micro:bit tutorial videos
  • microbit
  • micro:bit tutorial videos
Blog Controlling NeoPixels with Buttons on micro:bit * 06 *
Join micro:bit tutorial videos to participate - click to join for free!
  • Author Author: TechnoChic
  • Date Created: 29 Apr 2024 5:27 PM Date Created
  • Views 1588 views
  • Microsoft MakeCode
  • micro:bit
  • Make Code
  • micro:bit project ideas
  • micro:bit projects
  • micro:bit and neopixels
TechnoChic
TechnoChic
29 Apr 2024
Welcome back! Natasha here. :)
This is the sixth of 10 blog posts featuring each video in my series on animating LEDs with micro:bit and Make Code. If you've just stumbled upon this post, start from the beginning here.
Let's Make a NeoPixel Controller with micro:bit!
micro:bit buttons with neopixels
Watch it now:
In this video, we'll continue beyond making individual animations and learn to select and trigger specific animations using the buttons on the micro:bit.
how to use the micro:bit buttons
First, I'll show you how to set up the buttons in code blocks and talk about how they work:
Setting Up On Button Pressed Block in Make Code
Then, I'll teach you how to create animation modes that can be selected using the buttons:
Creating Animation Modes
And finally, I'll introduce the if/else block and show how to configure what animation plays each time you toggle through the animation functions that you've created.
If Else and Modes in Make Code
How did it go?
What animations did you make? Do you have an idea but don't know how to start?
Comment below or join the Discord channel to share your questions and ideas.
See you there! Slight smile
