yes I have the cursed microHDMI cable) and use standalone but every time, it just overheats if I do anything.
Idle temps are high too. Was wondering if I got a bad board or is it everyone?
  • mudz
    mudz over 7 years ago +7
    After seeing all of you in so much trouble I decided - Why you should have all the fun so iI bought this kit too, to get into the same trouble pool.. After all, we all are community members. Cheers to…
  • tariq.ahmad
    tariq.ahmad over 7 years ago +6
    Hi ipv1 , I looked into this and this is a known issue: BeagleBone AI - Frequently Asked Questions (FAQ) They recommend adding a larger heat sink and cooling via fan.
  • 14rhb
    14rhb over 7 years ago in reply to 14rhb +6
    Hi shabaz - I've made a first prototype which seems to fit quite well. Packing out the top spacing by one extra washer was enough to get it to grip the existing heatsink fins. I'll make a bracket over…
  • 14rhb
    14rhb over 6 years ago in reply to tariq.ahmad
  • phoenixcomm
    phoenixcomm over 6 years ago in reply to tariq.ahmad
    tariq.ahmad tarriq yea I had problems with the fan.. 5v @ 500ma and it you would see 1.45 volts...ouch. So I tossed the fan on my HP power supply set to .5amps and took it up from Ov through 5v about 8volts it started turning. and then took it up to 12volts. Now works fine on my 5v@500ma wall wart. LOL
    My plan is to print a case for it and put a fan in the case as well. BTW if you put a spacer (1-2mm) between the fan and the heat sink you will get more airflow. As there will be less resistance on the fan and will pull more heat out as well.
  • tariq.ahmad
    tariq.ahmad over 6 years ago in reply to phoenixcomm
    Thanks phoenixcomm ,  haven't heard a whole lot   Glad to you see you are up and running again.   Will be interesting to see how others use the fan or what solutions people come up with.   Interesting to discussion on fans  here as well:
    First of All, Tame the roaming beast, BBB AI.
    But looks like this has become the definitive post on bb ai heating issues...
  • phoenixcomm
    tariq.ahmad yes the fan and heat sink are issues. I will be putting this in a larger box that I will print. with a real CPU fan on one side and that should help with the cooling. image
