Vision Thing
  • Vision Thing
Vision Thing
Forum Beaglebone Ai Heating Issues
Join Vision Thing to participate - click to join for free!
  • Replies 124 replies
  • Subscribers 18 subscribers
  • Views 22375 views
  • beagleboneai
  • beaglebone ai
  • BeagleBone
  • ai
  • beagleboard
ipv1
ipv1 over 7 years ago
While experimenting with the device, I found that the board would shutdown without warning. The reasons is...
Now I tried a number of combos like us the USB tether, connect with display(yes I have the cursed microHDMI cable) and use standalone but every time, it just overheats if I do anything.
Idle temps are high too. Was wondering if I got a bad board or is it everyone?
  • mudz
    mudz over 7 years ago +7
    After seeing all of you in so much trouble I decided - Why you should have all the fun so iI bought this kit too, to get into the same trouble pool.. After all, we all are community members. Cheers to…
  • tariq.ahmad
    tariq.ahmad over 7 years ago +6
    Hi ipv1 , I looked into this and this is a known issue: BeagleBone AI - Frequently Asked Questions (FAQ) They recommend adding a larger heat sink and cooling via fan.
  • 14rhb
    14rhb over 7 years ago in reply to 14rhb +6
    Hi shabaz - I've made a first prototype which seems to fit quite well. Packing out the top spacing by one extra washer was enough to get it to grip the existing heatsink fins. I'll make a bracket over…
    shabaz over 7 years ago in reply to tariq.ahmad
    Hi Tariq,
    That's really awesome of you!
    I already have a similar fan so I don't need one, but it's really nice to see the offer.
  • mudz
    After seeing all of you in so much trouble I decided - Why you should have all the fun so iI bought this kit too, to get into the same trouble pool..  image
    After all, we all are community members. image
    Cheers to all ..
    • Vote Up +7 Vote Down
  • 14rhb
    14rhb over 7 years ago in reply to tariq.ahmad
    Hi Tariq,
    Thank you for your generous offer. I should have something suitable in my makers box - so don't need one.
    Thanks again
  • 14rhb
    14rhb over 7 years ago in reply to clem57
    Is it possible to remove, add new solder paste and replace the heatsink?
    Jan Cumps over 7 years ago in reply to 14rhb
    A little bit of heat works. A hairdryer or hot air blower on low temperature ...
    • Vote Up +5 Vote Down
    shabaz over 7 years ago in reply to 14rhb
    I'm still going back-and-forth on what to do, but am currently thinking of leaving the heatsink attached (too scared to try to remove it : ) and then glue a larger aluminium plate (maybe just 1mm thick?) to it, using double-sided thermal tape.
    Then, there are quite low-profile heatsinks that are 20x20x2.5mm, so I could try gluing (say) four of those to the top of the aluminium plate, i.e. for 40x40mm total area or slightly more. Then, have a 40mm fan on the acrylic cover blowing down on those heatsinks. That way the larger fan is blowing over more surface area.. I'm not too good with thermodynamics so this is just experimental!
    shabaz over 7 years ago in reply to gdstew
    gdstew  wrote:
    I've got a couple of 40mm fans but what I found was they have large motor hubs and very small blades which puts the blades too far away from
    most of the heat sink for my liking
    That's a good point.. subconsciously that must have been bothering me too, so I've been thinking of trying to make the area larger (with an aluminium plate). The height of the heatsink that comes attached to the BB-AI clears the height of the USB connector too, so quite a large plate could be glued on top. It might be inefficient though.. I'll try it anyway, and if it doesn't cool sufficiently, I'll switch to the 25mm fan.
  • 14rhb
    14rhb over 7 years ago in reply to shabaz
    I too thought that might be the safer option. I was looking at mine last night and I am going to make a heatsink that fits into the existing slots - I reckon five 60mm x 30mm high x 1~2mm thick aluminium plates. I'd use some thermal paste and bend the fins slightly to get a good friction fit. Then as 'belt and braces' I'd add a fan.
    I'll post any progress.
    Jan Cumps over 7 years ago in reply to shabaz
    The actual location that the blades are pointing to is not very critical. The goal is to keep the air flow going so that the hot air gets evacuated and replaced by cold air. The air volume plays the bigger role here.
  • 14rhb
    Hi shabaz - I've made a first prototype which seems to fit quite well. Packing out the top spacing by one extra washer was enough to get it to grip the existing heatsink fins. I'll make a bracket over the top for my DC fan and add some thermal grease on the final assembly.
    I think I've just fed my Beagleboard a new bone so I'm going to call it the "Beagleboard's Bone" and might even shape those aluminium fins accordingly image
    {gallery} Beagleboard's Bone
    BeagleboardAI: Heatsink
    I'll spin that U.Fl antenna around as well.
    • Vote Up +6 Vote Down
