Member and Staff Blogs Body Temperature Probe (Part 1)
  • Date Created: 11 Apr 2011 3:51 PM Date Created
  • Views 623 views
  • hackerspace
  • maker
  • body
  • education
  • pumpingstationone
  • hackerspaces
  • ps1
  • make
  • temperature
  • diy
  • chicago
  • schools
  • sparkfun
  • gghc
  • electronics
  • psone
e14 Contributor
e14 Contributor
11 Apr 2011
This week, I began work on the body temperature sensor.  Since putting the sensor in the user’s mouth would be an annoyance and present a possible choking hazard when performing physical activities, we decided to aim for locating the sensor under the user’s armpit.
We decided, at least for the first release, to go with the  temperature sensor breakout board from Sparkfun Electronics (http://www.sparkfun.com/products/9418).  Its small size will allow us to place it at the measurement location and send digital readings back to the Arduino over standard wire.  A thermocouple based unit would be more stiff and inclined to break over prolonged use or if kinks developed in the thermocouple wire.  Also, it would, probably, require a separate reference junction for accurate measurements.  As an added bonus, Sparkfun provides pre-written Arduino code for this unit which can be found hosted on the Wiring website here: http://wiring.org.co/learning/libraries/tmp102sparkfun.html.
Below, you can see a picture of my test setup wiring connecting the temperature sensor to the Arduino Mega 2560 I’m using for prototyping purposes.  I’ve included an American penny to give some reference for the size of the unit.  For this unit, we’ve soldered pins to the terminals so that it’s easy to breadboard.  The final version will need to be soldered directly to some high-durability shielded wire and installed into some kind of housing with a wire strain relief to ensure a longer life under, potentially, abusive conditions.
In the second photo, you can see the sketch being run on the Arduino Mega.  As you can see, the serial interface shows the temperature values being transmitted, in degrees Celsius, from the unit every half a second.
That's it for now.  Next time, I'll delve into fabrication of the finished, ruggedized, probe.
    e14 Contributor over 12 years ago +1
    Hi I am trying to build a body temperature sensor with the arduino, what type of temperature sensor are you using? and where did you buy it?
  • rosylinda
    rosylinda over 6 years ago in reply to e14 Contributor
    Thank you very much for this new unique discovery, keep it up.
  • rosylinda
