      • Japan
      • Vietnam
Publications
Publications
Blog A circuit to improve your cognitive performance
  • Date Created: 21 Sep 2011 6:42 PM Date Created
  • Views 776 views
  • Comments 5 comments
  • research
  • alternative_energy
  • dit
  • hmi
  • human
  • circuit
  • on_campus
  • cabeatwell:dit
  • measurement
  • university
  • energy
  • performance
21 Sep 2011
The University of New Mexico has developed a circuit that will improve human mental performance. It is simple, just apply 2mA at 9v to the cranium.
The DARPA study conducted by the university was to look at how to improve soldiers' mental performance in the battlefield, or as they put it "to sharpen soldiers' minds." Test subjects were to learn and play the game "DARWARS Ambush!" The game puts the player into a hazardous, virtual, environment littered with dilapidated buildings, wrecked cars, and civilians. The purpose of the game is to locate potential dangers like improvised explosive devices, combatants, and other battlefield dangers. (Soldiers bound for Iraq are trained with this game.)  While immersed in the game, the player has a wet sponge attached to their right temple where the 2mA is trickled.
The experiment was conducted by neuroscientist Vincent Clark, and the technique is dubbed transcranial direct-current stimulation (tDCS). Clark stated that "They learned more quickly, but they don't have a good intuitive or introspective sense about why." A common side effect, aside from the itchy electrode on the side of the head, was experiencing flashing lights. The positive effects may outweigh the negative. The tDCS experiment showed improvements in working memory, word association, and complex problem-solving.
Other researchers seek to improve on Clark's tDCS system. For example, Allan Snyder, of the University of Sydney, want to make a "thinking cap" that corporate executives and creative people may use before going into a brain-storming meeting. Other researchers are predicting widespread use of such devices in academia and medicine. Many claim that a form of tDCS may help with depression.
Does this sound like old pseudoscience to you? It should. In the 1800s, Italian scientist Jean Aldini, used direct current to stimulate corpses of executed felons. Later Aldini used the method to treat the mood disorder, "melancholy." In the 1940s, patients were treated with electroshock therapy for depression. In 1964 psychiatrist Joe Redfearn applied weak currents to humans in the 50-250 micro amp range. In the experiments he claimed that patients would be "giddy and talkative" when the current was applied in one direction "withdrawn" when applied in the opposite. Redfearn also said it improved patients with depression, despite not being able to replicate the results.
Perhaps tDCS will be a future alternative to coffee or energy drinks. The following chart is from Clark's research paper. Now, is anyone brave enough to try the brain-stim?
Cabe
  • Former Member
    Former Member over 14 years ago in reply to Catwell
    Sure Cabe,
    It's hard to say on the alertness/working memory part. I regularly use the Dual-N-Back test to measure/imporve my working memory, and the best results I've had have been immediately after using TDCS, but the effect is a subtle one.
    That said, one of the side benefits (and which is more predicatable and tangible) is that your mood seems to improve: The day after I use TDCS I feel happier/lighter. From my perspective it is worth continuing to use it for this alone.
    There are a few tricks on getting the right electrode placement (this also determines the type of effect TDCS wuill have) and the skin beneath the electrodes can be a bit irritated after 15 minutes, but apart from that I'd recommend it to anyone.
    Cheers,
    Keiran.
  • Catwell
    Catwell over 14 years ago in reply to Former Member
    Keiran,
    Since you have tried it, can you vouch for the results? Did you feel more alert?
    Cabe
  • Former Member
    Hi Eavesdropper,
    I've tried it, but I wouldn't use the circuit they describe here. If you did you'd get 5mA or more out of the battery and that would be most unpleasant on your skin if you kept it up for more than a couple of minutes.
    You'll need a resistor in series with the battery to limit the current (or a pot, for better accuracy/tuning). If you put a 4.7k in series at least you know that you won't be putting more that 2mA through. In my experience, your head (through two wet sponge electrodes) has a resistance of about 2kOhm.
    If you've got a multimeter then I'd use that as well to verify how much current is going through your head.
    Good luck!
  • Eavesdropper
    Eavesdropper over 14 years ago in reply to DAB
    I would give this a try. What was the real schematic for delivering the 2mA. If only applied to the skin, wouldn't it just conduct across the skin surface? What voltage was it at? (9V is what I assume)
    E
    DAB over 14 years ago
    I have to admit, my attention to my work always improves right after I get a good shock by touching the wrong wire.  I suspect that the electric current stimulates the adrenal gland, which would make you both attentive and alert.  The downside would be the bodies reaction to excessive adrenalin surges.  Those have been known to kill people.
    Still, it could be worth some expirementation with medical supervision.
    Now where did I put those jumper cables? image
