micro:bit tutorial videos
  • microbit
  • micro:bit tutorial videos
Blog The simplest LED Controller: What to Buy
Join micro:bit tutorial videos to participate - click to join for free!
  • Author Author: TechnoChic
  • Date Created: 29 Mar 2024 6:00 PM Date Created
  • Views 2454 views
  • Likes 9 likes
  • Comments 5 comments
  • micro:bit
  • micro:bit project ideas
  • led
  • The easiest way to program neopixels
  • neopixel
  • How to program neoPixels
  • led projects
  • micro:bit projects
  • micro:bit and neopixels
TechnoChic
TechnoChic
29 Mar 2024
Welcome back! Natasha here.
This is the second of 10 blog posts featuring each video in my series on animating LEDs with micro:bit and Make Code. If you've just stumbled upon this post, start from the beginning here.
In this video, I'll explore the components needed to create and code a light-up bike helmet project. I'll talk about the programmable LEDs called Neopixels, a small computer to control them called a micro:bit, the best battery to run it on called a LiPo battery, and materials to connect the project components together. After watching this video, you'll know exactly what to buy to follow along with the series and build your LED bike helmet with custom animations.
PROJECT SUPPLIES: (some links earn commissions)
NeoPixel LEDs:
https://www.newark.com/adafruit/3812/adafruit-neopixel-led-strip-w/dp/62AC0997?ost=adafruit+3812
micro:bit Controller:
https://www.newark.com/bbc-microbit?ost=microbit&rd=microbit
LiPo Batteries for micro:bit: *double check polarity before buying!* (get 500 mAh or more)
https://www.newark.com/adafruit/1578/battery-voltage-3-7v/dp/52X6819?ost=adafruit+1578
LiPo Battery Charger:
https://amzn.to/3SPnGaW
micro:bit Cases: *double check version before buying!*
https://www.newark.com/MarketingProductList?orderCode=75Y0420,75Y0419,29AC0390,29AC0391,14AC4497,44AC5616,01AH8675,01AH8676,01AH8677,01AH8679,01AH8680,01AH8681,01AH8682
Other Accessories:
Velcro Dots (Industrial Strength!): https://amzn.to/4bRDsuG
Velcro Squares: https://amzn.to/48rcK9e
Velcro Cable Ties: https://amzn.to/3Ice2du
Mounting Tape: https://amzn.to/3OWtpum
micro:bit watch accessory: https://amzn.to/3uH8zbv
    beacon_dave over 2 years ago +1
    The non standardised polarity of the battery connectors catches a number of beginners out. I have found that the connectors on the EEMB badged battery packs supplied by the likes of Amazon tend to have…
    Jan Cumps over 2 years ago in reply to Jan Cumps
    solved. Thank you Slight smile
  • TechnoChic
    TechnoChic over 2 years ago in reply to DAB
    I'll paste it here, but also look in the video description Slight smile
    The non standardised polarity of the battery connectors catches a number of beginners out. I have found that the connectors on the EEMB badged battery packs supplied by the likes of Amazon tend to have their polarity reversed from those connectors found on the Adafruit ones.
    DAB over 2 years ago
    In addition to the video, you might want to make a list of the components with links for more information or purchasing.
    to add a video, use the insert video menu.
    At the moment, the post contains an unclickable link
