Member and Staff Blogs 8 led effect with CD4017
  • Author Author: andrewblog
  • Date Created: 6 Oct 2016 3:55 PM Date Created
  • Views 1494 views
  • Comments 7 comments
  • cd4017
  • led effect
andrewblog
andrewblog
6 Oct 2016
This circuit produces a running led effect without using microcontrollers. All you need are two CD4017 counters, a NE555 timer and some basic skills in electronics. At the start condition the clock enable (pin 13) of the IC1 counter takes the direct negative signal from the last output of that counter. Such negative signal is inverted by the Q17 transistor and sent to the clock enable of the IC2. So the first counter drives the led from 1 to 8, while the second one keeps on the first output, which is not connected.
When the last output of the first counter turns on, the second counter drives the led from 8 to 1 and its last output gives off the reset signal.
The speed of the led effect can be adjusted by a trimmer.
Thehttps://www.youtube.com/watch?v=eXJgwhYXZH8CD4017https://www.youtube.com/watch?v=eXJgwhYXZH8counter is a CMOS integrated circuit, so it is very sensitive to electrostatic charges.
The circuit schematic is available here:
http://drive.google.com/file/d/0B7LPpongh6DzMTM0ZDk5NGEtNTVjYi00MTNhLThhY2ItNjY2Y2FiZjk5OTE0/view?usp=sharing
  • gihu
    gihu over 9 years ago
    Really nice!!
    DAB, it also takes me back to when I start study digital electronics, and to those times when you looked into those thick books (from national, ti...), with the thinnest pages I have even seen, to look for logic gates, latches, flip-flops, counters, BIN2BCD, BCD2BIN...
  • D_Hersey
    D_Hersey over 9 years ago
    maybe a '191 for the counter and a '138 or a '154 for the decoder
  • andrewblog
    andrewblog over 9 years ago in reply to D_Hersey
    Did you mean the 74190 decade counter?
  • D_Hersey
    https://www.youtube.com/watch?v=FLk0Ye2Vo7Y
    jw0752 over 9 years ago
    Hi Andrew,
    I like your project. It is always fun to breadboard a circuit.
