microbit
  • microbit
microbit
microbit Forum Rotation, Roll sensor, that is adjustable. A buzzer that will let you know when the RC truck is about to roll over.
  • Subscribers 48 subscribers
  • Views 1079 views
BenchMade
BenchMade over 3 years ago
I would like to know the steps on how to capture the role of an RC vehicle,  before it is about to roll on its side.  The micro:bit can be placed on the RC vehicle on the roll axis.
Micro:bit will be placed on the RC truck,  Roll axis .  Then A switch will Capture 0 value of the roll value.  Then the RC truck will be tilted at 90° or whatever the role value is, before it tips over.
Here is what I have on my micro:bit,  to capture the data when the air switch is pressed.  And when the B button is pressed down, it captures the angle of the roll.
what I don’t know is how to include the buzzer so when it gets to the point of the data captured on the B switch, it will start buzzing.
There is a YouTube example.
www.youtube.com/watch
  • beacon_dave
    beacon_dave over 3 years ago +1
    One way might be: In the main program loop, forever compare the current rotation angle with the tilt value stored by button B and if it is greater than or equal to, then turn the buzzer on, else turn…
  • beacon_dave
    0 beacon_dave over 3 years ago
    One way might be:
    In the main program loop, forever compare the current rotation angle with the tilt value stored by button B and if it is greater than or equal to, then turn the buzzer on, else turn the buzzer off.
    There is an example here which may help:
    https://makecode.microbit.org/reference/input/rotation
    Note that you may want to disable the buzzer until button B has stored the desired tilt threshold value otherwise the buzzer may start sounding before button B has been set. You could also initialise the tilt threshold value to a very high tilt value and then pressing button B effectively lowers it.
    Also you appear to be measuring pitch and not roll in your code. This may be intentional due to the orientation of the micro:bit on the vehicle.
    If you are just starting out with the micro:bit then you may be interested in getting hold of a copy of this book:
    https://www.mheducation.co.uk/save-the-world-with-code-20-fun-projects-for-all-ages-using-raspberry-pi-micro-bit-and-circuit-9781260457599-emea
    or perhaps taking a look at the Physical Computing course on FutureLearn:
    https://www.futurelearn.com/courses/build-a-physical-computing-prototype
    where if I recall correctly, the final project is a remote control car using two micro:bits
