Member and Staff Blogs 8 led effect with CD4017
  • Author Author: andrewblog
  • Date Created: 6 Oct 2016 3:55 PM Date Created
  • Views 1527 views
  • Comments 7 comments
  • cd4017
  • led effect
andrewblog
andrewblog
6 Oct 2016
This circuit produces a running led effect without using microcontrollers. All you need are two CD4017 counters, a NE555 timer and some basic skills in electronics. At the start condition the clock enable (pin 13) of the IC1 counter takes the direct negative signal from the last output of that counter. Such negative signal is inverted by the Q17 transistor and sent to the clock enable of the IC2. So the first counter drives the led from 1 to 8, while the second one keeps on the first output, which is not connected.
When the last output of the first counter turns on, the second counter drives the led from 8 to 1 and its last output gives off the reset signal.
The speed of the led effect can be adjusted by a trimmer.
Thehttps://www.youtube.com/watch?v=eXJgwhYXZH8CD4017https://www.youtube.com/watch?v=eXJgwhYXZH8counter is a CMOS integrated circuit, so it is very sensitive to electrostatic charges.
The circuit schematic is available here:
http://drive.google.com/file/d/0B7LPpongh6DzMTM0ZDk5NGEtNTVjYi00MTNhLThhY2ItNjY2Y2FiZjk5OTE0/view?usp=sharing
  • D_Hersey
    D_Hersey over 9 years ago
    For what it is worth, if you used an up/down counter and a 3-to-8 or 4-16 decoder, and a F/F you might get the output to go back-and-forth instead of round-and-round.
  • D_Hersey
  • andrewblog
    andrewblog over 9 years ago in reply to D_Hersey
    Did you mean the 74190 decade counter?
