STEM Projects
  • STEM Projects
STEM Projects
Blog Book Carrying Robot #4 Standalone complete code Running on Raspberry PI
Join STEM Projects to participate - click to join for free!
  • Author Author: mohanedessam
  • Date Created: 18 Aug 2015 11:25 AM Date Created
  • Views 1872 views
  • Comments 9 comments
  • image_processing
  • teachers_pet_robotics_design_challenge
  • teachers_pet
  • matlab_raspberry_pi
  • raspberry-pi
  • matlab
  • teachers pet robotics design challenge
  • digital_imaging
  • book_carrying_robot
  • simulink
mohanedessam
mohanedessam
18 Aug 2015
I have been able to complete my program that can identify the robot path using colored paper or stickers. the code is done in normal MATLAB coding similar to my previous posts.
I thought I would rather show my results first, then explain about my methodology in the following posts.
After I completed my code. I was able to translate this into a standalone program running independently on Raspberry PI using Simulink.
The program basically takes images from the Raspberry PI board camera, process them that and controls two motors through the Raspberry PI GPIO pins, making the robot follow the correct path.
the details about my code and how I made it as a standalone program on Raspberry PI will be explained in my following posts, However I will show here what I managed to do.
First I will show a video of the Program Running on Raspberry PI, where you can see the motors are controlled depending on the colored object position, all this is done solely on Raspberry PI (standalone program).
I was not able to upload the Video here so please follow this link:
https://www.youtube.com/watch?v=J7VL2jgqyqM&feature=youtu.be
this is an image of my setup
Also you can see in my second video a live feed while the program is running on Raspberry PI and How is it processing the images it get.
The video is shown in Simulink, however the code is still running as standalone program on Raspberry PI
I was also not able to upload the Video here so please follow this link:
https://www.youtube.com/watch?v=cJ8uMaAZnHM&feature=youtu.be
I will explain about my methodology and how to run the program as standalone program on Raspberry PI in my next posts, I will also include all my simulink and MATLAB codes.
  • madhugovindarajan
    madhugovindarajan over 11 years ago +1
    Only after re-watching did I realize that the robot wheels are turning towards the colored lines. I understand that this is just to show us what you have done, with the robot sitting on top of a station…
  • Robert Peter Oakes
    Robert Peter Oakes over 11 years ago +1
    you can link the video in from YouTube by clicking the video button and selecting WEB, provide the youtube link and it will pull in the rest. I do this all the time for my videos
  • mohanedessam
    mohanedessam over 11 years ago in reply to Robert Peter Oakes +1
    I have edited the post
  • madhugovindarajan
    The second video makes it even better image. The Video Capture block gives you 160x120 pixels by default, is that why the display looks tiny? or is that also part of your algorithm?
    Can't wait to see the complete set of files used!
  • mohanedessam
    mohanedessam over 11 years ago in reply to madhugovindarajan
    yeah it's a part of algorithm, actually I take frames of 480x640 pixels but I see that most of the picture is not necessary and cause overhead on processing, so before i do my processing, I cut parts that are not important for the output (i.e. part of the robot body, distances that considered so far, etc ... actually this video is 60x640 pixels .
    Thank you so much, I will upload all the files once I manage to document my sources and make the codes presentable
  • mohanedessam
