Webinars, Training and Events
Blog Problems with Solder joint cracking? Panasonic has the solution!
Join Webinars, Training and Events to participate - click to join for free!
Group - Links
  • Date Created: 12 Nov 2013 5:16 PM Date Created
  • Views 735 views
  • smd_resistors;solder_joint_cracking
  • panasonic;
e14 Contributor
e14 Contributor
12 Nov 2013
Do you have problems with solder joint cracking?
Solder joint cracking  is caused by difference of Thermal Expansion coefficient between PCB and resistor body.
In order to avoid solder cracking Panasonic uses   “Soft Termination technology” for all SMD resistors .
“Soft Termination technology”  helps to minimize solder joint cracking  caused by tough temperature cycle conditions.
Want to find out more; click here: http://uk.farnell.com/jsp/search/browse.jsp?N=2031+215515&Ntk=PLS_MAN_BRAND_NAME&Ntt=panasonic&Ntx=image
