Webinars, Training and Events
Forum Basic Electronics Question for Makers: What are Digital Isolators?
Join Webinars, Training and Events to participate - click to join for free!
  • Subscribers 1054 subscribers
  • Views 1102 views
  • scasny
rscasny
rscasny over 8 years ago
While getting to know how to use electronic components in projects is an important step in making your project work, sometimes you just need to know how the individual components work. So, let's explore in this discussion digital isolators. What are they and why do you need to know about them?
Let's first talk about isolation.
Isolation is a means of preventing dc and unwanted ac currents between two parts of a system, while allowing signal and power transfer between those two parts.
Electronic devices and semiconductor ICs used for isolation are called isolators. Some of the benefits of isolators are faster data transmission, higher magnetic immunity, and longer life expectancy. Used in combination with isolated power supplies, they can block high voltages, isolate grounds and prevent noise currents from entering the local ground and interfering with or damaging sensitive circuitry.image
In general, a digital isolator is made up of a high voltage isolation component or barrier and a transmitter (TX) to couple a signal into one side of the isolation component, and a receiver (RX) to convert the signal available on the other side of the isolation component into digital levels. Isolators can use SiO2 (silicon dioxide) based, high-voltage capacitors to serve as the isolation component.
To learn more about isolators, I encourage you to sign up for the webinar: TI Webinar: Understanding Capacitive Isolation Technology for Industrial Applications
  • Robert Peter Oakes
    Robert Peter Oakes over 8 years ago
    LOL, I almost forgot, the DC Load project than Jan and I started that has been running on E14 for a couple of years also uses an I2C TI digital isolator at its interface to the launchpad
    They are also excelent in providing a level shift capability were for instance you need to drive a High side  MOSFET were you control logic (A micro controller pin for example) needs to switch a MOSFET sitting on top of a 30V power rail.
    TI also has an excelent range of isolators specifically designed for I2C and SPI bus operation, I have used them on many occasions and have even published videos using them on the E14 community https://www.youtube.com/watch?v=BvIQ0b2gUFs
    Very much worth watching this webinar, I look forward to it
