STEM Academy
STEM Academy
Forum Problem Running Mopidy
  • Subscribers 53 subscribers
  • Views 1036 views
  • mopidy
  • stem space
mikedavis
mikedavis over 12 years ago
I have a problem running Mopidy on my RPi.  I get this error message:
ERROR MPD Server startup failed: [Erno 98] Address already in use
Any suggestions on overcoming this?  Do I need to assign another port to MPD in the config file?
  • bltsandwich1
    bltsandwich1 over 12 years ago
    First I have to ask, are you sure that you've installed the right version for the OS you are running it on? Debian VS Raspbian makes a difference.
    John Moosemiller
  • mikedavis
    mikedavis over 12 years ago in reply to bltsandwich1
    I believe it is Raspian.
  • bltsandwich1
    bltsandwich1 over 12 years ago in reply to mikedavis
    From the link below I notice that there are 2 sets of installation instructions. Each specific to the type of OS it will be running on. For this software there is (apparently) a notable difference in the functionality whether it is running on a 'Hard-Float' or 'Soft-Float' OS. Outside of this I'm not sure what else I could suggest without running through your process.
    Let me know  if this helps at all, or if there is anything else I can help with.
    http://docs.mopidy.com/en/latest/installation/raspberrypi/
