STEM Academy
STEM Academy
Documents STEM School:  Transistors
  • Author Author: kellyhensen
  • Date Created: 10 Feb 2021 10:49 PM Date Created
  • Last Updated Last Updated: 1 Jul 2021 1:59 PM
  • Views 840 views
STEM School rounds up the best educational content on the element14 Community.
This time we are talking Transistors.
Do you have an educational post to add? Then please post it below.
How Transistors Work
Rather than using a physical, mechanical switch, a transistor can act as an electronic switch, using signals to turn it on or off.  In this episode of The Learning Circuit, Karen explains Bipololar junction transistors (BJT), NPN transistors, PNP transistors, and darlington transistors.
The Learning Circuit 27: How Transistors Work
The above video link talks about how transistors work – in this video, Karen demonstrates how to use transistors to build a simple project that proves these concepts:
The Learning Circuit 28: Make Your Own Candy Thief Alarm
You may also be interested in:
The Learning Circuit 37: Community Feedback: Revisiting Transistors
Transistor eBooks
A transistor is a semiconductor device used to amplify or switch electronic signals and electrical power. Transistors are one of the basic building blocks of modern electronics.
Transistor eBook
  • Download Part 1
  • Download Part 2
From The Community
JFET Colpitts Oscillator
Plotting the Output Characteristics of a JFET
Experimenting with MOSFETs: Output Characteristics
Experimenting with MOSFETS: Total Gate Charge
Experimenting with MOSFETs: Transfer Characteristic
Buy now
Browse Vishay MOSFETS
Browse Vishay Automotive Components
See all Vishay Products
  • stem_academy
  • transistors
