microbit
  • microbit
microbit
Documents Accessory of the Month | micro:bit wear:it Development Kit
  • Author Author: jlucas
  • Date Created: 7 Dec 2018 2:35 PM Date Created
  • Last Updated Last Updated: 7 Dec 2018 2:35 PM
  • Views 529 views
Each month, we're going to shine a light on a kit or accessory that you can use to enhance your micro:bit projects. This month our featured product is the wear:it Development Kit, developed by element14.
What is it?
A versatile micro:bit enclosure that contains everything you need to start developing your first projects, the wear:it development kit is specially designed to suit mobile applications and to highlight the micro:bit's wearable applications. It can be used with a wrist strap, keyring or lanyard to open up a wide range of exciting on-the-go activities, making it perfect for use in the classroom.
Features
  • Mount and protect your micro:bit in a specially designed enclosure for easy access and wearability
  • Turn your micro:bit into a watch, a pedometer, an electronic name tag and much more with a variety of wearable options - including wrist straps, lanyard, keyring and belt clip.
  • Easily connect your micro:bit to a computer using included USB cable
  • Write and compile code for your device on the easy-to-use micro:bit MakeCode editor.
  • Send code wirelessly to your micro:bit using Bluetooth
Kit Contents
  • 1x micro:bit programmable micro:computer included with the package.
  • 1x micro:bit enclosure
  • 2x AAA Batteries included to power your micro:bit
  • 2x Wrist Straps
  • 1x USB cable to connect your micro:bit to your computer
  • 1x Lanyard
  • 1x Keyring
  • 1x Beltclip
Requirements
  • None
Additional Resources
Check out our wide range of wearable micro:bit projects with this downloadable classroom poster.
Road Test Reviews
  • Nitin Mane (57/60)
  • Daniel Wilches (56/60)
  • microbit featured accessories
