Webinars, Training and Events
Forum Nubie question
Join Webinars, Training and Events to participate - click to join for free!
  • Replies 7 replies
  • Subscribers 1056 subscribers
  • Views 1178 views
Nubie question
Hi, I'm just starting out on electronics, spurred on by getting a Raspberry Pi.  I'm accumulating some equipment and a crazy assortment of components.
So...
I've gotten a off-brand Multi-Meter.  One thing I've noticed is that when measuring Amps, the value continually drops as I hold the probes against the power supply.  Is this normal or is there something wrong with the meter?  If it's normal, do I take the measurement from the moment I touch the probes?
Second, the collection of resisters, caps, trnasisters, ICs etc. will soon overwhelm my ability to identify these minescule pieces.  How do you seasoned vets manage this stuff??
  • johnbeetem
    0 johnbeetem over 13 years ago in reply to e14 Contributor
    Lou Gallo wrote:
    Thanks John, that makes the future a bit brighter.  This weekend I also looked around for some storage bins with lots of drawers.  I didn't really come up with one that exactly fit the bill. Any suggestions?
    Large hardware stores should have this sort of thing.  For example, I found quite a few at USA's Home Depot.  Search for "parts cabinet".
    0 e14 Contributor over 13 years ago in reply to afmishaq
    Ha ha, yeah, Abul I survived my first potential disaster.   image
    0 e14 Contributor over 13 years ago in reply to johnbeetem
  • afmishaq
    0 afmishaq over 13 years ago in reply to e14 Contributor
    Good to know that both the multimeter and the power supply survived!
  • johnbeetem
    On a circuit board like RasPi, you try to get a schematic diagram.  RasPi's diagrams are at RasPi Hardware Wiki along with high-quality photos of the bare boards so you can easily find the names of components.  With purchased components such as SMT (surface mount technology) capacitors, resistors, etc. keep them in their bags until used.  If you have an unknown board with a unknown components, you basically have to use your experience to guess at what things are.  Sometimes small transistors and ICs have cryptic codes on them which you look up at the manufacturer's web site to see which component it is.  However, figuring out which manufacturer can be problematic, particularly if they're cheap Chinese equivalents instead of well-known manufacturers like OnSemi and Fairchild.
    We sometimes get questions here at element14 from someone who posts a high-quality photo of a component and asks for help identifying it.  They usually get lots of replies because most engineers love to solve puzzles.
    0 e14 Contributor over 13 years ago in reply to michaelkellett
    Hi Mike, well, yes I am.  OK, so Note-To-Self: don't take meter readings over a short circuit.  I put a 10K ohm in line and got a nice steady reading.  -- Thanks
    0 michaelkellett over 13 years ago
    Are you connecting the meter directly across the power supply terminals and reading the current ?
    If so this will be measuring the short cicruit current out of the supply which will likely be changing as the internals cook.
    Connect the meter in series with a resistor to the power supply and the current should be equal to V/R. (It won't be exact because the meter has a finite shunt resistance when measuring current whic drops some voltage.)
